7.1 Creating a Light Theremin
In this exciting project, we’ll build a Light Theremin using a Raspberry Pi Pico 2, a photoresistor, and a passive buzzer. A theremin is a unique musical instrument that is played without physical contact, producing different tones based on the position of the player’s hands. While we can’t replicate a traditional theremin entirely, we can simulate its functionality by using light intensity to control sound frequency.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(S8050) |
7 |
3(1KΩ, 220Ω, 10KΩ) |
8 |
Passive Buzzer |
9 |
Understanding the Concept
Photoresistor: A sensor that changes its resistance based on light intensity. More light decreases resistance, less light increases it.
Passive Buzzer: Requires an external signal to produce sound. We can control its frequency using Pulse Width Modulation (PWM).
Transistor (S8050): Used to amplify the current, allowing the buzzer to be driven effectively by the Pico.
By reading the values from the photoresistor, we can map light intensity to sound frequency. This means moving your hand over the photoresistor will change the pitch of the sound produced by the buzzer, similar to playing a theremin.
Circuit Diagram
Before starting the project, wave your hand up and down over the photoresistor to calibrate the range of light intensity. The LED connected in GP16 is used to indicate the debugging time, and the LED is lit to indicate the start of debugging and off to indicate the end of debugging.
When GP15 outputs high level, S8050 (NPN transistor) conducts and the passive buzzer starts to sound.
When the light is stronger, GP28’s value is smaller; vice versa, it is larger when the light is weaker. By programming the value of the photoresistor to affect the frequency of the passive buzzer, a photosensitive device can be simulated.
Wiring Diagram
Writing the Code
Let’s write a MicroPython program that reads the light intensity from the photoresistor, maps it to a frequency, and plays that frequency on the buzzer.
Open the
7.1_light_theremin.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize components
led = machine.Pin(16, machine.Pin.OUT) # LED on GP16
photoresistor = machine.ADC(28) # Photoresistor connected to ADC0 (GP28)
buzzer = machine.PWM(machine.Pin(15)) # Buzzer connected to GP15
# Variables for calibration
light_low = 65535
light_high = 0
# Function to map values from one range to another
# Ensure in_min != in_max to avoid division by zero
if in_max - in_min == 0:
return out_min
return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
# Function to play a tone on the buzzer
def play_tone(pin, frequency):
if frequency <= 0:
pin.duty_u16(0)
pin.freq(frequency)
pin.duty_u16(32768) # 50% duty cycle
# Calibration process
def calibrate():
global light_low, light_high
print("Calibrating... Move your hand over the sensor.")
led.value(1) # Turn on LED to indicate calibration
start_time = utime.ticks_ms()
while utime.ticks_diff(utime.ticks_ms(), start_time) < 5000: # 5 seconds calibration
light_value = photoresistor.read_u16()
if light_value > light_high:
light_high = light_value
if light_value < light_low:
light_low = light_value
utime.sleep_ms(10)
led.value(0) # Turn off LED after calibration
print("Calibration complete.")
print("Light Low:", light_low)
print("Light High:", light_high)
# Main function
def main():
calibrate()
# Map the light value to a frequency range (e.g., 200 Hz to 2000 Hz)
frequency = interval_mapping(light_value, light_low, light_high, 200, 2000)
play_tone(buzzer, frequency)
utime.sleep_ms(20)
buzzer.deinit()
print("Program stopped.")
# Run the main function
if __name__ == "__main__":
main()
When the code is running, the LED will light up, indicating the calibration period.
Calibration:
Move your hand over the photoresistor during the 5-second calibration.
This helps the program understand the range of light conditions.
Playing the Theremin:
After calibration, the LED turns off.
Move your hand over the photoresistor.
The buzzer will emit tones that change pitch based on the light intensity.
Experiment with different hand positions and movements to create sounds.
Understanding the Code
Initialization:
LED Indicator: Used to signal when calibration is happening.
Photoresistor: Reads analog values corresponding to light intensity.
Buzzer: Controlled using PWM to generate tones at different frequencies.
Calibration Function (
calibrate()):Runs for 5 seconds, during which it records the minimum and maximum light values.
Instructs the user to move their hand over the sensor to capture the range.
Uses the LED as a visual indicator.
# Calibration process def calibrate(): global light_low, light_high print("Calibrating... Move your hand over the sensor.") led.value(1) # Turn on LED to indicate calibration start_time = utime.ticks_ms() while utime.ticks_diff(utime.ticks_ms(), start_time) < 5000: # 5 seconds calibration light_value = photoresistor.read_u16() if light_value > light_high: light_high = light_value if light_value < light_low: light_low = light_value utime.sleep_ms(10) led.value(0) # Turn off LED after calibration print("Calibration complete.") print("Light Low:", light_low) print("Light High:", light_high)
Interval Mapping Function (
interval_mapping()):Maps the light sensor values to a frequency range suitable for the buzzer.
Prevents division by zero errors.
# Function to map values from one range to another def interval_mapping(x, in_min, in_max, out_min, out_max): # Ensure in_min != in_max to avoid division by zero if in_max - in_min == 0: return out_min return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
Playing Tones (
play_tone()):Sets the frequency of the buzzer using PWM.
If the frequency is zero or negative, turns off the buzzer.
# Function to play a tone on the buzzer def play_tone(pin, frequency): if frequency <= 0: pin.duty_u16(0) else: pin.freq(frequency) pin.duty_u16(32768) # 50% duty cycle
Main Loop:
Continuously reads the light value from the photoresistor.
Maps this value to a frequency.
Plays the tone corresponding to the frequency.
Includes error handling to clean up on exit.
# Main function def main(): calibrate() try: while True: light_value = photoresistor.read_u16() # Map the light value to a frequency range (e.g., 200 Hz to 2000 Hz) frequency = interval_mapping(light_value, light_low, light_high, 200, 2000) play_tone(buzzer, frequency) utime.sleep_ms(20) except KeyboardInterrupt: buzzer.deinit() print("Program stopped.")
Experimenting Further
Adjust Frequency Range:
Modify the values in
interval_mapping()to change the pitch range. Example: Change 200, 2000 to 100, 5000 for a wider range.Visual Feedback:
Use additional LEDs to provide visual cues corresponding to the pitch.
Add a Second Sensor:
Introduce another photoresistor to control volume or another parameter.
Create a Musical Instrument:
Combine with other sensors or inputs to build a more complex instrument.
Understanding Limitations
Ambient Light:
Changes in ambient light can affect performance. Ensure consistent lighting or recalibrate as needed.
Sensor Sensitivity:
The photoresistor may not respond quickly to rapid hand movements.
Sound Quality:
Passive buzzers have limited sound quality. For better audio, consider using an active speaker with a DAC output.
Conclusion
You’ve successfully created a Light Theremin using the Raspberry Pi Pico 2! This project demonstrates how sensors and actuators can be combined to create interactive and fun experiments. Keep exploring and modifying the project to enhance your understanding and creativity.
