13. Play Music and Sound Effects
In this project, you will learn how to make the PiCar-X play background music or sound effects. You can also play music files that you have stored.
Before You Start
Make sure you‘ve completed:
Run the Code
cd ~/picar-x/example
sudo python3 13.sound_background_music.py
After the code runs, please operate according to the prompt that printed on the terminal.
Input key to call the function!
  • space: Play sound effect (Car horn)
  • c: Play sound effect with threads
  • q: Play/Stop Music
from time import sleep
from picarx.music import Music
import readchar
music = Music()
manual = '''
    q: Play/Stop Music
def main():
    print(manual)
    flag_bgm = False
    music.music_set_volume(20)
        key = readchar.readkey()
        key = key.lower()
        if key == "q":
            flag_bgm = not flag_bgm
            if flag_bgm is True:
                music.music_play('../musics/slow-trail-Ahjay_Stelino.mp3')
                music.music_stop()
        elif key == readchar.key.SPACE:
            music.sound_play('../sounds/car-double-horn.wav')
            sleep(0.05)
        elif key == "c":
            music.sound_play_threading('../sounds/car-double-horn.wav')
            sleep(0.05)
if __name__ == "__main__":
    main()
How it works?
Functions related to background music include these:
  • music = Music() : Declare the object.
  • music.music_set_volume(20) : Set the volume, the range is 0~100.
  • music.music_play('../musics/slow-trail-Ahjay_Stelino.mp3') : Play music files, here is the slow-trail-Ahjay_Stelino.mp3 file under the ../musics path.
  • music.music_stop() : Stop playing background music.
You can add different sound effects or music to musics or sounds folder via FileZilla Software.
