3.3 Controlling an RGB LED Strip
In this lesson, we’ll learn how to control an RGB LED strip (specifically the WS2812 type) using the Raspberry Pi Pico 2 and MicroPython.
The WS2812 is a smart LED that integrates a control circuit and an RGB chip into a 5050-sized LED package. Each LED has its own built-in controller, which allows us to control each LED individually using a single data line. This means we can change the color and brightness of each LED on the strip independently.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Circuit Diagram
Wiring Diagram
Be cautious with the current draw. While the Pico’s VBUS pin can supply power for a small number of LEDs (like 8), using more LEDs may require an external power supply to prevent overloading the Pico.
Writing the Code
Open the
3.3_rgb_led_strip.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
Here you need to use the library called
ws2812.py, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
import machine
from ws2812 import WS2812
# Initialize the LED strip
led_strip = WS2812(machine.Pin(0), 8) # Using GP0, 8 LEDs
# Set colors for each LED
led_strip[0] = [255, 0, 0] # Red
led_strip[1] = [0, 255, 0] # Green
led_strip[2] = [0, 0, 255] # Blue
led_strip[3] = [255, 255, 0] # Yellow
led_strip[4] = [0, 255, 255] # Cyan
led_strip[5] = [255, 0, 255] # Magenta
led_strip[6] = [255, 255, 255] # White
led_strip[7] = [128, 128, 128] # Gray
# Update the LED strip to show the colors
led_strip.write()
When this code is running, the WS2812 LED strip connected to pin GP0 with 8 LEDs will display the following colors:
LED 0: Red (255, 0, 0)
LED 1: Green (0, 255, 0)
LED 2: Blue (0, 0, 255)
LED 3: Yellow (255, 255, 0)
LED 4: Cyan (0, 255, 255)
LED 5: Magenta (255, 0, 255)
LED 6: White (255, 255, 255)
LED 7: Gray (128, 128, 128)
Understanding the Code
Import Libraries:
machine: Provides access to hardware-related functions.WS2812: The library to control the WS2812 LED strip.
Initialize the LED Strip:
led_strip = WS2812(machine.Pin(0), 8): Initializes the LED strip connected to pin GP0 with 8 LEDs.
Set Colors:
led_strip[0] = [255, 0, 0]: Assigns a color to each LED using RGB values (Red, Green, Blue), ranging from 0 to 255.
Update the LED Strip:
led_strip.write(): Sends the color data to the LED strip to display the colors.
Let’s Make a Flowing Rainbow Effect!
Now, we’ll create a colorful flowing light effect by randomly generating colors and shifting them along the strip.
import machine
import utime
import urandom
# Number of LEDs in the strip
NUM_LEDS = 8
# Initialize the LED strip with 8 LEDs
led_strip = WS2812(machine.Pin(0), NUM_LEDS)
def flowing_light():
# Shift colors along the strip
for i in range(NUM_LEDS - 1, 0, -1):
led_strip[i] = led_strip[i - 1]
# Generate a random color for the first LED
led_strip[0] = [urandom.getrandbits(8), urandom.getrandbits(8), urandom.getrandbits(8)]
# Update the strip
led_strip.write()
# Small delay for smooth animation
utime.sleep_ms(100)
# Main loop
flowing_light()
When the code runs, the LED strip displays a flowing dynamic effect with random colors, where a new random color is introduced at the beginning and shifts towards the end with each cycle.
Random Color Generation: Generates a random RGB color where each component ranges from 0 to 255.
Shifting Colors: Moves each LED’s color to the next position, creating a flowing effect.
for i in range(NUM_LEDS - 1, 0, -1): led_strip[i] = led_strip[i - 1]
Infinite Loop: Continuously updates the LED strip to keep the animation running.
while True: flowing_light()
Experimenting Further
Adjusting Speed: Modify
utime.sleep_ms(100)to make the flowing effect faster or slower.More LEDs: If you have a longer strip, change the number in
WS2812(machine.Pin(0), number_of_leds)accordingly.Custom Animations: Experiment with different patterns and color combinations to create your own animations.
Conclusion
You’ve successfully learned how to control an RGB LED strip using the Raspberry Pi Pico 2 and MicroPython! This opens up a world of possibilities for creating stunning light displays, mood lighting, or even interactive art projects.
