2.2.3 DHT-11
The digital temperature and humidity sensor DHT11 is a composite sensor that contains a calibrated digital signal output of temperature and humidity. The technology of a dedicated digital modules collection and the technology of the temperature and humidity sensing are applied to ensure that the product has high reliability and excellent stability.
The sensors include a wet element resistive sensor and a NTC temperature sensor and they are connected to a high performance 8-bit microcontroller.
Components
Principle
The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins are needed).
Only three pins are available: VCC, GND, and DATA. The communication process begins with the DATA line sending start signals to DHT11, and DHT11 receives the signals and returns an answer signal. Then the host receives the answer signal and begins to receive 40-bit humiture data (8-bit humidity integer + 8-bit humidity decimal + 8-bit temperature integer + 8-bit temperature decimal + 8-bit checksum). For more information, please refer to DHT11 datasheet.
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
For C Language Users
cd ~/davinci-kit-for-raspberry-pi/c/2.2.3/
Step 3: Compile the code.
gcc 2.2.3_DHT.c -lwiringPi
After the code runs, the program will print the temperature and humidity detected by DHT11 on the computer screen.
#include <wiringPi.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#define MAXTIMINGS 85 // Maximum number of timing transitions
int dht11_dat[5] = {0, 0, 0, 0, 0}; // Data array to hold sensor values
// Function to read data from DHT11 sensor
void read_dht11_dat(int GPIOPIN)
uint8_t currState;
uint8_t laststate = HIGH;
uint8_t counter = 0;
uint8_t j = 0;
uint8_t i;
float f; // Temperature in Fahrenheit
// Reset data array before each read
dht11_dat[0] = dht11_dat[1] = dht11_dat[2] = dht11_dat[3] = dht11_dat[4] = 0;
// Pull pin down for 18 milliseconds to initiate communication
pinMode(GPIOPIN, OUTPUT);
digitalWrite(GPIOPIN, LOW);
delay(18);
// Then pull it up for 40 microseconds
digitalWrite(GPIOPIN, HIGH);
delayMicroseconds(40);
// Prepare to read the pin
pinMode(GPIOPIN, INPUT);
// Detect change and read data
for (i = 0; i < MAXTIMINGS; i++)
counter = 0;
// Count how long each state lasts
while (digitalRead(GPIOPIN) == laststate)
counter++;
delayMicroseconds(2);
if (counter == 255)
break;
// Save the current state
laststate = digitalRead(GPIOPIN);
if (counter == 255) break;
// Ignore first 3 transitions (DHT11 response signal)
if ((i >= 4) && (i % 2 == 0))
// Shift bits and store data
dht11_dat[j/8] <<= 1;
if (counter > 16)
dht11_dat[j/8] |= 1;
j++;
// Check if we received 40 bits (5 bytes) and verify checksum
if ((j >= 40) && (dht11_dat[4] == ((dht11_dat[0] + dht11_dat[1] + dht11_dat[2] + dht11_dat[3]) & 0xFF)) )
// Convert temperature to Fahrenheit
f = dht11_dat[2] * 9.0 / 5.0 + 32;
printf("Humidity = %d.%d %% Temperature = %d.%d °C (%.1f °F)\n",
dht11_dat[0], dht11_dat[1], dht11_dat[2], dht11_dat[3], f);
else
printf("Data not good, skip\n");
int main (void)
printf("Raspberry Pi wiringPi DHT11 Temperature test program\n");
// Initialize wiringPi using BCM GPIO pin numbering
if (wiringPiSetupGpio() == -1)
exit(1);
while(1)
// Read data from DHT11 connected to GPIO pin 17
read_dht11_dat(17);
delay(1000); // Wait 1 second before next read
Code Explanation
Include Headers: The code includes necessary headers for wiringPi functions and standard input/output.
#include <wiringPi.h> #include <stdio.h> #include <stdlib.h> #include <stdint.h>
Define Constants:
MAXTIMINGS: The maximum number of timing transitions expected from the DHT11 sensor (85).
Global Data Array:
dht11_dat[5]: An array to hold the 5 bytes of data received from the DHT11 sensor.
Function
read_dht11_dat(int GPIOPIN): Reads data from the DHT11 sensor connected to the specified GPIO pin.Initialization: Reset the dht11_dat array to zero before each read.
Start Signal: Pull the GPIO pin low for at least 18 milliseconds to signal the DHT11 to start sending data.
pinMode(GPIOPIN, OUTPUT); digitalWrite(GPIOPIN, LOW); delay(18); // 18 milliseconds
Pull the GPIO pin high for 40 microseconds.
digitalWrite(GPIOPIN, HIGH); delayMicroseconds(40); // 40 microseconds
Set the GPIO pin to input mode to read data from the sensor.
Data Reading Loop: The loop runs up to MAXTIMINGS times to read the data bits.
