.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.7 Traffic Light
In this project, we will use LED lights of three colors to realize the
change of traffic lights and a four-digit 7-segment display will be used
to display the timing of each traffic state.
Components
.. image:: img/list_Traffic_Light.png
:align: center
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
SPIMOSI Pin 19 12 10
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO25 Pin 22 6 25
SPICE0 Pin 24 10 8
SPICE1 Pin 26 11 7
.. image:: img/Schematic_three_one7.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image254.png
:width: 800
**Step 2:** Change directory.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.7/
**Step 3:** Compile.
.. raw:: html
.. code-block::
gcc 3.1.7_TrafficLight.c -lwiringPi
**Step 4:** Run.
.. raw:: html
.. code-block::
As the code runs, LEDs will simulate the color changing of traffic
lights. Firstly, the red LED lights up for 60s, then the green LED
lights up for 30s; next, the yellow LED lights up for 5s. After that,
the red LED lights up for 60s once again. In this way, this series of
actions will be executed repeatedly.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code Explanation**
.. code-block:: c
#define SDI 5
#define RCLK 4
#define SRCLK 1
const int placePin[] = {12, 3, 2, 0};
unsigned char number[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
void pickDigit(int digit);
void hc595_shift(int8_t data);
void clearDisplay();
void display();
These codes are used to realize the function of number display of 4-Digit 7-Segment
Displays. Refer to :ref:`1.1.5_4digit_c_pi5` of the document for more details. Here, we use the
codes to display countdown of traffic light time.
.. code-block:: c
const int ledPin[]={6,10,11};
int colorState = 0;
void lightup()
for(int i=0;i<3;i++){
digitalWrite(ledPin[i],HIGH);
digitalWrite(ledPin[colorState],LOW);
The codes are used to switch the LED on and off.
.. code-block:: c
int greenLight = 30;
int yellowLight = 5;
int redLight = 60;
int colorState = 0;
char *lightColor[]={"Red","Green","Yellow"};
int counter = 60;
void timer(int timer1){ //Timer function
if(timer1 == SIGALRM){
counter --;
alarm(1);
if(counter == 0){
if(colorState == 0) counter = greenLight;
if(colorState == 1) counter = yellowLight;
if(colorState == 2) counter = redLight;
colorState = (colorState+1)%3;
printf("counter : %d \t light color: %s \n",counter,lightColor[colorState]);
The codes are used to switch the timer on and off. Refer to :ref:`1.1.5_4digit_c_pi5` for more details. Here, when the timer returns to zero, colorState
will be switched so as to switch LED, and the timer will be assigned to
a new value.
.. code-block:: c
void loop()
display();
lightup();
int main(void)
signal(SIGALRM,timer);
alarm(1);
loop();
The timer is started in the main() function. In loop() function, use
**while(1)** loop and call the functions of 4-Digit 7-Segment and LED.
