8.15 Bluetooth Voice-control Relay
This project demonstrates the use of a Raspberry Pi Pico 2 W to control a relay through Bluetooth Low Energy (BLE). The Pico W receives BLE commands from a smartphone or other BLE-capable device. When it receives a “1” signal, the relay is switched on, and when it receives a “0” signal, the relay is switched off.
This project is ideal for those exploring BLE communication and IoT applications with the Raspberry Pi Pico 2 W.
1. Build the Circuit
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Transistor
1(S8050)
Diode
Resistor
1(1KΩ) 1(220Ω)
Relay
Li-po Charger Module
Power Pack
Warning
This example demonstrates how to use a relay to control an LED. While the relay can connect to other appliances in practical applications, exercise extreme caution when working with high AC voltage. Improper or incorrect use may result in serious injury or death. Always prioritize safety.
../../_images/8.15_bb.png
1. Create the Android App
You will develop the Android application using MIT App Inventor, a free web application ideal for beginners in Android development. It offers intuitive drag-and-drop features for creating functional applications.
Follow these steps to get started:
  1. Go to Get Started with MIT App Inventor, and click “online tool” to login. You will need a Google account to register with MIT App Inventor.
    ../../_images/13-ai-signup.png
  2. After logging in, navigate to Projects -> Import project (.aia) from my computer. Subsequently, upload the ble_relay_picow.aia file located in the following path: pico-2w-kit/micropython/iot/8.15-ble_relay.
    Alternatively, you can download the file directly: ble_relay_picow.aia
    ../../_images/13-ai-import.png
  3. Once uploaded, the app template will appear in the MIT App Inventor interface. This pre-configured template can be customized after you become familiar with the platform.
  4. MIT App Inventor has two main sections: Designer and Blocks. You can switch between these two sections in the upper right corner of the page.
    ../../_images/13-ai-intro-1.png
  5. The Designer allows you to add buttons, text, screens, and modify the overall aesthetic of your app.
    ../../_images/15-ai-intro-2.png
  6. Next, there’s the Blocks section. This section lets you craft custom functionalities for your app, allowing you to program each component on the app’s GUI to achieve desired features.
    ../../_images/15-ai-intro-3.png
  7. To install the app on a phone, navigate to the Build tab.
    ../../_images/13-ai-intro-4.png
    • Generate a .apk file. After selecting this option, a page will appear allowing you to choose between downloading a .apk file or scanning a QR code for installation. Follow the installation guide to complete the application installation.
      Alternatively, download our pre-compiled APK file here: ble_relay_picow.apk
    • If you wish to publish this app to Google Play or another app marketplace, you can generate a .aab file.
3. Run the Code
Open the 8.15-ble_relay.py file under the path of pico-2w-kit/micropython/iot/8.15-ble_relay, or copy this code into your IDE.
This code depends on the ble_advertising.py file. Make sure to upload it to the Pico board before running the script.
import bluetooth
import random
import struct
from ble_example.ble_advertising import advertising_payload
from machine import Pin
from micropython import const
relay = machine.Pin(15, machine.Pin.OUT)
_IRQ_CENTRAL_CONNECT = const(1)
_IRQ_CENTRAL_DISCONNECT = const(2)
_IRQ_GATTS_WRITE = const(3)
_FLAG_READ = const(0x0002)
_FLAG_WRITE_NO_RESPONSE = const(0x0004)
_FLAG_WRITE = const(0x0008)
_FLAG_NOTIFY = const(0x0010)
_RELAY_UUID = bluetooth.UUID("46719f98-3141-4bbb-aede-47a7630d024b")
_SWITCH_CHAR = (
    bluetooth.UUID("08b82cd0-6877-4308-b08d-a32520c327a2"),
    _FLAG_READ | _FLAG_WRITE | _FLAG_WRITE_NO_RESPONSE,
_RELAY_SERVICE = (
    _RELAY_UUID,
    (_SWITCH_CHAR,),
class BLERelay:
    def __init__(self, ble, name="ble-relay"):
        self._ble = ble
        self._ble.active(True)
        self._ble.irq(self._irq)
        handles = self._ble.gatts_register_services((_RELAY_SERVICE,))
        # print("Registered handles:", handles)
        ((self._handle_note,),) = handles
        self._connections = set()
        self._write_callback = None
        self._payload = advertising_payload(name=name, services=[_RELAY_UUID])
        self._advertise()
    def _irq(self, event, data):
        # Track connections so we can send notifications.
        if event == _IRQ_CENTRAL_CONNECT:
            conn_handle, _, _ = data
            print("New connection", conn_handle)
            self._connections.add(conn_handle)
        elif event == _IRQ_CENTRAL_DISCONNECT:
            print("Disconnected", conn_handle)
            self._connections.remove(conn_handle)
            # Start advertising again to allow a new connection.
            self._advertise()
        elif event == _IRQ_GATTS_WRITE:
            conn_handle, value_handle = data
            value = self._ble.gatts_read(value_handle)
            # print("Write event: conn_handle={}, value_handle={}, value={}".format(conn_handle, value_handle, value))
            if value_handle == self._handle_note and self._write_callback:
                self._write_callback(value)
    def is_connected(self):
        return len(self._connections) > 0
    def _advertise(self, interval_us=500000):
        print("Starting advertising")
        self._ble.gap_advertise(interval_us, adv_data=self._payload)
    def on_write(self, callback):
        self._write_callback = callback
def relay_update(data):
    print("Receive:", data)
    decoded_data = int(data.decode('utf-8').rstrip('\x00'))
    # print(decoded_data)
    relay.value(decoded_data)
def demo():
    ble = bluetooth.BLE()
    relay = BLERelay(ble,"pico2w")
        if relay.is_connected():
            relay.on_write(relay_update)
        # time.sleep_ms(100)
if __name__ == "__main__":
    demo()
4. App and Bluetooth Connection
Ensure that the “Voice-Controlled Relay BLE” app created earlier is installed on your phone.
  1. Enable Bluetooth on your phone.
  2. Open the Voice-Controlled Relay BLE app.
    ../../_images/15_app_2.png
  3. When you open the app for the first time, you will see two consecutive prompts requesting permissions. These permissions are required for Bluetooth functionality.
    ../../_images/15_app_3.png
  4. In the APP, click on Connect button to establish a connection between the APP and Pico 2 W via bluetooth.
    ../../_images/15_app_4.png
  5. This page displays a list of all Bluetooth devices. Choose the xx.xx.xx.xx.xx.xx pico2w option from the list. Each device name is displayed alongside its MAC address.
    ../../_images/13_app_5.png
  6. If no devices appear in the list, try enabling the location feature on your phone. (On some Android versions, the location setting is linked to Bluetooth functionality.)
  7. Once connected, you will be redirected to the main screen. Tap the microphone icon to control the relay using voice commands. If your voice command contains “on,” the relay will activate. If it contains “off,” the relay will deactivate.
    ../../_images/15_app_7.png
