3.1.5 Battery Indicator(MCP3008)ο
Introductionο
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
Required Componentsο
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
SPICE0 |
Pin 24 |
10 |
8 |
SPIMOSI |
Pin 19 |
12 |
10 |
SPIMISO |
Pin 21 |
13 |
9 |
SPISCLK |
Pin 23 |
14 |
11 |
GPIO25 |
Pin 22 |
25 |
GPIO12 |
Pin 32 |
26 |
12 |
GPIO16 |
Pin 36 |
27 |
16 |
GPIO20 |
Pin 38 |
28 |
20 |
GPIO21 |
Pin 40 |
29 |
21 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
GPIO19 |
Pin 35 |
24 |
19 |
GPIO26 |
Pin 37 |
25 |
26 |
Experimental Proceduresο
Step 1: Build the circuit.
cd ~/davinci-kit-for-raspberry-pi/c/3.1.5-2/
Step 3: Compile the code.
gcc 3.1.5_BatteryIndicator.c -lwiringPi
After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Codeο
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1MHz
#define VREF 3.3
int pins[10] = {6, 26, 27, 28, 29, 21, 22, 23, 24, 25};
int read_ADC(int channel)
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Single-ended mode
buffer[2] = 0;
int value = ((buffer[1] & 3) << 8) | buffer[2];
return value;
void LedBarGraph(int value) {
for (int i = 0; i < 10; i++) {
if (i < value)
digitalWrite(pins[i], HIGH);
else
digitalWrite(pins[i],LOW);
int main(void)
if (wiringPiSetup() == -1) {
printf("setup wiringPi failed!\n");
printf("SPI setup failed!\n");
pinMode(pins[i], OUTPUT);
while (1) {
int analogVal = read_ADC(0); // MCP3008 CH0
if (analogVal < 0) continue;
float voltage = analogVal * VREF / 1023.0;
int level = analogVal * 10 / 1024;
if (level > 10) level = 10;
LedBarGraph(level);
printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level);
delay(200);
Code Explanationο
buffer[1] = (8 + channel) << 4; // Single-ended mode, CH0~CH7
buffer[2] = 0;
int value = ((buffer[1] & 3) << 8) | buffer[2]; // Combine 10-bit result
return value;
This function reads analog values from the MCP3008 ADC chip using SPI. The channel parameter selects one of the 8 analog inputs (CH0βCH7). The MCP3008 returns a 10-bit digital value between 0 and 1023 representing the analog voltage.
if (i < value)
digitalWrite(pins[i], HIGH); // Turn on LED (assumes active HIGH wiring)
else
digitalWrite(pins[i], LOW); // Turn off LED
This function controls a 10-LED bar graph display. Each LED represents 1/10th of the voltage range. LEDs are turned on in order up to the specified level.
Note: This version assumes LED anodes are connected to GPIOs and cathodes to GND (i.e. active HIGH).
int main(void)
digitalWrite(pins[i], HIGH); // Initialize all LEDs to ON
while (1) {
int analogVal = read_ADC(0); // Read voltage on CH0
int level = analogVal * 10 / 1024; // Map to 0β10 levels
LedBarGraph(level); // Display level on LEDs
delay(200); // Update rate: 5 Hz
Main program logic:
Initializes wiringPi and SPI communication.
Sets GPIO pins as outputs for controlling the 10-LED bar.
Continuously reads analog voltage via MCP3008 (CH0).
Converts the reading to a voltage using VREF = 3.3V.
Scales voltage to a 0β10 level bar graph and lights up LEDs.
Displays the raw ADC value, voltage (in volts), and LED level via serial console.
This acts as a visual battery level indicator or analog voltmeter.
