šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
3.2 Play Custom Tones with a Passive Buzzer
In this lesson, we’ll learn how to use a passive buzzer with the Raspberry Pi Pico 2 W to play different tones and even simple melodies! Unlike an active buzzer, a passive buzzer needs a changing electrical signal to produce sound, which means we can control the pitch of the sound by changing the signal’s frequency.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Transistor
1(S8050)
Resistor
1(1KĪ©)
Passive Buzzer
Understanding the Passive Buzzer
A passive buzzer works like a tiny speaker. It doesn’t produce sound on its own; instead, it needs an oscillating signal to make sound. By providing signals of different frequencies, we can make the buzzer produce different pitches, allowing us to play notes and melodies.
img_buzzer
Circuit Diagram
sch_buzzer
In this circuit, the passive buzzer is powered through a transistor (S8050 NPN). The transistor amplifies the current, making the buzzer sound louder than if it were connected directly to the Pico.
Here’s what happens:
  • GP15 outputs a high signal to control the transistor.
  • When the transistor is activated, it allows current to flow through the buzzer, making it beep.
A 1kΩ resistor is used to limit the current to protect the transistor.
Wiring Diagram
Make sure you are using the passive buzzer. You can tell it’s the correct one by looking for the exposed PCB (as opposed to the sealed back, which is a active buzzer).
img_buzzer
wiring_buzzer
Writing the Code
Now, let’s write some code to make the buzzer play different tones.
  • Open the 3.2_custom_tone.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click ā€œRunā€ or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize PWM on GP15
buzzer = machine.PWM(machine.Pin(15))
def play_tone(frequency, duration):
    # Set the frequency of the PWM signal
    buzzer.freq(frequency)
    # Set duty cycle to 50%
    buzzer.duty_u16(32768)
    # Play the tone for the specified duration
    utime.sleep_ms(duration)
    # Turn off the buzzer
    buzzer.duty_u16(0)
# Play some tones
play_tone(440, 500)  # A4 note for 500ms
utime.sleep_ms(200)
play_tone(494, 500)  # B4 note for 500ms
utime.sleep_ms(200)
play_tone(523, 500)  # C5 note for 500ms
When the code runs, you will hear the passive buzzer play the A4 note for 500ms, the B4 note for 500ms, and the C5 note for 500ms respectively.
Explanation of the Code
  1. Initialize PWM:
    • buzzer = machine.PWM(machine.Pin(15)): This sets up PWM (Pulse Width Modulation) on pin GP15, which we’ll use to control the buzzer.
  2. Define the play_tone Function:
        buzzer.duty_u16(0)
    • frequency: The pitch of the tone. Higher frequency means a higher pitch.
    • duration: How long the tone plays, in milliseconds.
    • buzzer.duty_u16(32768): Sets the duty cycle to 50% (half of 65535), which is ideal for generating sound.
    • After the duration, we turn off the buzzer by setting the duty cycle to 0.
  3. Play Notes:
    We call play_tone with different frequencies corresponding to musical notes.
    # Play some tones
    utime.sleep_ms(200)
    utime.sleep_ms(200)
Playing a Melody
Now that we’ve learned how to play individual tones with the passive buzzer, let’s create a simple melody! This will help us understand how to sequence notes and control their durations to produce music.
import machine
import utime
# Note frequencies (in Hz)
NOTE_C4 = 262
NOTE_D4 = 294
NOTE_E4 = 330
NOTE_F4 = 349
NOTE_G4 = 392
NOTE_A4 = 440
NOTE_B4 = 494
NOTE_C5 = 523
melody = [
    NOTE_C4, NOTE_D4, NOTE_E4, NOTE_F4,
    NOTE_G4, NOTE_A4, NOTE_B4, NOTE_C5
note_durations = [
    500, 500, 500, 500,
    500, 500, 500, 500
    buzzer.duty_u16(0)
    utime.sleep_ms(50)  # Short pause between notes
for i in range(len(melody)):
    play_tone(melody[i], note_durations[i])
When you run this code, the buzzer will play a simple melody by sounding each note in the sequence. Each note lasts for 500 milliseconds, and there’s a short pause between notes. You’ll hear the buzzer play an ascending scale from Middle C (C4) up to the next octave’s C (C5).
Experimenting Further
  • Create Your Own Melody: Change the notes and durations in the melody and note_durations lists to compose your own tune.
  • Adjust the Tempo: Modify the values in note_durations to speed up or slow down the melody.
  • Add More Notes: Define additional notes by adding their frequencies and include them in your melody.
  • Change the Volume: Adjust the duty cycle in buzzer.duty_u16() to make the buzzer louder or quieter. A value around 32768 gives 50% duty cycle.
Conclusion
In this lesson, you’ve learned how to use a passive buzzer to play tones and melodies with the Raspberry Pi Pico 2 W. By controlling the frequency of the PWM signal, you can create a variety of sounds and even play simple songs. This is a great way to add audio feedback or fun musical elements to your projects.
