2.2.6 Speed Sensor Module
In this project, we will learn the use of the speed sensor module. A Speed sensor module is a type of tachometer that is used to measure the speed of a rotating object like a motor.
../_images/2.2.6_photo_interrrupter_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Speed Sensor Module
Schematic Diagram
../_images/2.2.6_photo_interrrupter_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.6_photo_interrrupter_circuit.png
Step 2: Change directory.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.2.6_speed_sensor_module_zero.py
After the code runs, the green LED will light up. If you place an obstacle in the gap of the speed sensor module, the “light blocked” will be printed on the screen and the red LED will be lit. Remove the obstacle and the green LED will light up again.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED, Button
from signal import pause
# Initialize GPIO pins for the speed sensor and LEDs using GPIO Zero library
speed_sensor = Button(17, pull_up=False)  # Speed sensor connected to GPIO pin 17 without pull-up
green_led = LED(27)                      # Green LED connected to GPIO pin 27
red_led = LED(22)                        # Red LED connected to GPIO pin 22
def update_leds():
    Update the state of LEDs based on the speed sensor.
    - If the sensor is pressed (triggered), the red LED is turned on and a message is printed.
    - If the sensor is released (not triggered), the green LED is turned on.
    if speed_sensor.is_pressed:
        green_led.off()  # Turn off green LED
        red_led.on()     # Turn on red LED
        print('Light was blocked')  # Print message indicating sensor is triggered
        green_led.on()   # Turn on green LED
        red_led.off()    # Turn off red LED
    # Main loop to continuously check sensor state
        # Update LEDs based on sensor state changes
        speed_sensor.when_pressed = update_leds   # Update LEDs when sensor is pressed
        speed_sensor.when_released = update_leds  # Update LEDs when sensor is released
    # Handle KeyboardInterrupt (Ctrl+C) for a graceful script termination
Code Explanation
  1. The gpiozero library is imported to use its LED and Button classes for interacting with the GPIO pins. The signal library is imported for the pause function, which is used to keep the script running.
  2. speed_sensor is set as a Button on GPIO pin 17. The pull_up=False parameter indicates that the internal pull-up resistor is not used. green_led and red_led are initialized as LED objects connected to GPIO pins 27 and 22, respectively.
  3. The update_leds function checks the state of the speed sensor. If the sensor is pressed (activated), it turns off the green LED, turns on the red LED, and prints a message. If the sensor is released, it does the opposite.
    def update_leds():
  4. The main loop continuously checks the state of the speed sensor. The when_pressed and when_released attributes are event handlers that call the update_leds function when the sensor state changes. The try-except block is for handling a KeyboardInterrupt for a graceful exit.
