2.4 Colorful Light
In this lesson, we’ll explore how to create various colors using an RGB LED and the Raspberry Pi Pico 2. By adjusting the intensity of the red, green, and blue components, we can mix light to produce a wide range of colors. This concept is based on the additive method of color mixing.
What is Additive Color Mixing?
Additive color mixing involves combining different colors of light to produce new colors. When red, green, and blue light are combined in various intensities, they can create any color in the visible spectrum. For example:
Red + Green = Yellow
Red + Blue = Magenta
Green + Blue = Cyan
Red + Green + Blue = White
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
3(1-330Ω, 2-220Ω) |
Circuit Diagram
The PWM pins GP13, GP14 and GP15 control the Red, Green and Blue pins of the RGB LED respectively, and connect the common cathode pin to GND. This allows the RGB LED to display a specific color by superimposing light on these pins with different PWM values.
Wiring Diagram
The RGB LED has 4 pins: the long pin is the common cathode pin, which is usually connected to GND; the left pin next to the longest pin is Red; and the two pins on the right are Green and Blue.
We use a higher resistance for the red LED because it is typically brighter than the green and blue LEDs at the same current.
Writing the Code
We’ll write a MicroPython program that controls the intensity of each color using Pulse Width Modulation (PWM) to produce different colors.
Open the
2.4_colorful_light.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize PWM for red, green, and blue pins
red = machine.PWM(machine.Pin(13))
green = machine.PWM(machine.Pin(14))
blue = machine.PWM(machine.Pin(15))
# Set the PWM frequency
red.freq(1000)
green.freq(1000)
blue.freq(1000)
def map_value(x, in_min, in_max, out_min, out_max):
# Map a value from one range to another
return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
def set_color(r, g, b):
# Set the color by adjusting duty cycles
red.duty_u16(map_value(r, 0, 255, 0, 65535))
green.duty_u16(map_value(g, 0, 255, 0, 65535))
blue.duty_u16(map_value(b, 0, 255, 0, 65535))
# Example: Set the color to orange
set_color(255, 165, 0)
When the code is running, the RGB LED will emit an orange light.
Understanding the Code
Import Libraries:
machine: To access hardware-specific functions.utime: For time-related functions (not used in this example but useful for animations).
Initialize PWM Objects:
Create PWM objects for the red, green, and blue pins connected to the RGB LED and set the PWM frequency to 1000 Hz for all colors.
# Initialize PWM for red, green, and blue pins red = machine.PWM(machine.Pin(13)) green = machine.PWM(machine.Pin(14)) blue = machine.PWM(machine.Pin(15)) # Set the PWM frequency red.freq(1000) green.freq(1000) blue.freq(1000)
Define
map_valueFunction:Since the
duty_u16method accepts values from 0 to 65535, but color values are typically in the range 0 to 255, we need to map the 0-255 range to 0-65535.The
map_valuefunction scales the input value accordingly.
def map_value(x, in_min, in_max, out_min, out_max): # Map a value from one range to another return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
Define
set_colorFunction:This function takes RGB values (each from 0 to 255) and sets the duty cycle for each color channel after mapping.
def set_color(r, g, b): # Set the color by adjusting duty cycles red.duty_u16(map_value(r, 0, 255, 0, 65535)) green.duty_u16(map_value(g, 0, 255, 0, 65535)) blue.duty_u16(map_value(b, 0, 255, 0, 65535))
Set the Desired Color:
Call
set_color(255, 165, 0)to set the RGB LED to orange. You can change the values to any RGB color you like.
Example: Color Cycling
Let’s enhance the code to cycle through different colors.
To find the RGB values for different colors, you can use any graphic software or an online color picker. For example:
Red: (255, 0, 0)
Green: (0, 255, 0)
Blue: (0, 0, 255)
White: (255, 255, 255)
Purple: (128, 0, 128)
Write the code.
We define a list of RGB tuples representing different colors. The
while Trueloop cycles through each color, sets the RGB LED to that color, and waits for 1 second before moving to the next color.import machine import utime # Initialize PWM for red, green, and blue pins red = machine.PWM(machine.Pin(13)) green = machine.PWM(machine.Pin(14)) blue = machine.PWM(machine.Pin(15)) # Set the PWM frequency red.freq(1000) green.freq(1000) blue.freq(1000) def map_value(x, in_min, in_max, out_min, out_max): return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min) def set_color(r, g, b): red.duty_u16(map_value(r, 0, 255, 0, 65535)) green.duty_u16(map_value(g, 0, 255, 0, 65535)) blue.duty_u16(map_value(b, 0, 255, 0, 65535)) # List of colors to cycle through colors = [ (255, 0, 0), # Red (0, 255, 0), # Green (0, 0, 255), # Blue (255, 255, 0), # Yellow (0, 255, 255), # Cyan (255, 0, 255), # Magenta (255, 255, 255) # White ] while True: for color in colors: set_color(*color) utime.sleep(1)
When this code is running, the RGB LED will cycle through a sequence of colors: red, green, blue, yellow, cyan, magenta, and white.
Each color will be displayed for 1 second before transitioning to the next one in the list.
Conclusion
By controlling the intensity of the red, green, and blue components of an RGB LED using PWM, we can create a vast array of colors. This project demonstrates the principles of additive color mixing and provides a foundation for creating colorful light displays with microcontrollers.
References