For each transition (from high to low or low to high), it measures how long the pin stays in each state.
for (i = 0; i < MAXTIMINGS; i++) { counter = 0; while (digitalRead(GPIOPIN) == laststate) { counter++; delayMicroseconds(2); if (counter == 255) { break; } } laststate = digitalRead(GPIOPIN); // ... rest of the loop }
Data Bit Extraction: The first 3 transitions are ignored as they are part of the DHT11’s initial response.
For each data bit, it determines if the bit is 0 or 1 based on the duration the pin stays high.
if ((i >= 4) && (i % 2 == 0)) { dht11_dat[j/8] <<= 1; if (counter > 16) { dht11_dat[j/8] |= 1; } j++; }
Checksum Verification: After receiving all bits, the code verifies the checksum to ensure data integrity.
If the checksum is correct, it prints out the humidity and temperature values.
f = dht11_dat[2] * 9.0 / 5.0 + 32; printf("Humidity = %d.%d %% Temperature = %d.%d °C (%.1f °F)\n", dht11_dat[0], dht11_dat[1], dht11_dat[2], dht11_dat[3], f);
If the checksum fails, it prints an error message.
else { printf("Data not good, skip\n"); }
Main Function:
Prints a starting message.
Initializes wiringPi using BCM GPIO pin numbering.
if (wiringPiSetupGpio() == -1) { exit(1); }
Enters an infinite loop to read data from the DHT11 sensor every second.
while(1) { read_dht11_dat(17); delay(1000); // wait 1 second }
For Python Language Users
Step 3: Run the executable file.
sudo python3 2.2.3_DHT.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
from gpiozero import OutputDevice, InputDevice
class DHT11():
MAX_DELAY_COUINT = 100
BIT_1_DELAY_COUNT = 10
BITS_LEN = 40
def __init__(self, pin, pull_up=False):
self._pin = pin
self._pull_up = pull_up
def read_data(self):
bit_count = 0
delay_count = 0
bits = ""
# -------------- send start --------------
gpio = OutputDevice(self._pin)
gpio.off()
time.sleep(0.02)
gpio.close()
gpio = InputDevice(self._pin, pull_up=self._pull_up)
# -------------- wait response --------------
while gpio.value == 1:
# -------------- read data --------------
while bit_count < self.BITS_LEN:
while gpio.value == 0:
# st = time.time()
delay_count += 1
# break
if delay_count > self.MAX_DELAY_COUINT:
break
if delay_count > self.BIT_1_DELAY_COUNT:
bits += "1"
bits += "0"
delay_count = 0
bit_count += 1
# -------------- verify --------------
humidity_integer = int(bits[0:8], 2)
humidity_decimal = int(bits[8:16], 2)
temperature_integer = int(bits[16:24], 2)
temperature_decimal = int(bits[24:32], 2)
check_sum = int(bits[32:40], 2)
_sum = humidity_integer + humidity_decimal + temperature_integer + temperature_decimal
# print(bits)
# print(humidity_integer, humidity_decimal, temperature_integer, temperature_decimal)
# print(f'sum:{_sum}, check_sum:{check_sum}')
# print()
if check_sum != _sum:
humidity = 0.0
temperature = 0.0
humidity = float(f'{humidity_integer}.{humidity_decimal}')
temperature = float(f'{temperature_integer}.{temperature_decimal}')
# -------------- return --------------
return humidity, temperature
if __name__ == '__main__':
dht11 = DHT11(17)
humidity, temperature = dht11.read_data()
print(f"{time.time():.3f} temperature:{temperature}°C humidity: {humidity}%")
time.sleep(2)
Code Explanation
bit_count = 0
delay_count = 0
bits = ""
gpio.off()
time.sleep(0.02)
gpio.close()
This function is used to implement the functions of DHT11. It stores the
detected data in the bits[] array. DHT11 transmits data of 40 bits
at a time. The first 16 bits are related to humidity, the middle 16 bits
are related to temperature, and the last eight bits are used for
verification. The data format is:
8bit humidity integer data +8bit humidity decimal data
+8bit temperature integer data + 8bit temperature decimal data
+ 8bit check bit.
When the validity is detected via the check bit, the function returns two results: 1. error; 2. humidity and temperature.
humidity = 0.0
temperature = 0.0
For example, if the received date is 00101011``(8-bit value of humidity
integer) ``00000000 (8-bit value of humidity decimal) 00111100 (8-bit
value of temperature integer) 00000000 (8-bit value of temperature
decimal) 01100111 (check bit)
Calculation:
00101011+00000000+00111100+00000000=01100111.
If the final result is equal to the check bit data, the data transmission is abnormal: return False.
If the final result is equal to the check bit data, the received data is
correct, then there will return humidity and temperature and output
"Humidity =43%,Temperature =60C".
Phenomenon Picture
