.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.2.1_c_mcp3008:
2.2.1 Photoresistor(MCP3008)
.. note::
.. image:: img/mcp3008_and_adc0834.jpg
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
Photoresistor is a commonly used component of ambient light intensity in
life. It helps the controller to recognize day and night and realize
light control functions such as night lamp. This project is very similar
to potentiometer, and you might think it changing the voltage to sensing
light.
.. image:: img/list2_2.2.1_photoresistor.png
Principle
A photoresistor or photocell is a light-controlled variable resistor.
The resistance of a photoresistor decreases with increasing incident
light intensity; in other words, it exhibits photo conductivity. A
photoresistor can be applied in light-sensitive detector circuits, and
light- and darkness-activated switching circuits.
.. image:: img/image196.png
:width: 200
:align: center
Schematic Diagram
.. list-table::
:widths: 30 30 30 30
:header-rows: 1
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
* - GPIO22
- pin15
- 3
- 22
.. image:: img/schematic_2.2.1_photoresistor_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/july24_2.2.1_photoresistor_mcp3008.png
For C Language Users
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/2.2.1-2/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.2.1_Photoresistor.c -o photoresistor -lwiringPi -lm
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
./photoresistor
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code**
.. code-block:: c
#include
#include
#include
#include
#define SPI_CHANNEL 0 // Use SPI channel 0 (CE0)
#define SPI_SPEED 1000000 // 1 MHz SPI speed
#define LedPin 3 // GPIO3 (WiringPi) for LED PWM
// Read ADC value from MCP3008, channel 0~7
int readMCP3008(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // SGL/DIF = 1, D2-D0 = channel
buffer[2] = 0;
// Combine the result
int result = ((buffer[1] & 3) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("wiringPi init failed!\n");
printf("SPI setup failed!\n");
softPwmCreate(LedPin, 0, 100); // Init software PWM
while (1) {
int analogVal = readMCP3008(0); // Read from CH0
printf("ADC Value: %d\n", analogVal);
// Scale 10-bit ADC value (0–1023) to PWM range (0–100)
int pwmVal = analogVal * 100 / 1023;
softPwmWrite(LedPin, pwmVal);
delay(100);
**Code Explanation**
The codes here are the same as that in 2.1.4 Potentiometer. If you have
any other questions, please check the code explanation of :ref:`2.1.4_c_mcp3008` for details.
For Python Language Users
**Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this.
**Step 3:** Go to the folder of the code.
.. raw:: html
.. code-block::
.. raw:: html
.. code-block::
sudo python3 2.2.1-2_photoresistor.py
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
import spidev
# GPIO pin for PWM LED
PWM_PIN = 22
# Setup GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(PWM_PIN, GPIO.OUT)
# Initialize PWM (frequency = 1000Hz)
pwm = GPIO.PWM(PWM_PIN, 1000)
pwm.start(0) # Start with 0% duty cycle
# Initialize SPI (MCP3008 on Bus 0, CE0)
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 1000000 # 1 MHz
# Function to read MCP3008 ADC value
def read_adc(channel):
Read analog value from MCP3008 (channel 0–7)
Returns: 10-bit value (0–1023)
return -1
value = ((r[1] & 3) << 8) | r[2]
return value
# Main loop to read ADC and set PWM brightness
analogVal = read_adc(0)
print(f"value = {analogVal}")
# Scale ADC value (0–1023) to duty cycle (0–100)
duty_cycle = analogVal * 100 / 1023
pwm.ChangeDutyCycle(duty_cycle)
time.sleep(0.2)
finally:
pwm.stop()
GPIO.cleanup()
spi.close()
#. Import necessary libraries:
- ``RPi.GPIO`` to control GPIO pins and generate PWM signal.
- ``spidev`` to interface with the MCP3008 ADC via SPI.
- ``time`` to handle timing and delays.
import spidev
#. Configure GPIO pin 22 as PWM output using BCM mode. Then, initialize software PWM at 1000 Hz with a starting duty cycle of 0%.
PWM_PIN = 22
# Setup GPIO
#. Set up the SPI interface to communicate with MCP3008 on bus 0, chip enable 0 (CE0), and configure SPI speed to 1 MHz.
spi.open(0, 0)
#. Define a function ``read_adc(channel)`` to read analog values from MCP3008. The function sends three bytes to the chip and reconstructs a 10-bit analog value (0–1023) from the response.
return -1
return value
#. This is the main loop that:
- Reads analog input from channel 0 of the MCP3008.
- Converts the value to a PWM duty cycle (0–100%).
- Adjusts the brightness of the LED using ``pwm.ChangeDutyCycle()``.
- Repeats every 0.2 seconds.
time.sleep(0.2)
#. When the user interrupts the program with Ctrl+C, the PWM and GPIO are properly cleaned up, and the SPI interface is closed.
finally:
pwm.stop()
GPIO.cleanup()
spi.close()
