2.1.6 Joystick(MCP3008)
_images/mcp3008_and_adc0834.jpg
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
_images/image317-copy.png
Principle
Joystick
The basic idea of a joystick is to translate the movement of a stick into electronic information that a computer can process.
In order to communicate a full range of motion to the computer, a joystick needs to measure the stick’s position on two axes – the X-axis (left to right) and the Y-axis (up and down). Just as in basic geometry, the X-Y coordinates pinpoint the stick’s position exactly.
To determine the location of the stick, the joystick control system simply monitors the position of each shaft. The conventional analog joystick design does this with two potentiometers, or variable resistors.
The joystick also has a digital input that is actuated when the joystick is pressed down.
_images/image318.png
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
_images/schematic_2.1.9_joystick_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
_images/july24_2.1.9_joystick_mcp3008.png
For C Language Users
cd ~/davinci-kit-for-raspberry-pi/c/2.1.6-2/
Step 3: Compile the code.
gcc 2.1.6_Joystick.c -o joystick -lwiringPi
./joystick
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000  // 1 MHz
#define BtnPin      3        // WiringPi 3 = BCM GPIO22
// Read from MCP3008 channel (0–7)
int read_ADC(int channel) {
    unsigned char buffer[3];
    buffer[0] = 1;                            // Start bit
    buffer[1] = (8 + channel) << 4;           // Channel config
    buffer[2] = 0;
    int result = ((buffer[1] & 0x03) << 8) | buffer[2];
    return result;
int main(void) {
    if (wiringPiSetup() == -1) {
        printf("WiringPi setup failed!\n");
        printf("SPI setup failed!\n");
    pinMode(BtnPin, INPUT);
    pullUpDnControl(BtnPin, PUD_UP);
    while (1) {
        int x_val = read_ADC(0);     // VRX on CH0
        int y_val = read_ADC(1);     // VRY on CH1
        int btn_val = digitalRead(BtnPin);  // SW button
        printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
        delay(100);
Code Explanation
  1. This section initializes the libraries needed for GPIO and SPI communication.
    #include <stdio.h>
  2. Defines a function read_ADC() to read analog data from MCP3008. It communicates over SPI to request data from a given channel (0–7), then parses the response to get a 10-bit ADC result.
        buffer[0] = 1;
        buffer[2] = 0;
        return result;
  3. The main function initializes the WiringPi and SPI interfaces, configures the joystick’s button pin, and continuously reads joystick values and prints them to the console.
    int main(void) {
        while (1) {
            int x_val = read_ADC(0);     // VRX to CH0
            int y_val = read_ADC(1);     // VRY to CH1
            int btn_val = digitalRead(BtnPin);  // SW to GPIO22
            delay(100);
For Python Language Users
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
Step 4: Run.
sudo python3 2.1.6-2_Joystick.py
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# Define GPIO pin for joystick button (SW pin)
BTN_PIN = 22
# Set up GPIO mode
GPIO.setmode(GPIO.BCM)
GPIO.setup(BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP)  # Use internal pull-up
# Initialize SPI communication with MCP3008
spi = spidev.SpiDev()
spi.open(0, 0)  # SPI bus 0, CE0
def read_adc(channel):
    Reads analog value from the specified MCP3008 channel (0–7)
    :param channel: ADC channel number (0–7)
    :return: 10-bit integer value (0–1023)
        return -1
    return value
    # Main loop to read and print joystick values and button state
        # Read X and Y values from MCP3008 channels 1 and 2
        x_val = read_adc(1)  # Joystick VRX connected to CH1
        y_val = read_adc(2)  # Joystick VRY connected to CH2
        # Read the state of the joystick button (SW)
        Btn_val = GPIO.input(BTN_PIN)  # 0 = pressed, 1 = released
        # Print the read values
        print('X: %d  Y: %d  Btn: %d' % (x_val, y_val, Btn_val))
        time.sleep(0.2)
finally:
    spi.close()
    GPIO.cleanup()
Code Explanation
import spidev
This section imports the required libraries:
  • RPi.GPIO is used to handle GPIO input (joystick button).
  • spidev is used to communicate with the MCP3008 ADC chip via SPI.
  • time is used to introduce delays between readings.
BTN_PIN = 22
# Set up GPIO mode
spi.max_speed_hz = 1000000
This block sets the GPIO mode to BCM, initializes the joystick button input on GPIO22 with a pull-up resistor, and configures the SPI interface with MCP3008 using bus 0 and chip enable 0 (CE0) at 1 MHz.
        return -1
    return value
Defines the read_adc() function to read analog data from a specific MCP3008 channel. It sends three bytes over SPI and interprets the response to return a 10-bit value from 0 to 1023.
        # Read X and Y values from MCP3008 channels 0 and 1
        x_val = read_adc(0)  # Joystick VRX connected to CH0
        y_val = read_adc(1)  # Joystick VRY connected to CH1
        time.sleep(0.2)
finally:
    spi.close()
    GPIO.cleanup()
This main loop reads and prints the X/Y analog positions from the joystick and its button state every 200ms. If the script is interrupted via keyboard (Ctrl+C), SPI and GPIO are properly cleaned up.
