2.2.1 Photoresistor
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/python-pi5
Step 3: Run the executable file.
sudo python3 2.2.1_Photoresistor_zero.py
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import PWMLED
import ADC0834
# Initialize a PWM LED on GPIO pin 22
led = PWMLED(22)
# Set up the ADC0834 module
ADC0834.setup()
# Define a function for mapping values from one range to another
# Main loop for reading ADC value and controlling LED brightness
def loop():
# Read analog value from ADC
print('value = %d' % analogVal)
# Map the ADC value to a PWM value and set LED brightness
led.value = float(analogVal/255)
# Wait for 0.2 seconds
time.sleep(0.2)
# Run the main loop and handle KeyboardInterrupt for graceful shutdown
loop()
# Turn off LED before exiting
led.value = 0
Code Explanation
This segment imports the PWMLED class from the gpiozero library, necessary for controlling PWM LEDs. It also includes the ADC0834 module for interfacing with the analog-to-digital converter, and the time module for executing time-based functions such as sleep.
#!/usr/bin/env python3 from gpiozero import PWMLED import ADC0834 import time
Initializes a PWM LED connected to GPIO pin 22 and sets up the ADC0834 module, preparing it for use in the project.
# Initialize a PWM LED on GPIO pin 22 led = PWMLED(22) # Set up the ADC0834 module ADC0834.setup()
Defines a function to map an input value from one range to another. This function is crucial for translating the ADC readings into a suitable range for PWM control.
# Define a function for mapping values from one range to another def MAP(x, in_min, in_max, out_min, out_max): return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
This section contains a loop that continuously reads the analog value from the ADC0834, maps it to a corresponding PWM value, and adjusts the LED brightness. A brief delay (time.sleep(0.2)) is included to make the changes visible and to avoid overburdening the CPU.
# Main loop for reading ADC value and controlling LED brightness def loop(): while True: # Read analog value from ADC analogVal = ADC0834.getResult() print('value = %d' % analogVal) # Map the ADC value to a PWM value and set LED brightness led.value = float(analogVal/255) # Wait for 0.2 seconds time.sleep(0.2)
Executes the loop function and includes error handling for a graceful shutdown on KeyboardInterrupt. It ensures the LED is turned off when the program is stopped.
# Run the main loop and handle KeyboardInterrupt for graceful shutdown try: loop() except KeyboardInterrupt: # Turn off LED before exiting led.value = 0
