2.2.7 PIR
In this project, we will make a device by using the human body infrared pyroelectric sensors. When someone gets closer to the LED, the LED will turn on automatically. If not, the light will turn off. This infrared motion sensor is a kind of sensor that can detect the infrared emitted by human and animals.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/python-pi5
Step 3: Run the executable file.
sudo python3 2.2.7_PIR_zero.py
After the code runs, PIR detects surroundings and let RGB LED glow yellow if it senses someone walking by.
There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import RGBLED, MotionSensor
from time import sleep
# Initialize RGB LED and PIR motion sensor using GPIO Zero library
led = RGBLED(red=18, green=27, blue=22) # RGB LED connected to GPIO pins 18 (Red), 27 (Green), 22 (Blue)
pir = MotionSensor(17) # PIR sensor connected to GPIO pin 17
# Continuously monitor for motion and update LED color
if pir.motion_detected: # Check for motion detected by PIR sensor
led.color = (1, 1, 0) # Set LED color to yellow (Red + Green)
led.color = (0, 0, 1) # Set LED color to blue (only Blue)
sleep(0.1) # Short delay to reduce CPU load
# Handle KeyboardInterrupt (Ctrl+C) to exit the loop gracefully
Code Explanation
Imports the
RGBLEDclass for controlling an RGB LED and theMotionSensorclass for motion detection from the GPIO Zero library. Also imports thesleepfunction for creating delays.#!/usr/bin/env python3 from gpiozero import RGBLED, MotionSensor from time import sleep
Initializes an RGB LED with red, green, and blue components connected to GPIO pins 18, 27, and 22, respectively. Also, initializes a PIR sensor on GPIO pin 17.
# Initialize RGB LED and PIR motion sensor using GPIO Zero library led = RGBLED(red=18, green=27, blue=22) # RGB LED connected to GPIO pins 18 (Red), 27 (Green), 22 (Blue) pir = MotionSensor(17) # PIR sensor connected to GPIO pin 17
The program enters an infinite loop, continuously checking for motion using the PIR sensor. If motion is detected, the LED is set to yellow (mix of red and green). If no motion is detected, the LED turns blue. A short sleep of 0.1 seconds reduces CPU load.
try: # Continuously monitor for motion and update LED color while True: if pir.motion_detected: # Check for motion detected by PIR sensor led.color = (1, 1, 0) # Set LED color to yellow (Red + Green) else: led.color = (0, 0, 1) # Set LED color to blue (only Blue) sleep(0.1) # Short delay to reduce CPU load except KeyboardInterrupt: # Handle KeyboardInterrupt (Ctrl+C) to exit the loop gracefully pass
