πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.3 Tilt Switch
Introduction
This is a ball tilt-switch with a metal ball inside. It is used to detect inclinations of a small angle.
Components
_images/list_2.1.3_tilt_switch.png
Principle
Tilt
The principle is very simple. When the switch is tilted in a certain angle, the ball inside rolls down and touches the two contacts connected to the pins outside, thus triggering circuits. Otherwise the ball will stay away from the contacts, thus breaking the circuits.
_images/image167.png
Schematic Diagram
_images/image307.png _images/image308.png
Experimental Procedures
Step 1: Build the circuit.
_images/image169.png
For C Language Users
Step 2: Change directory.
cd ~/davinci-kit-for-raspberry-pi/c/2.1.3/
Step 3: Compile.
gcc 2.1.3_Tilt.c -lwiringPi
Step 4: Run.
Place the tilt horizontally, and the green LED will turns on. If you tilt it, "Tilt!" will be printed on the screen and the red LED will lights on. Place it horizontally again, and the green LED will turns on again.
#include <wiringPi.h>
#include <stdio.h>
#define TiltPin     0
#define Gpin        2
#define Rpin        3
void LED(char* color)
    pinMode(Gpin, OUTPUT);
    pinMode(Rpin, OUTPUT);
    if (color == "RED")
        digitalWrite(Rpin, HIGH);
        digitalWrite(Gpin, LOW);
    else if (color == "GREEN")
        digitalWrite(Rpin, LOW);
        digitalWrite(Gpin, HIGH);
    else
        printf("LED Error");
int main(void)
    pinMode(TiltPin, INPUT);
    LED("GREEN");
        if(0 == digitalRead(TiltPin)){
            delay(10);
                LED("RED");
                printf("Tilt!\n");
                delay(100);
        else if(1 == digitalRead(TiltPin)){
            delay(10);
                LED("GREEN");
Code Explanation
    if (color == "RED")
    else
Define a function LED() to turn the two LEDs on or off. If the parameter color is RED, the red LED lights up; similarly, if the parameter color is GREEN, the green LED will turns on.
            delay(10);
                LED("RED");
                printf("Tilt!\n");
            delay(10);
                LED("GREEN");
If the read value of tilt switch is 0, it means that the tilt switch is tilted then you write the parameter "RED" into function LED to get the red LED lighten up; otherwise, the green LED will lit.
For Python Language Users
Step 3: Run.
sudo python3 2.1.3_Tilt.py
Place the tilt horizontally, and the green LED will turns on. If you tilt it, "Tilt!" will be printed on the screen and the red LED will turns on. Place it horizontally again, and the green LED will lights on.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
dhtPin = 17
GPIO.setmode(GPIO.BCM)
MAX_UNCHANGE_COUNT = 100
STATE_INIT_PULL_DOWN = 1
STATE_INIT_PULL_UP = 2
STATE_DATA_FIRST_PULL_DOWN = 3
STATE_DATA_PULL_UP = 4
STATE_DATA_PULL_DOWN = 5
def readDht11():
    GPIO.setup(dhtPin, GPIO.OUT)
    GPIO.output(dhtPin, GPIO.HIGH)
    time.sleep(0.05)
    GPIO.output(dhtPin, GPIO.LOW)
    time.sleep(0.02)
    GPIO.setup(dhtPin, GPIO.IN, GPIO.PUD_UP)
    unchanged_count = 0
    last = -1
    data = []
        current = GPIO.input(dhtPin)
        data.append(current)
        if last != current:
            unchanged_count = 0
            last = current
            unchanged_count += 1
            if unchanged_count > MAX_UNCHANGE_COUNT:
                break
    state = STATE_INIT_PULL_DOWN
    lengths = []
    current_length = 0
    for current in data:
        current_length += 1
        if state == STATE_INIT_PULL_DOWN:
            if current == GPIO.LOW:
                state = STATE_INIT_PULL_UP
                continue
        if state == STATE_INIT_PULL_UP:
            if current == GPIO.HIGH:
                state = STATE_DATA_FIRST_PULL_DOWN
                continue
        if state == STATE_DATA_FIRST_PULL_DOWN:
                state = STATE_DATA_PULL_UP
                continue
        if state == STATE_DATA_PULL_UP:
                current_length = 0
                state = STATE_DATA_PULL_DOWN
                continue
        if state == STATE_DATA_PULL_DOWN:
                lengths.append(current_length)
                continue
    if len(lengths) != 40:
        #print ("Data not good, skip")
        return False
    shortest_pull_up = min(lengths)
    longest_pull_up = max(lengths)
    halfway = (longest_pull_up + shortest_pull_up) / 2
    bits = []
    the_bytes = []
    byte = 0
    for length in lengths:
        bit = 0
        if length > halfway:
            bit = 1
        bits.append(bit)
    #print ("bits: %s, length: %d" % (bits, len(bits)))
    for i in range(0, len(bits)):
        byte = byte << 1
        if (bits[i]):
            byte = byte | 1
            byte = byte | 0
        if ((i + 1) % 8 == 0):
            the_bytes.append(byte)
            byte = 0
    #print (the_bytes)
    checksum = (the_bytes[0] + the_bytes[1] + the_bytes[2] + the_bytes[3]) & 0xFF
    if the_bytes[4] != checksum:
        return False
    return the_bytes[0], the_bytes[2]
def main():
        result = readDht11()
        if result:
            humidity, temperature = result
            print ("humidity: %s %%,  Temperature: %s C`" % (humidity, temperature))
        time.sleep(1)
def destroy():
    GPIO.cleanup()
if __name__ == '__main__':
        main()
        destroy()
Code Explanation
GPIO.add_event_detect(TiltPin, GPIO.BOTH, callback=detect, bouncetime=200)
Set up a detect on TiltPin, and callback function to detect.
def Led(x):
    if x == 0:
        GPIO.output(Rpin, 1)
        GPIO.output(Gpin, 0)
    if x == 1:
        GPIO.output(Rpin, 0)
        GPIO.output(Gpin, 1)
Define a function Led() to turn the two LEDs on or off. If x=0, the red LED lights up; otherwise, the green LED will be lit.
def Print(x):
    if x == 0:
        print ('    *************')
        print ('    *   Tilt!   *')
Create a function, Print() to print the characters above on the screen.
def detect(chn):
    Led(GPIO.input(TiltPin))
    Print(GPIO.input(TiltPin))
Define a callback function for tilt callback. Get the read value of the tilt switch then the function LedοΌˆοΌ‰ controls the turning on or off of the two LEDs that is depended on the read value of the tilt switch.
Phenomenon Picture
_images/image170.jpeg
