7.2 Building a Room Temperature Meter
In this project, we’ll create a Room Temperature Meter using a thermistor and an I2C LCD1602 display. This simple yet practical device will measure the ambient temperature and display it on the LCD screen, providing real-time temperature readings of your environment.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(10KΩ) |
7 |
Understanding the Components
Thermistor: A type of resistor whose resistance varies significantly with temperature. We’ll use a Negative Temperature Coefficient (NTC) thermistor, meaning its resistance decreases as temperature increases.
Voltage Divider: By combining the thermistor with a fixed resistor, we create a voltage divider circuit, allowing us to measure changes in voltage corresponding to temperature changes.
I2C LCD1602 Display: A 16x2 character LCD display with an I2C interface, which simplifies wiring and code by using only two data lines (SDA and SCL).
Circuit Diagram
Wiring Diagram
Writing the Code
We’ll write a MicroPython program that reads the temperature from the thermistor and displays it on the LCD.
Open the
7.2_room_temperature_meter.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
Here you need to use the library called
lcd1602.py, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
from lcd1602 import LCD
from machine import I2C, Pin, ADC
import utime
import math
# Initialize the thermistor (ADC on pin 28)
thermistor = ADC(28) # Analog input from the thermistor
# Initialize I2C communication for the LCD1602 display
i2c = I2C(1, scl=Pin(7), sda=Pin(6), freq=400000)
# Create an LCD object for controlling the LCD1602 display
lcd = LCD(i2c)
# Constants for the Steinhart-Hart equation
BETA = 3950 # Beta coefficient of the thermistor
R0 = 10000 # Resistance at 25 degrees Celsius
T0 = 298.15 # Reference temperature in Kelvin (25°C)
def read_temperature():
# Read raw ADC value from the thermistor
adc_value = thermistor.read_u16()
# Convert the raw ADC value to voltage
voltage = adc_value * 3.3 / 65535
# Calculate the resistance of the thermistor
Rt = (voltage * R0) / (3.3 - voltage)
# Apply the Steinhart-Hart equation to calculate temperature in Kelvin
tempK = 1 / ((1 / T0) + (1 / BETA) * math.log(Rt / R0))
# Convert temperature from Kelvin to Celsius
tempC = tempK - 273.15
return tempC
def main():
temperature = read_temperature()
# Format the temperature to two decimal places
temp_str = "{:.2f} C".format(temperature)
# Display the temperature on the LCD
lcd.clear()
lcd.write(0, 0, "Room Temp:")
lcd.write(4, 1, temp_str)
# Optional: Print the temperature to the console
print("Temperature:", temp_str)
utime.sleep(1)
if __name__ == "__main__":
main()
Once the code is running, the LCD should display the current room temperature in Celsius. If the LCD is blank, adjust the contrast using the potentiometer on the back. The console in Thonny will also print the temperature readings.
Understanding the Code
Imports and Initialization:
lcd1602.LCD: For controlling the LCD display.machine.ADC: To read analog values from the thermistor.math: For logarithmic calculations needed in the temperature conversion.
Variables:
BETA: The beta coefficient specific to your thermistor (commonly 3950).
R0: The resistance of the thermistor at the reference temperature (usually 10kΩ at 25°C).
T0: The reference temperature in Kelvin (25°C + 273.15).
BETA = 3950 # Beta coefficient of the thermistor R0 = 10000 # Resistance at 25 degrees Celsius T0 = 298.15 # Reference temperature in Kelvin (25°C)
Reading Temperature (
read_temperature Function):ADC Reading: Captures the analog value from the thermistor.
Voltage Calculation: Converts the ADC value to an actual voltage.
Resistance Calculation (Rt): Calculates the thermistor’s resistance using the voltage divider formula.
Steinhart-Hart Equation: A mathematical model that relates the resistance of a thermistor to its temperature.
Conversion to Celsius: Adjusts the temperature from Kelvin to Celsius.
def read_temperature(): # Read raw ADC value from the thermistor adc_value = thermistor.read_u16() # Convert the raw ADC value to voltage voltage = adc_value * 3.3 / 65535 # Calculate the resistance of the thermistor Rt = (voltage * R0) / (3.3 - voltage) # Apply the Steinhart-Hart equation to calculate temperature in Kelvin tempK = 1 / ((1 / T0) + (1 / BETA) * math.log(Rt / R0)) # Convert temperature from Kelvin to Celsius tempC = tempK - 273.15 return tempC
Main Loop (main Function):
Continuously reads the temperature.
Formats and displays the temperature on the LCD.
Prints the temperature to the console (optional for debugging).
Waits for 1 second before repeating.
def main(): while True: temperature = read_temperature() # Format the temperature to two decimal places temp_str = "{:.2f} C".format(temperature) # Display the temperature on the LCD lcd.clear() lcd.write(0, 0, "Room Temp:") lcd.write(4, 1, temp_str) # Optional: Print the temperature to the console print("Temperature:", temp_str) utime.sleep(1)
Troubleshooting
LCD Not Displaying Text:
Verify SDA and SCL connections (GP6 and GP7).
Check that the LCD is powered correctly.
Adjust the contrast potentiometer on the LCD module.
Incorrect Temperature Readings:
Ensure the thermistor and resistor are connected properly.
Double-check the resistor values.
Confirm that the BETA value matches your thermistor’s specifications.
Program Errors:
Make sure all necessary libraries are correctly uploaded to the Pico.
Check for typos or indentation errors in the code.
Experimenting Further
Display Temperature in Fahrenheit:
Modify the read_temperature function to convert Celsius to Fahrenheit:
tempF = (tempC * 9 / 5) + 32.Add Humidity Measurement:
Integrate a DHT11 or DHT22 sensor to display humidity alongside temperature.
Data Logging:
Store temperature readings over time in a file on the Pico. Plot the data using a computer for analysis.
Visual Alerts:
Add LEDs or a buzzer to alert when the temperature exceeds certain thresholds.
Understanding the Science
Thermistors and Temperature Measurement:
Thermistors are sensitive to temperature changes, making them ideal for precise measurements.
The voltage divider circuit converts resistance changes into voltage changes that can be read by the Pico’s ADC.
Provides a more accurate temperature calculation than a simple linear approximation.
Essential for applications requiring precise temperature readings.
Conclusion
Congratulations! You’ve built a functional Room Temperature Meter using the Raspberry Pi Pico 2. This project not only demonstrates how to interface analog sensors and I2C devices but also provides practical experience with temperature measurement and display technologies.
Feel free to enhance and customize your temperature meter by adding new features or integrating other sensors. This project serves as a solid foundation for exploring environmental monitoring and control systems.
