Power Supply Module
A 3.3V and 5V breadboard power module with series diode and reverse polarity protection. The module can accept 6.5V to 12V input, and can generate 3.3V and +5V. For experimenters who must test/prototype electronic circuits on breadboards or perforated/veroboards, this is a must-have power supply module.
- Features
Plug directly to MB102 Standard breadboard.
Input voltage: 6.5-12 V (DC) or 5V USB power supply.
Output voltage: 3.3V and 5V can switch over.
Maximum output current: <700 mA.
External Input voltage ON/OFF switch.
Independent control of upper and Lower Bread Board Power Rails. Can switch over to 0V, 3.3V, 5V using jumpers on any rail.
On-board two groups of 3.3V, 5V DC output plug pin, convenient external lead use.
USB device connector onboard for power output to external device.
Size: 5.3cm x 3.5cm.
Example
3.5 Controlling a Small Fan (DC Motor) (For MicroPython User)
3.5 Controlling a Small Fan (DC Motor) (For Arduino User)
2.16 Control Another Circuit with a Relay (For MicroPython User)
2.16 Control Another Circuit with a Relay (For Arduino User)
3.6 Controlling a Water Pump (For MicroPython User)
3.6 Controlling a Water Pump (For Arduino User)
