6.5 Interfacing RFID
In this lesson, we’ll explore how to use Radio Frequency Identification (RFID) technology with the Raspberry Pi Pico 2. RFID allows for wireless communication between a reader and tags, which can be used for identification, authentication, and data storage.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Understanding RFID
RFID technology uses electromagnetic fields to automatically identify and track tags attached to objects. The tags contain electronically stored information, which can be read from a distance without direct line-of-sight.
RFID Reader (MFRC522): A device that emits radio waves to communicate with RFID tags.
RFID Tag: A small object, such as a card or key fob, that contains a microchip and antenna. It can be passive (no battery) or active (battery-powered).
Circuit Diagram
Wiring Diagram
Writing the Code
We’ll write two separate scripts:
Here you need to use the libraries in mfrc522 folder, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
Writing Data to an RFID Tag:
SimpleMFRC522class from themfrc522library simplifies interactions with the RFID reader.The reader is initialized with the specified SPI pins.
Prompts the user to input data to write.
Instructs the user to place the tag near the reader.
Writes the data to the tag using
reader.write(data).
Open the
6.5_rfid_write.pyfile fromnewton-lab-kit/micropythonor copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.from mfrc522 import SimpleMFRC522 from machine import Pin, SPI # Initialize the RFID reader reader = SimpleMFRC522(spi_id=0, sck=18, mosi=19, miso=16, cs=17, rst=9) def write_to_tag(): try: data = input("Enter data to write to the tag: ") print("Place your tag near the reader...") reader.write(data) print("Data written successfully!") finally: pass # Cleanup actions if necessary write_to_tag()
After running, the following occurs:
The program displays:
Enter data to write to the tag:"
You input the text you want to write to the RFID tag and press Enter.
The program then shows:
You place the RFID tag near the reader module.
After successfully writing the data, it displays:
Reading Data from an RFID Tag:
Reads the tag’s ID and stored text using
reader.read().Prints out the tag’s ID and the data read from the tag.
Open the
6.5_rfid_read.pyfile fromnewton-lab-kit/micropythonor copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.from mfrc522 import SimpleMFRC522 from machine import Pin, SPI # Initialize the RFID reader reader = SimpleMFRC522(spi_id=0, sck=18, mosi=19, miso=16, cs=17, rst=9) def read_from_tag(): try: print("Place your tag near the reader...") id, text = reader.read() print("Tag ID: {}".format(id)) print("Data: {}".format(text.strip())) finally: pass # Cleanup actions if necessary read_from_tag()
After running, the program prints the message “Place your tag near the reader…”. You need to place an RFID tag near the MFRC522 reader module, then program prints the retrieved information to the console. The output will look something like:
Tag ID: 1234567890 Data: Your stored message
Understanding the Code
RFID Communication: The MFRC522 module communicates with the RFID tag using radio waves. When the tag is within range, the reader can read or write data to the tag’s memory.
SPI Interface: The module communicates with the Pico via the SPI protocol, allowing for fast data transfer.
Data Storage: RFID tags have limited storage capacity, suitable for storing small amounts of data like IDs or short text.
Applications
Access Control Systems: Use RFID tags as keys to unlock doors or devices.
Inventory Management: Track items in a warehouse or store by tagging them with RFID tags.
Attendance Systems: Record attendance by scanning RFID tags assigned to individuals.
Experimenting Further
Multiple Tags: Try writing different data to multiple tags and reading them back.
Security Measures: Implement basic authentication to prevent unauthorized access.
Data Formatting: Store structured data, such as JSON or CSV, for more complex applications.
Conclusion
In this lesson, you’ve learned how to interface an RFID reader with the Raspberry Pi Pico 2 to read and write data to RFID tags. This technology opens up possibilities for numerous applications in identification, tracking, and automation.
