πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.2.1 Photoresistor(MCP3008)
_images/mcp3008_and_adc0834.jpg
Introduction
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Components
_images/list2_2.2.1_photoresistor.png
Principle
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity; in other words, it exhibits photo conductivity. A photoresistor can be applied in light-sensitive detector circuits, and light- and darkness-activated switching circuits.
_images/image196.png
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
GPIO22
pin15
_images/schematic_2.2.1_photoresistor_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
_images/july24_2.2.1_photoresistor_mcp3008.png
For C Language Users
cd ~/davinci-kit-for-raspberry-pi/c/2.2.1-2/
Step 3: Compile the code.
gcc 2.2.1_Photoresistor.c -o photoresistor -lwiringPi -lm
./photoresistor
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#define SPI_CHANNEL 0      // Use SPI channel 0 (CE0)
#define SPI_SPEED   1000000 // 1 MHz SPI speed
#define LedPin      3       // GPIO3 (WiringPi) for LED PWM
// Read ADC value from MCP3008, channel 0~7
int readMCP3008(int channel) {
    unsigned char buffer[3];
    buffer[0] = 1;                          // Start bit
    buffer[1] = (8 + channel) << 4;         // SGL/DIF = 1, D2-D0 = channel
    buffer[2] = 0;
    // Combine the result
    int result = ((buffer[1] & 3) << 8) | buffer[2];
    return result;
int main(void) {
    if (wiringPiSetup() == -1) {
        printf("wiringPi init failed!\n");
        printf("SPI setup failed!\n");
    softPwmCreate(LedPin, 0, 100); // Init software PWM
    while (1) {
        int analogVal = readMCP3008(0); // Read from CH0
        printf("ADC Value: %d\n", analogVal);
        // Scale 10-bit ADC value (0–1023) to PWM range (0–100)
        int pwmVal = analogVal * 100 / 1023;
        softPwmWrite(LedPin, pwmVal);
        delay(100);
Code Explanation
The codes here are the same as that in 2.1.4 Potentiometer. If you have any other questions, please check the code explanation of 2.1.4 Potentiometer(MCP3008) for details.
For Python Language Users
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
sudo python3 2.2.1-2_photoresistor.py
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# GPIO pin for PWM LED
PWM_PIN = 22
# Setup GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(PWM_PIN, GPIO.OUT)
# Initialize PWM (frequency = 1000Hz)
pwm = GPIO.PWM(PWM_PIN, 1000)
pwm.start(0)  # Start with 0% duty cycle
# Initialize SPI (MCP3008 on Bus 0, CE0)
spi = spidev.SpiDev()
spi.open(0, 0)
# Function to read MCP3008 ADC value
def read_adc(channel):
    Read analog value from MCP3008 (channel 0–7)
    Returns: 10-bit value (0–1023)
        return -1
    value = ((r[1] & 3) << 8) | r[2]
    return value
# Main loop to read ADC and set PWM brightness
        analogVal = read_adc(0)
        print(f"value = {analogVal}")
        # Scale ADC value (0–1023) to duty cycle (0–100)
        duty_cycle = analogVal * 100 / 1023
        pwm.ChangeDutyCycle(duty_cycle)
        time.sleep(0.2)
finally:
    pwm.stop()
    GPIO.cleanup()
    spi.close()
Code Explanation
  1. Import necessary libraries:
    • RPi.GPIO to control GPIO pins and generate PWM signal.
    • spidev to interface with the MCP3008 ADC via SPI.
    • time to handle timing and delays.
    import spidev
  2. Configure GPIO pin 22 as PWM output using BCM mode. Then, initialize software PWM at 1000 Hz with a starting duty cycle of 0%.
    PWM_PIN = 22
    # Setup GPIO
  3. Set up the SPI interface to communicate with MCP3008 on bus 0, chip enable 0 (CE0), and configure SPI speed to 1 MHz.
    spi.open(0, 0)
  4. Define a function read_adc(channel) to read analog values from MCP3008. The function sends three bytes to the chip and reconstructs a 10-bit analog value (0–1023) from the response.
            return -1
        return value
  5. This is the main loop that:
    • Reads analog input from channel 0 of the MCP3008.
    • Converts the value to a PWM duty cycle (0–100%).
    • Adjusts the brightness of the LED using pwm.ChangeDutyCycle().
    • Repeats every 0.2 seconds.
            time.sleep(0.2)
  6. When the user interrupts the program with Ctrl+C, the PWM and GPIO are properly cleaned up, and the SPI interface is closed.
    finally:
        pwm.stop()
        GPIO.cleanup()
        spi.close()
