7.5 Creating a “10 Second” Game
In this engaging project, we’ll build a fun game called “10 Second” using the Raspberry Pi Pico 2, a tilt switch, and a 4-digit 7-segment display. The objective of the game is to shake a magic wand (simulated using the tilt switch attached to a stick) to start a timer, and then shake it again to stop the timer as close to 10.00 seconds as possible. It’s a great way to test your timing skills and challenge friends to see who is the true time wizard!
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
5(4-220Ω, 1-10KΩ) |
7 |
8 |
Understanding the Components
Tilt Switch: A sensor that detects orientation or movement. When tilted, it completes or breaks a circuit, allowing us to detect shaking or movement.
4-Digit 7-Segment Display: Displays numbers from 0000 to 9999. We’ll use shift registers to control the display using fewer GPIO pins.
74HC595 Shift Register: 8-bit serial-in, parallel-out shift register that allow us to control multiple outputs with just a few GPIO pins.
Circuit Diagram
This circuit is based on 5.3 Creating a Time Counter with a 4-Digit 7-Segment Display with the addition of a tilt switch.
GP16 is high when the tilt switch is upright; low when tilted.
Wiring Diagram
Writing the Code
We’ll write a MicroPython script that:
Detects shaking using the tilt switch.
Starts and stops a timer based on the tilt switch.
Displays the elapsed time on the 4-digit 7-segment display.
Uses multiplexing and shift registers to control the display.
from machine import Pin
import utime
# Initialize the control pins for 74HC595
SDI = machine.Pin(18, machine.Pin.OUT) # Serial Data Input (DS)
RCLK = machine.Pin(19, machine.Pin.OUT) # Register Clock (STCP)
SRCLK = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock (SHCP)
# 7-segment display segment codes for digits 0-9 (common cathode)
SEGMENT_CODES = [0x3F, # 0
0x06, # 1
0x5B, # 2
0x4F, # 3
0x66, # 4
0x6D, # 5
0x7D, # 6
0x07, # 7
0x7F, # 8
0x6F] # 9
# Initialize digit select pins (common cathodes)
digit_pins = [
machine.Pin(10, machine.Pin.OUT), # Digit 1
machine.Pin(11, machine.Pin.OUT), # Digit 2
machine.Pin(12, machine.Pin.OUT), # Digit 3
machine.Pin(13, machine.Pin.OUT) # Digit 4
# Initialize the tilt switch
tilt_switch = Pin(16, Pin.IN, Pin.PULL_DOWN)
# Variables for timing
start_time = 0
elapsed_time = 0
counting = False
# Function to shift out data to the shift registers
def shift_out(data):
RCLK.low()
for bit in range(7, -1, -1):
SRCLK.low()
bit_val = (data >> bit) & 0x01
SDI.value(bit_val)
SRCLK.high()
RCLK.high()
# Function to display a digit at a specific position
def display_digit(position, digit):
# Turn off all digits
for dp in digit_pins:
dp.high()
# Send segment data
shift_out(SEGMENT_CODES[digit])
# Activate the selected digit (common cathode is active low)
digit_pins[position].low()
# Small delay to allow the digit to be visible
utime.sleep_ms(5)
# Turn off the digit
digit_pins[position].high()
# Function to display the elapsed time
def display_time(time_ms):
# Convert time to centiseconds (hundredths of a second)
centiseconds = int(time_ms / 10)
# Limit to 9999 to fit the display
if centiseconds > 9999:
centiseconds = 9999
# Extract individual digits
digits = [
(centiseconds // 1000) % 10,
(centiseconds // 100) % 10,
(centiseconds // 10) % 10,
centiseconds % 10
# Display each digit rapidly
for i in range(4):
display_digit(i, digits[i])
# Interrupt handler for the tilt switch
def tilt_handler(pin):
global counting, start_time, elapsed_time
if not counting:
# Start counting
counting = True
start_time = utime.ticks_ms()
# Stop counting
counting = False
elapsed_time = utime.ticks_diff(utime.ticks_ms(), start_time)
# Set up tilt switch interrupt
tilt_switch.irq(trigger=Pin.IRQ_RISING, handler=tilt_handler)
# Main loop
if counting:
# Calculate elapsed time
current_time = utime.ticks_diff(utime.ticks_ms(), start_time)
display_time(current_time)
# Display the final time
display_time(elapsed_time)
When the code is running, the 4-digit 7-segment display should initialize and show 00.00.
Start the Timer:
Shake the wand or tilt the tilt switch to trigger the interrupt.
The timer will start counting up from 00.00.
Stop the Timer:
Shake the wand or tilt the switch again.
The timer will stop, displaying the final time.
Objective:
Try to stop the timer as close to 10.00 seconds as possible.
Challenge friends to see who can get the closest!
Understanding the Code
Imports and Pin Definitions:
machine.Pin: For controlling GPIO pins.utime: For timing functions.Define SDI, SRCLK, and RCLK pins for controlling the shift registers.
