8.6 Cloud Player with @MQTT
It is recommended that you do the 8.5 Cloud Calling System with @MQTT project first to complete the installation of some modules and to complete the configuration of the HiveMQ platform.
In this project, Pico 2 W will act as a subscriber and receive the song name under the topic. If the song name is already in the code, Pico 2 W will make the buzzer play the song.
1. Required Components
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Transistor
1(S8050)
Resistor
1(1KΩ)
Passive Buzzer
Li-po Charger Module
Power Pack
2. Build the Circuit
Two buzzers are included in the kit, we use a passive buzzer (one with an exposed PCB on the back). The buzzer needs a transistor to work, here we use S8050.
Warning
Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your Power Pack and circuitry.
../../_images/6.mqtt_sub_bb.png
3. Run the Code
  1. Upload the play_music.py file under the path of pico-2w-kit-main/micropython/iot to the Raspberry Pi Pico 2 W.
    ../../_images/mqtt-A-1.png
  2. Open the 8.6_mqtt_subscribe_music.py file under the path of pico-2w-kit-main/micropython/iot and click the Run current script button or press F5 to run it.
    ../../_images/6_cloud_player.png
    Before running the code, you need to create do_connect.py and secrets.py scripts in your Pico 2 W, please refer to 8.1 Access to the Network to create them.
  3. Open HiveMQ Web Client in your browser, fill in the Topic as SunFounder MQTT Music, fill in the song name as Message. After clicking Publish button, the buzzer connected to the Pico 2 W will play the corresponding song.
    Included in play_music.py are nokia, starwars, nevergonnagiveyouup, gameofthrone, songofstorms, zeldatheme, harrypotter.
    ../../_images/mqtt-5.png
  4. If you want this script to be able to boot up, you can save it to the Raspberry Pi Pico 2 W as main.py.
How it works?
In order to make it easier to understand, we separated the MQTT code from the rest. As a result, you get the following code, which implements the most basic functionality of MQTT subscriptions in three places.
from umqtt.simple import MQTTClient
#This imports the `do_connect()` function, which contains the logic for connecting to Wi-Fi using the `network` module. Once the `do_connect()` function is called, it will connect to the Wi-Fi network specified in `secrets.py`. If the connection fails, it will raise an exception; if successful, the next step will proceed.
from do_connect import *
do_connect()
mqtt_server = 'broker.hivemq.com'
client_id = 'Jimmy'
# to subscribe the message
topic = b'SunFounder MQTT Music'
def callback(topic, message):
    print("New message on topic {}".format(topic.decode('utf-8')))
    message = message.decode('utf-8')
    print(message)
    client = MQTTClient(client_id, mqtt_server, keepalive=60)
    client.set_callback(callback)
    client.connect()
    print('Connected to %s MQTT Broker'%(mqtt_server))
except OSError as e:
    print('Failed to connect to MQTT Broker. Reconnecting...')
    time.sleep(5)
    machine.reset()
    client.subscribe(topic)
    time.sleep(1)
When connecting to the MQTT broker, we call the client.set_callback(callback) function, which serves as a callback for the received subscription messages.
    client.connect()
    time.sleep(5)
    machine.reset()
Next is the callback function, which prints out the message from the topic that was fetched. MQTT is a binary based protocol were the control elements are binary bytes and not text strings, so these messages need to be decoded using message.decode('utf-8').
    print(message)
Use a While True loop to get messages under this topic at regular intervals.
    time.sleep(1)
Next, music will be played. This function is placed in the play_music.py script, which consists of three main parts.
  • Tone: Simulates a specific tone based on the fundamental Piano key frequencies , which is used to play it.
    NOTE_B0 =  31
    NOTE_C1 =  33
    NOTE_DS8 = 4978
    REST =      0
  • Score: Edit the music into a format that the program can use. These scores are from Robson Couto’s free sharing, you can also add your favorite music in the following format.
# notes of the moledy followed by the duration.
# a 4 means a quarter note, 8 an eighteenth , 16 sixteenth, so on
# !!negative numbers are used to represent dotted notes,
# so -4 means a dotted quarter note, that is, a quarter plus an eighteenth!!
song = {
    "nokia":[NOTE_E5, 8, NOTE_D5, 8, NOTE_FS4, 4, NOTE_GS4, 4, NOTE_CS5, 8, NOTE_B4, 8, NOTE_D4, 4,
                NOTE_E4, 4,NOTE_B4, 8, NOTE_A4, 8, NOTE_CS4, 4, NOTE_E4, 4, NOTE_A4, 2],
    "starwars":[,,,],
    "nevergonnagiveyouup":[,,,],
    "gameofthrone":[,,,],
    "songofstorms":[,,,],
    "zeldatheme":[,,,],
    "harrypotter":[,,,],
import machine
# change this to make the song slower or faster
tempo = 220
# this calculates the duration of a whole note in ms
wholenote = (60000 * 4) / tempo
def tone(pin,frequency,duration):
    if frequency is 0:
        pin.freq(frequency)
        pin.duty_u16(30000)
    time.sleep_ms(duration)
    pin.duty_u16(0)
def noTone(pin):
    tone(pin,0,100)
def play(pin,melody):
    # iterate over the notes of the melody.
    # Remember, the array is twice the number of notes (notes + durations)
    for thisNote in range(0,len(melody),2):
        # calculates the duration of each note
        divider = melody[thisNote+1]
        if divider > 0:
            noteDuration = wholenote/divider
        elif divider < 0:
            noteDuration = wholenote/-(divider)
            noteDuration *= 1.5
        # we only play the note for 90% of the duration, leaving 10% as a pause
        tone(pin,melody[thisNote],int(noteDuration*0.9))
        # Wait for the specief duration before playing the next note.
        time.sleep_ms(int(noteDuration))
        # stop the waveform generation before the next note.
        noTone(pin)
Go back to the main function and let MQTT trigger music playback. In the callback function, determine if the message sent is the name of a song that has been included. If it is, assign the song name to the variable melody and set play_flag to True.
    print(message)
    if message in song.keys():
        global melody,play_flag
        melody = song[message]
        play_flag = True
In the main loop, if play_flag is True, play melody.
    time.sleep(1)
    if play_flag is True:
        play(buzzer,melody)
        play_flag = False
