4.2 Using a 4x4 Keypad
In this lesson, we’ll learn how to interface a 4x4 matrix keypad with the Raspberry Pi Pico 2 to detect which keys are pressed. Matrix keypads are commonly used in devices like calculators, telephones, vending machines, and security systems for numerical input.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
4(10KΩ) |
Understanding the 4x4 Keypad
A 4x4 keypad consists of:
16 keys arranged in 4 rows and 4 columns.
8 pins: 4 connected to rows and 4 connected to columns.
When you press a key, it connects a specific row and column, allowing us to identify the key based on the row and column numbers.
Here’s how the keys are arranged:
Circuit Diagram
4 pull-down resistors are connected to each of the columns of the matrix keyboard, so that G6 ~ G9 get a stable low level when the keys are not pressed.
The rows of the keyboard (G2 ~ G5) are programmed to go high; if one of G6 ~ G9 is read high, then we know which key is pressed.
For example, if G6 is read high, then numeric key 1 is pressed; this is because the control pins of numeric key 1 are G2 and G6, when numeric key 1 is pressed, G2 and G6 will be connected together and G6 is also high.
Writing the Code
Let’s write a MicroPython program to read which key is pressed.
Open the
4.2_4x4_keypad.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
# Define the characters on the keypad
keys = [
['1', '2', '3', 'A'],
['4', '5', '6', 'B'],
['7', '8', '9', 'C'],
['*', '0', '#', 'D']
# Define the GPIO pins connected to the rows and columns
row_pins = [2, 3, 4, 5] # GP2-GP5
col_pins = [6, 7, 8, 9] # GP6-GP9
# Initialize row pins as outputs
rows = [machine.Pin(pin_num, machine.Pin.OUT) for pin_num in row_pins]
# Initialize column pins as inputs with pull-down resistors
cols = [machine.Pin(pin_num, machine.Pin.IN, machine.Pin.PULL_DOWN) for pin_num in col_pins]
def scan_keypad():
for i, row in enumerate(rows):
# Set all rows low
for r in rows:
r.value(0)
# Set the current row high
row.value(1)
# Check columns for a high signal
for j, col in enumerate(cols):
if col.value() == 1:
# Key detected
return keys[i][j]
return None
last_key = None
key = scan_keypad()
if key != last_key:
if key is not None:
print("Key pressed:", key)
last_key = key
time.sleep(0.1)
Understanding the Code
Define Keypad Characters
This 2D list represents the keypad layout, matching the physical arrangement.
keys = [ ['1', '2', '3', 'A'], ['4', '5', '6', 'B'], ['7', '8', '9', 'C'], ['*', '0', '#', 'D'] ]
Initialize Pins:
row_pins = [2, 3, 4, 5] # GPIO pins for rows col_pins = [6, 7, 8, 9] # GPIO pins for columns # Initialize rows as outputs rows = [machine.Pin(pin_num, machine.Pin.OUT) for pin_num in row_pins] # Initialize columns as inputs with pull-down resistors cols = [machine.Pin(pin_num, machine.Pin.IN, machine.Pin.PULL_DOWN) for pin_num in col_pins]
Define the Keypad Scanning Function:
The function scans each row by setting it high and checking if any column reads high, indicating a key press at that row and column.
def scan_keypad(): for i, row in enumerate(rows): # Set all rows low for r in rows: r.value(0) # Set the current row high row.value(1) # Check columns for a key press for j, col in enumerate(cols): if col.value() == 1: # Key is pressed return keys[i][j] return None
Main Loop to Detect Key Presses
The loop continuously scans for key presses.
It checks if the current key is different from the last key to prevent multiple detections of the same key press (debouncing).
Prints the key when a new key press is detected.
last_key = None while True: key = scan_keypad() if key != last_key: if key is not None: print("Key pressed:", key) last_key = key time.sleep(0.1)
After running the program, Press different keys on the keypad. The corresponding key character should be printed in the Thonny Shell.
Troubleshooting Tips
No Output When Pressing Keys:
Ensure all connections are correct.
Verify that the pull-down resistors are properly connected between the column pins and GND.
Incorrect Key Detected:
Double-check the keys array to ensure it matches your keypad’s layout.
Make sure the row and column pins in the code match the physical connections.
Multiple Keys Detected:
Mechanical keypads may sometimes detect ghosting (false key presses) if multiple keys are pressed simultaneously. For this basic setup, avoid pressing multiple keys at once.
Experimenting Further
Implement a Simple Password Lock: Store a sequence of key presses and compare them to a preset password.
Add an LCD Display: Display the keys pressed on an LCD screen.
Create a Calculator: Use the keypad to input numbers and perform basic arithmetic operations.
Conclusion
In this lesson, you’ve learned how to connect and program a 4x4 matrix keypad with the Raspberry Pi Pico 2. You can now detect key presses and use them to interact with your projects, opening up possibilities for creating interactive devices like locks, calculators, and control interfaces.
