6.3 Read from the MPU-6050
In this lesson, we’ll explore how to interface the MPU-6050 6-axis motion tracking sensor with the Raspberry Pi Pico 2. The MPU-6050 combines a 3-axis gyroscope and a 3-axis accelerometer, providing raw sensor data over the I2C communication protocol.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Understanding the MPU-6050 Sensor
The MPU-6050 sensor is widely used in projects that require motion tracking and orientation detection, such as drones, robotics, and gaming devices.
Accelerometer: Measures acceleration forces along the X, Y, and Z axes. This includes gravitational acceleration, allowing you to determine the tilt or orientation of the sensor.
Gyroscope: Measures rotational velocity around the X, Y, and Z axes, providing information about how fast the sensor is spinning.
Circuit Diagram
Wiring Diagram
Writing the Code
Let’s write a MicroPython script to read accelerometer and gyroscope data from the MPU-6050 sensor.
Open the
6.3_6axis_motion_tracking.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
Here you need to use the
imu.pyandvector3d.py, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
from machine import I2C, Pin
import utime
from imu import MPU6050
# Initialize I2C interface (I2C0) with SDA on GP4 and SCL on GP5
i2c = I2C(0, sda=Pin(4), scl=Pin(5), freq=400000)
# Initialize the MPU-6050 sensor
mpu = MPU6050(i2c)
def read_accelerometer():
"""Reads accelerometer data and returns it as a tuple (x, y, z)."""
accel = mpu.accel
return accel.x, accel.y, accel.z
def read_gyroscope():
"""Reads gyroscope data and returns it as a tuple (x, y, z)."""
gyro = mpu.gyro
return gyro.x, gyro.y, gyro.z
def main():
"""Main loop to read and print sensor data."""
# Read accelerometer data
ax, ay, az = read_accelerometer()
print("Accelerometer (g) - X: {:.3f}, Y: {:.3f}, Z: {:.3f}".format(ax, ay, az))
# Pause for readability
utime.sleep(0.5)
# Read gyroscope data
gx, gy, gz = read_gyroscope()
print("Gyroscope (°/s) - X: {:.3f}, Y: {:.3f}, Z: {:.3f}".format(gx, gy, gz))
# Pause before the next set of readings
utime.sleep(0.5)
# Run the main function
if __name__ == "__main__":
main()
The script prints accelerometer and gyroscope readings alternately every 0.5 seconds.
Accelerometer Output:
Accelerometer (g) - X: 0.000, Y: 0.000, Z: 1.000
At rest, you should see values close to 0 g on X and Y axes, and approximately 1 g on the Z-axis due to gravity.
Gyroscope Output:
Gyroscope (°/s) - X: 0.000, Y: 0.000, Z: 0.000
When stationary, the gyroscope readings should be close to 0 °/s on all axes. Rotating the sensor will change these values, reflecting the angular velocity.
Understanding the Code
Imports and Setup:
machine.I2C and machine.Pin: For hardware interface.utime: For timing functions.MPU6050: The sensor class from the imu.py library.
I2C Initialization:
Sets up I2C bus 0 with SDA on GP4 and SCL on GP5. The frequency is set to 400 kHz for fast communication.
Sensor Initialization:
Creates an instance of the MPU-6050 sensor using the I2C interface.
mpu = MPU6050(i2c)
Reading Accelerometer Data:
Accesses the accelerometer data and returns the X, Y, Z values.
def read_accelerometer(): accel = mpu.accel return accel.x, accel.y, accel.z
Reading Gyroscope Data:
Accesses the gyroscope data and returns the X, Y, Z values.
def read_gyroscope(): gyro = mpu.gyro return gyro.x, gyro.y, gyro.z
Main Loop:
Reads and prints accelerometer data.
Waits for 0.5 seconds.
Reads and prints gyroscope data.
Waits for another 0.5 seconds before repeating.
def main(): while True: # Read and print accelerometer data ax, ay, az = read_accelerometer() print("Accelerometer (g) - X: {:.3f}, Y: {:.3f}, Z: {:.3f}".format(ax, ay, az)) utime.sleep(0.5) # Read and print gyroscope data gx, gy, gz = read_gyroscope() print("Gyroscope (°/s) - X: {:.3f}, Y: {:.3f}, Z: {:.3f}".format(gx, gy, gz)) utime.sleep(0.5)
Program Entry Point:
Ensures that
main()is called when the script is executed directly.if __name__ == "__main__": main()
Experimenting Further
Focus on One Sensor: To concentrate on either accelerometer or gyroscope data, you can comment out the print statements for the other sensor.
Data Visualization: Use tools or software to plot the sensor data in real-time for better visualization.
Calculating Orientation: Implement algorithms to calculate pitch and roll from the accelerometer data.
Motion Detection: Create a program that performs actions when certain motion thresholds are exceeded.
Understanding Sensor Data
Accelerometer:
Measures acceleration forces in g (gravitational force).
Useful for detecting orientation, tilt, and linear motion.
Gyroscope:
Measures rotational velocity in degrees per second (°/s).
Useful for detecting rotation and angular motion.
Troubleshooting Tips
No Output or Errors:
Verify the wiring connections, especially SDA and SCL lines.
Ensure that the sensor is powered correctly.
Static Readings:
If the readings don’t change when moving the sensor, check for loose connections.
Make sure the correct I2C address is being used.
Inconsistent Data:
Environmental vibrations can affect sensor readings.
Place the sensor on a stable surface when testing.
Conclusion
In this lesson, you’ve learned how to interface the MPU-6050 accelerometer and gyroscope sensor with the Raspberry Pi Pico 2. By reading the raw sensor data, you can explore a wide range of applications involving motion detection, orientation tracking, and more.
