8.7 Setup a Web Server
In this article, you will learn how to make Pico 2 W a web server that allows you to operate the circuit and get readings from the sensor from a browser.
setup_web
1. Required Components
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
4(1-330Ω, 2-220Ω, 1-10KΩ)
RGB LED
Thermistor
Li-po Charger Module
Power Pack
2. Build the Circuit
Warning
Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your Power Pack and circuitry.
../../_images/7.web_page_bb.png
3. Run the Code
Before running the code, you need to make sure you have do_connect.py and secrets.py scripts in your Pico 2 W, if not please refer to 8.1 Access to the Network to create them.
  1. Open the 7_web_page.py file under the path of pico-2w-kit-main/micropython/iot.
  2. Click the Run current script button or press F5 to run it. After successful connection, you will see the IP of Pico 2 W.
    ../../_images/7_web_server.png
  3. Enter the IP address of the Pico 2 W into your browser to access the web page built for this project. Click any button to change the color of the RGB LEDs and refresh the temperature and humidity.
  4. If you want this script to be able to boot up, you can save it to the Raspberry Pi Pico 2 W as main.py.
How it works?
This project requires a network connection, use the 8.1 Access to the Network method to connect to the network.
from secrets import *
from do_connect import *
from do_connect import * : This imports the do_connect() function, which contains the logic for connecting to Wi-Fi using the network module. Once the do_connect() function is called, it will connect to the Wi-Fi network specified in secrets.py. If the connection fails, it will raise an exception; if successful, the next step will proceed.
from secrets import * : The secrets.py file is typically a separate file used to store your Wi-Fi SSID, password, and other sensitive information (such as API keys). This helps avoid embedding sensitive information directly in the main code file.
The web page you are visiting is actually hosted on some server, and the socket on the server will send the web page to us when we visit it. A socket is the way a server can listen for a client that wants to connect to it.
In this project, Pico 2 W is your server, and your computer is accessing the web page hosted on Pico 2 W through a browser.
First we create a socket, which requires an IP address and a port. The network connection and the way to get the IP are described in 8.1 Access to the Network. And for port, we use 80. After setting up the socket, return it and use it for the next step.
socket library - Python Docs
import socket
def open_socket(ip):
    # Open a socket
    address = (ip, 80)
    connection = socket.socket()
    connection.bind(address)
    connection.listen(1)
    print(connection)
    return(connection)
Then, set up your web service where the socket you set up earlier will be used. The following code will allow your Pico 2 W to receive access requests from your browser.
def serve(connection):
        client = connection.accept()[0]
        request = client.recv(1024)
        client.close()
Next, you need an html page to send to the visitor. This example stores a simple html page in the form of characters in the variable html.
If you want to be able to write your own html, you can get help at HTML.COM.
def webpage(value):
    html = f"""
            <!DOCTYPE html>
            <html>
            <body>
            <form action="./red">
            <input type="submit" value="red " />
            </form>
            <form action="./green">
            <input type="submit" value="green" />
            </form>
            <form action="./blue">
            <input type="submit" value="blue" />
            </form>
            <form action="./off">
            <input type="submit" value="off" />
            </form>
            <p>Temperature is {value} degrees Celsius</p>
            </body>
            </html>
    return html
Send html page to visitor.
        html=webpage(0)
        client.send(html)
        client.close()
The page can be accessed through your browser if you combine the above parts. If you want to see the effect, run the code below with thonny.
import machine
import socket
def webpage(value):
    html = f"""
            <!DOCTYPE html>
            <html>
            <body>
            </form>
            </form>
            </form>
            </form>
            </body>
            </html>
    return html
    # Open a socket
    address = (ip, 80)
    print(connection)
    return(connection)
        html=webpage(0)
        client.send(html)
        client.close()
    ip=do_connect()
    if ip is not None:
        connection=open_socket(ip)
        serve(connection)
    machine.reset()
When you run the code above, you will see that it displays only a web page, does not allow you to control RGB LEDs, nor does it show sensor readings. The web service needs to be refined further.
The first thing we need to know is what information the server receives when the browser accesses the web page. Therefore, change serve() slightly to print request.
        request = str(request)
        print(request)
        html=webpage(0)
        client.send(html)
        client.close()
Re-run the script and the Shell will print the following message when we press a key on the web page.
b'GET /red? HTTP/1.1\r\nHost: 192.168.18.162\r\nConnection: keep-alive.......q=0.5\r\n\r\n'
b'GET /favicon.ico HTTP/1.1\r\nHost: 192.168.18.162\r\nConnection: keep-alive.......q=0.5\r\n\r\n'
b'GET /blue? HTTP/1.1\r\nHost: 192.168.18.162\r\nConnection: keep-alive.......q=0.5\r\n\r\n'
They are too long to read!!!
But all we really need is the small piece of information in front of /red?, /blue?. It tells us which button was pressed. So we refined serve() a bit to extract the keystroke information.
            request = request.split()[1]
        except IndexError:
        print(request)
        html=webpage(0)
        client.send(html)
        client.close()
Re-run the program and the Shell will print the following message when we press a key on the web page.
/red?
/favicon.ico
/blue?
/favicon.ico
/off?
/favicon.ico
Then, we just need to change the color of the RGB LED according to the value of request.
        except IndexError:
        print(request)
        if request == '/off?':
            red.low()
            green.low()
            blue.low()
        elif request == '/red?':
            red.high()
            green.low()
            blue.low()
        elif request == '/green?':
            red.low()
            green.high()
            blue.low()
        elif request == '/blue?':
            red.low()
            green.low()
            blue.high()
        html=webpage(0)
        client.send(html)
        client.close()
The last thing is to display the thermistor value on the web page (see 2.13 Thermometer for details on using the thermistor). This part is actually done by modifying the text on the html. We set the parameters in the webpage(value) function and simply change the incoming parameters to change the number displayed on the web page.
        except IndexError:
        #print(request)
            red.low()
            green.low()
            blue.low()
            red.high()
            green.low()
            blue.low()
            red.low()
            green.high()
            blue.low()
            red.low()
            green.low()
            blue.high()
        value='%.2f'%temperature()
        html=webpage(value)
        client.send(html)
        client.close()
