7. PiDog 发声
PiDog 可以发出声音,实际上是播放一段音频文件。
这些音频文件保存在 pidog\sounds 路径下,你可以调用以下函数进行播放:
Pidog.speak(name)
  • name:音频文件名(不带后缀),如 "angry"Pidog 目前提供以下音效文件:
    • "angry" —— 愤怒
    • "confused_1" —— 疑惑1
    • "confused_2" —— 疑惑2
    • "confused_3" —— 疑惑3
    • "growl_1" —— 低吼1
    • "growl_2" —— 低吼2
    • "howling" —— 嚎叫
    • "pant" —— 喘气
    • "single_bark_1" —— 吠叫1
    • "single_bark_2" —— 吠叫2
    • "snoring" —— 打鼾
    • "woohoo" —— 欢呼
以下是一个使用示例:
# !/usr/bin/env python3
''' play sound effecfs
    Note that you need to run with "sudo"
API:
    Pidog.speak(name, volume=100)
        play sound effecf in the file "../sounds"
        - name    str, file name of sound effect, no suffix required, eg: "angry"
        - volume  int, volume 0-100, default 100
from pidog import Pidog
import os
# 切换工作目录
abspath = os.path.abspath(os.path.dirname(__file__))
# print(abspath)
os.chdir(abspath)
my_dog = Pidog()
print("\033[033mNote that you need to run with \"sudo\", otherwise there may be no sound.\033[m")
# my_dog.speak("angry")
# time.sleep(2)
for name in os.listdir('../sounds'):
    name = name.split('.')[0] # 去除文件后缀
    print(name)
    my_dog.speak(name)
    # my_dog.speak(name, volume=50)
    time.sleep(3) # 每段音效的时长不同,建议适当等待
print("closing ...")
my_dog.close()
