8.2 Follow the @CheerLights
This is a romantic project, join the @CheerLights - Twitter LED color-changing community, which allows LEDs all over the world to change colors simultaneously.
You can place it in a corner of your office to remind yourself that you are not alone.
You can tweeting @cheerlights and including the color name in the tweet. This will change the LEDs around the world to the color you specify.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
7 |
Power Pack |
Steps
Build the circuit.
Switch the path to the folder where you downloaded the code package before and open the
8.2_cheer_light.pyfile under the path ofpico-2w-kit-main/micropython/iot.- To run the script, click the Run current script button or press F5, then you will see the connected prompt, the IP and the color (0xff0000 is red) in the Shell.
Before running the code, you need to create
do_connect.pyandsecrets.pyscripts in your Pico 2 W, please refer to 8.1 Access to the Network to create them.
Control global @CheerLights devices
Join the Discord Server and utilize the CheerLights bot to set the color. Simply type
/cheerlightsin any of the channels on the CheerLights Discord Server to activate the bot.
Follow the instructions provided by the bot to set the color. This will allow you to control CheerLights devices globally.
After the script runs, the WS2812 RGB strip will show a color, sometimes the color will change.
If you want to run this script on boot, you need to save it to the Raspberry Pi Pico 2 W as
main.py, as follows.Stop the script from running and click File -> Save as.
Select Raspberry Pi Pico in the popup window that appears.
Set the file name to
main.py. A prompt will appear if the same file already exists on your Pico 2 W.
You can now unplug the USB cable and use the Li-po Charger Module to power the Raspberry Pi Pico 2 W. Put it in a corner and it will work automatically.
How it works?
This project requires a network connection, use the network module to connect to the network. You can learn how to use the network module by referring to 8.1 Access to the Network.
from secrets import *
from do_connect import *
do_connect()
from do_connect import * : This imports the do_connect() function, which contains the logic for connecting to Wi-Fi using the network module. Once the do_connect() function is called, it will connect to the Wi-Fi network specified in secrets.py. If the connection fails, it will raise an exception; if successful, the next step will proceed.
from secrets import * : The secrets.py file is typically a separate file used to store your Wi-Fi SSID, password, and other sensitive information (such as API keys). This helps avoid embedding sensitive information directly in the main code file.
Set WS2812 RGB strip, please refer to 3.3 RGB LED Strip for its usage details.
import machine
from ws2812 import WS2812
ws = WS2812(machine.Pin(18), 8)
Now, we need a way to get the color of @CheerLights. There is a back-end system that takes the color changes from Twitter and posts them in JSON format to the URL: http://api.thingspeak.com/channels/1417/field/2/last.json.
If you open this URL directly in your browser, you will see something like the following. All we need is the field2 data, which is a hexadecimal color-coded string.
{"created_at":"2022-08-16T06:12:44Z","entry_id":870488,"field2":"#ff00ff"}
We need to use the urequests module to get this data and the json module to convert this character into a python dictionary.
The following code gets the latest @CheerLights color from the url and returns a color value that can be used by WS2812.
def get_colour():
url = "http://api.thingspeak.com/channels/1417/field/2/last.json"
r = urequests.get(url)
if r.status_code > 199 and r.status_code < 300:
cheerlights = json.loads(r.content.decode('utf-8'))
print(cheerlights['field2'])
colour = int('0x'+cheerlights['field2'][1:7])#Convert from String to Integer
r.close()
return colour
return None
except Exception as e:
print(e)
return None
Finally, use a loop to make the ws2812 work once every 5 seconds.
colour = get_colour()
if colour is not None:
ws.write_all(colour)
time.sleep(5)
