2.2.2 Thermistor
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/2.2.2_thermistor_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Thermistor
ADC0834
Schematic Diagram
../_images/2.2.2_thermistor_schematic_1.png ../_images/2.2.2_thermistor_schematic_2.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.2_thermistor_circuit.png
cd ~/raphael-kit/python-pi5
Step 3: Run the executable file
sudo python3 2.2.2_Thermistor_zero.py
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
 # -*- coding: utf-8 -*-
import ADC0834
 import math
# Initialize the ADC0834 module
ADC0834.setup()
# Run the process in a try-except block
        # Read the analog value from the sensor
        # Convert the analog value to a voltage
        Vr = 5 * float(analogVal) / 255
        # Calculate the resistance of the thermistor
        Rt = 10000 * Vr / (5 - Vr)
        # Calculate the temperature in Kelvin
        temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25)))
        # Convert Kelvin to Celsius
        Cel = temp - 273.15
        # Convert Celsius to Fahrenheit
         Fah = Cel * 1.8 + 32
        # Print the temperature in both Celsius and Fahrenheit
        print('Celsius: %.2f C  Fahrenheit: %.2f F' % (Cel, Fah))
        # Wait for 0.2 seconds before the next read
         time.sleep(0.2)
# Handle KeyboardInterrupt for graceful termination
    # Clean up ADC0834 resources
    ADC0834.destroy()
Code Explanation
  1. This section imports the ADC0834 library for analog-to-digital conversion, the time library for implementing delays, and the math library for conducting mathematical operations.
    import ADC0834
    import math
  2. Initializes the ADC0834 module to enable reading of analog values.
    ADC0834.setup()
  3. Implements an infinite loop for continuous data reading. The loop reads the analog value from a thermistor, converts this value to voltage, calculates the thermistor’s resistance, and then translates this resistance into temperature measurements in Kelvin, Celsius, and Fahrenheit. It also outputs the temperature readings in Celsius and Fahrenheit, pausing for 0.2 seconds between each reading.
            Cel = temp - 273.15
            time.sleep(0.2)
  4. Catches a KeyboardInterrupt exception to gracefully terminate the program and includes clean-up instructions for the ADC0834 resources upon termination.
        ADC0834.destroy()
