2.2.5 IR Obstacle Avoidance Sensor
In this project, we will learn IR obstacle avoidance module, which is a sensor module that can be used to detect obstacles at short distances, with small interference, easy to assemble, easy to use, etc. It can be widely used in robot obstacle avoidance, obstacle avoidance trolley, assembly line counting, etc.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit
Step 2: Change directory.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.2.5_IrObstacle_zero.py
After the code runs, when you put your hand in front of the module’s probe, the output indicator on the module lights up and the “Detected Barrier!” will be repeatedly printed on the screen until the your hand is removed.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import Button
# Initialize the obstacle sensor connected to GPIO pin 17
# The sensor is configured with a pull-up resistor
obstacle_sensor = Button(17, pull_up=True)
# Continuously monitor for obstacles
if obstacle_sensor.is_pressed: # Check if the sensor is triggered
print("Detected Barrier!") # Print a message when an obstacle is detected
time.sleep(1) # Delay for 1 second to avoid repetitive messages
# Handle KeyboardInterrupt (Ctrl+C) for a clean and safe exit
Code Explanation
This line sets the script to run using Python 3. It imports the
Buttonclass from gpiozero (used for the obstacle sensor) and thetimemodule for delays.#!/usr/bin/env python3 from gpiozero import Button import time
Initializes an obstacle sensor connected to GPIO pin 17 with an internal pull-up resistor.
# Initialize the obstacle sensor connected to GPIO pin 17 # The sensor is configured with a pull-up resistor obstacle_sensor = Button(17, pull_up=True)
In a continuous loop, the program checks if the obstacle sensor is activated (
is_pressed). If an obstacle is detected, it prints “Detected Barrier!” and then waits for one second (to prevent repetitive messages). Thetry-exceptstructure is used to handle a KeyboardInterrupt for a clean exit.try: # Continuously monitor for obstacles while True: if obstacle_sensor.is_pressed: # Check if the sensor is triggered print("Detected Barrier!") # Print a message when an obstacle is detected time.sleep(1) # Delay for 1 second to avoid repetitive messages except KeyboardInterrupt: # Handle KeyboardInterrupt (Ctrl+C) for a clean and safe exit pass