Initialize the tilt switch on GP16 with a pull-down resistor.
Segment and Digit Codes:
SEGMENT_CODES: A list containing the binary codes for displaying digits 0-9 on a 7-segment display.digit_pins: Codes to select each digit of the display. Active LOW for common cathode displays.
# 7-segment display segment codes for digits 0-9 (common cathode) SEGMENT_CODES = [0x3F, # 0 0x06, # 1 0x5B, # 2 0x4F, # 3 0x66, # 4 0x6D, # 5 0x7D, # 6 0x07, # 7 0x7F, # 8 0x6F] # 9 # Initialize digit select pins (common cathodes) digit_pins = [ machine.Pin(10, machine.Pin.OUT), # Digit 1 machine.Pin(11, machine.Pin.OUT), # Digit 2 machine.Pin(12, machine.Pin.OUT), # Digit 3 machine.Pin(13, machine.Pin.OUT) # Digit 4 ]
Variables for Timing:
start_time: Records the time when the timer starts.elapsed_time: Stores the total elapsed time when the timer stops.counting: A boolean flag indicating whether the timer is running.
Define the
shift_outFunction:Sends 8 bits of data to the 74HC595.
Shifts out the data starting from the most significant bit (MSB).
Pulses the shift and register clocks appropriately.
def shift_out(data): RCLK.low() for bit in range(7, -1, -1): SRCLK.low() bit_val = (data >> bit) & 0x01 SDI.value(bit_val) SRCLK.high() RCLK.high()
Define the
display_digitFunction:Turns off all digits.
Sends the segment code for the digit.
Activates the specified digit by setting its pin low.
Adds a small delay to make the digit visible.
Turns off the digit after displaying.
def display_digit(position, digit): for dp in digit_pins: dp.high() shift_out(SEGMENT_CODES[digit]) digit_pins[position].low() utime.sleep_ms(5) digit_pins[position].high()
display_timeFunction:Converts the elapsed time from milliseconds to centiseconds (hundredths of a second).
Splits the time into individual digits.
Uses multiplexing to display each digit rapidly.
def display_time(time_ms): # Convert time to centiseconds (hundredths of a second) centiseconds = int(time_ms / 10) # Limit to 9999 to fit the display if centiseconds > 9999: centiseconds = 9999 # Extract individual digits digits = [ (centiseconds // 1000) % 10, (centiseconds // 100) % 10, (centiseconds // 10) % 10, centiseconds % 10 ] # Display each digit rapidly for i in range(4): display_digit(i, digits[i])
tilt_handlerFunction:Triggered by the tilt switch interrupt.
Toggles the counting state.
Records the
start_timewhen counting starts.Calculates the
elapsed_timewhen counting stops.
def tilt_handler(pin): global counting, start_time, elapsed_time if not counting: # Start counting counting = True start_time = utime.ticks_ms() else: # Stop counting counting = False elapsed_time = utime.ticks_diff(utime.ticks_ms(), start_time)
Main Loop:
If counting is
True, continuously updates the display with the current elapsed time.If counting is
False, displays the finalelapsed_time.
while True: if counting: # Calculate elapsed time current_time = utime.ticks_diff(utime.ticks_ms(), start_time) display_time(current_time) else: # Display the final time display_time(elapsed_time)
Troubleshooting
Display Issues:
If the display is not showing numbers correctly, verify the segment and digit codes, and check the wiring connections.
Ensure that the shift register is connected properly and that data is being shifted out in the correct order.
Tilt Switch Sensitivity:
If the tilt switch is too sensitive or not sensitive enough, consider adjusting its orientation or replacing it with a different type.
Ensure that the pull-down resistor is correctly connected to prevent false triggers.
Timing Accuracy:
The timer relies on the system clock, which is reasonably accurate but may have slight variances.
For improved accuracy, use an external real-time clock (RTC) module.
Extensions and Enhancements
Visual Effects:
Add LEDs that flash or change color when the timer stops.
Use a buzzer to provide audio feedback when starting and stopping the timer.
High Score Tracking:
Modify the code to store the best (closest to 10.00) time achieved.
Display a congratulatory message or animation for new high scores.
Multiplayer Mode:
Allow multiple players to take turns, storing each player’s time.
Display player numbers and their respective times.
Difficulty Levels:
Introduce different target times (e.g., 5.00 seconds, 15.00 seconds) to increase the challenge.
Randomize the target time and display it at the beginning of each round.
Alternate Input Methods:
Replace the tilt switch with a button or another sensor for starting and stopping the timer.
Use a motion sensor to detect specific gestures.
Conclusion
You’ve successfully built a “10 Second” Game using the Raspberry Pi Pico 2! This project combines sensor input, timing functions, and display control to create an interactive and entertaining game. It’s an excellent example of how microcontrollers can be used to create fun and engaging experiences.
Feel free to customize and expand upon this project. Whether it’s adding new features, improving the design, or integrating additional components, the possibilities are endless.
