3.1.7 Traffic Light
In this project, we will use LED lights of three colors to realize the change of traffic lights and a four-digit 7-segment display will be used to display the timing of each traffic state.
Components
../_images/list_Traffic_Light1.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
SPICE0
Pin 24
10
8
SPICE1
Pin 26
11
7
../_images/Schematic_three_one71.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image2541.png
Step 2: Change directory.
cd ~/davinci-kit-for-raspberry-pi/c/3.1.7/
Step 3: Compile.
gcc 3.1.7_TrafficLight.c -lwiringPi
Step 4: Run.
As the code runs, LEDs will simulate the color changing of traffic lights. Firstly, the red LED lights up for 60s, then the green LED lights up for 30s; next, the yellow LED lights up for 5s. After that, the red LED lights up for 60s once again. In this way, this series of actions will be executed repeatedly.
Code Explanation
#define     SDI     5
#define     RCLK    4
#define     SRCLK    1
const int placePin[] = {12, 3, 2, 0};
unsigned char number[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
void pickDigit(int digit);
void hc595_shift(int8_t data);
void clearDisplay();
void display();
These codes are used to realize the function of number display of 4-Digit 7-Segment Displays. Refer to 1.1.5 4-Digit 7-Segment Display of the document for more details. Here, we use the codes to display countdown of traffic light time.
const int ledPin[]={6,10,11};
int colorState = 0;
void lightup()
    for(int i=0;i<3;i++){
        digitalWrite(ledPin[i],HIGH);
    digitalWrite(ledPin[colorState],LOW);
The codes are used to switch the LED on and off.
int greenLight = 30;
int yellowLight = 5;
int redLight = 60;
int colorState = 0;
char *lightColor[]={"Red","Green","Yellow"};
int counter = 60;
void timer(int  timer1){       //Timer function
    if(timer1 == SIGALRM){
        counter --;
        alarm(1);
        if(counter == 0){
            if(colorState == 0) counter = greenLight;
            if(colorState == 1) counter = yellowLight;
            if(colorState == 2) counter = redLight;
            colorState = (colorState+1)%3;
        printf("counter : %d \t light color: %s \n",counter,lightColor[colorState]);
The codes are used to switch the timer on and off. Refer to 1.1.5 4-Digit 7-Segment Display for more details. Here, when the timer returns to zero, colorState will be switched so as to switch LED, and the timer will be assigned to a new value.
void loop()
    display();
    lightup();
int main(void)
    signal(SIGALRM,timer);
    alarm(1);
    loop();
The timer is started in the main() function. In loop() function, use while(1) loop and call the functions of 4-Digit 7-Segment and LED.
