2.12 Feel the Light
In this lesson, we’ll learn how to use a photoresistor (also known as a light-dependent resistor or LDR) with the Raspberry Pi Pico 2 to measure light intensity. A photoresistor changes its resistance based on the amount of light it receives: the brighter the light, the lower the resistance. This makes it ideal for detecting changes in ambient light.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(10KΩ) |
Circuit Diagram
In this circuit, a 10K resistor and a photoresistor are connected in series, forming a voltage divider. GP28 reads the voltage across the photoresistor, while the 10K resistor provides protection by limiting current.
Bright Light: The photoresistor’s resistance decreases, lowering its voltage and the GP28 reading. In strong light, its resistance approaches zero, and GP28 reads close to 0. At this time, the 10K resistor plays a protective role, so that 3.3V and GND are not connected together, resulting in a short circuit.
Darkness: The photoresistor’s resistance increases, raising its voltage and the GP28 value. In complete darkness, its resistance is nearly infinite (the 10K resistor is negligible), and GP28 reads close to 65535.
The calculation formula is shown below.
Digital Value = (Analog Voltage/3.3V) * 65535
Wiring Diagram
Writing the Code
We’ll write a MicroPython program to read the analog value from the photoresistor and display it.
Open the
2.12_feel_the_light.pyfile under the pathnewton-lab-kit/micropythonor copy the code below into Thonny. Then click “Run Current Script” or press F5 to run it.Ensure that the “MicroPython (Raspberry Pi Pico).COMxx” interpreter is selected in the bottom right corner of Thonny.
For detailed instructions, refer to Open and Run Code Directly.
import machine
import utime
# Initialize ADC on GP28
photoresistor = machine.ADC(28)
# Read the analog value (0-65535)
light_value = photoresistor.read_u16()
print("Light value:", light_value)
utime.sleep(0.5)
When the code is running, observe the values printed in the console.
Cover the photoresistor with your hand to simulate darkness; the value should increase.
Shine a light or a flashlight on the photoresistor; the value should decrease.
Understanding the Code
Import Modules:
machine: Provides access to hardware-related functions.utime: Allows us to use time-related functions like sleep.
Initialize the ADC Pin:
photoresistor = machine.ADC(28): Sets up GP28 as an analog input to read voltage levels.
Main Loop:
while True: Starts an infinite loop.light_value = photoresistor.read_u16(): Reads the analog value from the photoresistor. The value ranges from 0 (0V) to 65535 (3.3V).print("Light value:", light_value): Outputs the light value to the console.utime.sleep(0.5): Pauses the loop for 0.5 seconds before the next reading.
Experimenting Further
Calibrating the Readings:
Map the analog values to a percentage or a more meaningful scale.
import machine import utime photoresistor = machine.ADC(28) while True: light_value = photoresistor.read_u16() light_percentage = (light_value / 65535) * 100 print("Light level: {:.2f}%".format(light_percentage)) utime.sleep(0.5)
Control an LED Based on Light Intensity:
Use the light sensor to turn an LED on in the dark and off in bright light.
import machine import utime photoresistor = machine.ADC(28) led = machine.Pin(15, machine.Pin.OUT) while True: light_value = photoresistor.read_u16() if light_value > 50000: led.value(1) # Turn on LED in darkness else: led.value(0) # Turn off LED in bright light utime.sleep(0.5)
Create a Light-Activated Alarm or Notification: Trigger an action when light levels change significantly.
Conclusion
By using a photoresistor with the Raspberry Pi Pico 2, you’ve learned how to read analog inputs and respond to changes in environmental light. This knowledge can be applied to various projects, such as automatic lighting systems, light-following robots, or security devices that react to changes in lighting.
