š Ready to explore and create with us? Click [here] and join today!
8.16 Bluetooth Lock Controllerļ
The project uses a Raspberry Pi Pico 2 W board with Bluetooth capabilities to create a smart lock system. The lockās servo motor, connected to the Pico 2 W, is controlled wirelessly via a custom mobile application. The app sends lock and unlock commands to the board using BLE (Bluetooth Low Energy) communication.
This project demonstrates how to use the Raspberry Pi Pico 2 W for IoT applications, integrating Bluetooth functionality with physical control mechanisms. It provides an engaging way to explore BLE communication and servo control using MicroPython.
The app used in this project was developed with MIT App Inventor.
1. Build the Circuitļ
Itās definitely convenient to buy a whole kit, hereās the link:
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
2. Create the Android Appļ
You will develop the Android application using MIT App Inventor, a free web application ideal for beginners in Android development. It offers intuitive drag-and-drop features for creating functional applications.
Follow these steps to get started:
Go to Get Started with MIT App Inventor, and click āonline toolā to login. You will need a Google account to register with MIT App Inventor.
After logging in, navigate to Projects -> Import project (.aia) from my computer. Subsequently, upload the
ble_lock_picow.aiafile located in the following path:pico-2w-kit/micropython/iot/8.16-ble_lock.Alternatively, you can download the file directly:
ble_lock_picow.aia
Once uploaded, the app template will appear in the MIT App Inventor interface. This pre-configured template can be customized after you become familiar with the platform.
MIT App Inventor has two main sections: Designer and Blocks. You can switch between these two sections in the upper right corner of the page.
The Designer allows you to add buttons, text, screens, and modify the overall aesthetic of your app.
Next, thereās the Blocks section. This section lets you craft custom functionalities for your app, allowing you to program each component on the appās GUI to achieve desired features.
To install the app on a phone, navigate to the Build tab.
Generate a
.apkfile. After selecting this option, a page will appear allowing you to choose between downloading a.apkfile or scanning a QR code for installation. Follow the installation guide to complete the application installation.Alternatively, download our pre-compiled APK file here:
ble_lock_picow.apkIf you wish to publish this app to Google Play or another app marketplace, you can generate a
.aabfile.
3. Run the Codeļ
Open the 8.16-ble_lock.py file under the path of pico-2w-kit/micropython/iot/8.16-ble_lock, or copy this code into your IDE.
This code depends on the ble_advertising.py file. Make sure to upload it to the Pico board before running the script.
import bluetooth
import random
import struct
from ble_example.ble_advertising import advertising_payload
from machine import Pin
import struct
from micropython import const
servo = machine.PWM(machine.Pin(15))
servo.freq(50)
_IRQ_CENTRAL_CONNECT = const(1)
_IRQ_CENTRAL_DISCONNECT = const(2)
_IRQ_GATTS_WRITE = const(3)
_FLAG_READ = const(0x0002)
_FLAG_WRITE_NO_RESPONSE = const(0x0004)
_FLAG_WRITE = const(0x0008)
_FLAG_NOTIFY = const(0x0010)
_LOCK_UUID = bluetooth.UUID("f3ac7f80-5045-47b0-88fe-24d858e2e92f")
_SWITCH_CHAR = (
bluetooth.UUID("808b6a74-8d38-4114-8cb7-0ac9465db42d"),
_FLAG_READ | _FLAG_WRITE | _FLAG_WRITE_NO_RESPONSE,
_LOCK_SERVICE = (
_LOCK_UUID,
(_SWITCH_CHAR,),
class BLELock:
def __init__(self, ble, name="PICO-LOCK"):
self._ble = ble
self._ble.active(True)
self._ble.irq(self._irq)
handles = self._ble.gatts_register_services((_LOCK_SERVICE,))
# print("Registered handles:", handles)
((self._handle_note,),) = handles
self._connections = set()
self._write_callback = None
self._payload = advertising_payload(name=name, services=[_LOCK_UUID])
self._advertise()
def _irq(self, event, data):
# Track connections so we can send notifications.
if event == _IRQ_CENTRAL_CONNECT:
conn_handle, _, _ = data
print("New connection", conn_handle)
self._connections.add(conn_handle)
elif event == _IRQ_CENTRAL_DISCONNECT:
print("Disconnected", conn_handle)
self._connections.remove(conn_handle)
# Start advertising again to allow a new connection.
self._advertise()
elif event == _IRQ_GATTS_WRITE:
conn_handle, value_handle = data
value = self._ble.gatts_read(value_handle)
# print("Write event: conn_handle={}, value_handle={}, value={}".format(conn_handle, value_handle, value))
if value_handle == self._handle_note and self._write_callback:
self._write_callback(value)
def is_connected(self):
return len(self._connections) > 0
def _advertise(self, interval_us=500000):
print("Starting advertising")
self._ble.gap_advertise(interval_us, adv_data=self._payload)
def on_write(self, callback):
self._write_callback = callback
def servo_write(pin,angle):
pulse_width=interval_mapping(angle, 0, 180, 0.5,2.5)
duty=int(interval_mapping(pulse_width, 0, 20, 0,65535))
pin.duty_u16(duty)
def lock_update(data):
print("Receive:", data)
decoded_data = struct.unpack('I', data)[0]
if decoded_data == 1:
servo_write(servo,90)
servo_write(servo,0)
def demo():
ble = bluetooth.BLE()
piano = BLELock(ble,"pico2w")
if piano.is_connected():
piano.on_write(lock_update)
# time.sleep_ms(100)
if __name__ == "__main__":
demo()
4. App and Bluetooth Connectionļ
Ensure that the āBluetooth controlled lock bleā app created earlier is installed on your phone.
Enable Bluetooth on your phone.
Open the Bluetooth controlled lock ble app.
When you open the app for the first time, you will see two consecutive prompts requesting permissions. These permissions are required for Bluetooth functionality.
In the APP, click the lock icon to establish a Bluetooth connection between the application and the Pico 2 W.
This page displays a list of all Bluetooth devices. Choose the
xx.xx.xx.xx.xx.xx pico2woption from the list. Each device name is displayed alongside its MAC address.
If no devices appear in the list, try enabling the location feature on your phone. (On some Android versions, the location setting is linked to Bluetooth functionality.)
Once connected, you will be redirected to the main screen. Click the unlock or lock button to control the servo motor, unlocking or locking it as needed.
