15. AI Storytelling Robot with Piper and OpenAI
In the previous lesson, we tried two built-in TTS engines on Raspberry Pi (Espeak and Pico2Wave). Now let’s explore two more powerful options: Piper (offline, neural network-based) and OpenAI TTS (online, cloud-based).
  • Piper: a local TTS engine that runs offline on Raspberry Pi.
  • OpenAI TTS: an online service that provides very natural, human-like voices.
At the end, your PiCar-X will drive around and tell jokes like a little storyteller.
Before You Start
Make sure you‘ve completed:
1. Testing Piper
Steps to try it out:
  1. Create a new file:
    cd ~/picar-x/example
    sudo nano test_tts_piper.py
  2. Copy the example code below into the file. Press Ctrl+X, then Y, and finally Enter to save and exit.
    from picarx.tts import Piper
    tts = Piper()
    # List supported languages
    print(tts.available_countrys())
    # List models for English (en_us)
    print(tts.available_models('en_us'))
    # Set a voice model (auto-download if not already present)
    tts.set_model("en_US-amy-low")
    # Say something
    tts.say("Hello! I'm Piper TTS.")
    • available_countrys(): print supported languages.
    • available_models(): list available models for that language.
    • set_model(): set the voice model (downloads automatically if missing).
    • say(): convert text to speech and play it.
  3. Run the program:
    sudo python3 test_tts_piper.py
  4. The first time you run it, the selected voice model will be downloaded automatically.
    • You should then hear the PiCar-X say: Hello! I'm Piper TTS.
    • You can change to another language model by calling set_model() with a different name.
2. Testing OpenAI TTS
Get and save your API Key
  1. Go to OpenAI Platform and log in. On the API keys page, click Create new secret key.
  2. Fill in the details (Owner, Name, Project, and permissions if needed), then click Create secret key.
  3. Once the key is created, copy it right away — you won’t be able to see it again. If you lose it, you must generate a new one.
  4. In your project folder (for example: /picar-x/example), create a file called secret.py:
    sudo nano secret.py
  5. Paste your key into the file like this:
    # secret.py
    # Store secrets here. Never commit this file to Git.
    OPENAI_API_KEY = "sk-xxx"
Write and Run a Test Program
    sudo nano test_tts_openai.py
    from picarx.tts import OpenAI_TTS
    from secret import OPENAI_API_KEY   # or use the try/except version shown above
    # Initialize OpenAI TTS
    tts = OpenAI_TTS(api_key=OPENAI_API_KEY)
    tts.set_model('gpt-4o-mini-tts')  # low-latency TTS model
    tts.set_voice('alloy')            # pick a voice
    # Quick hello (sanity check)
    tts.say("Hello! I'm OpenAI TTS.")
  3. Run the program:
    sudo python3 test_tts_openai.py
  4. You should hear the PiCar-X say:
3. Storytelling Robot
Now that we have tested both Piper and OpenAI TTS, let’s use them in a real project: a storytelling robot car that drives around while telling jokes.
In this program, the PiCar-X will:
  • Greet you with TTS when it starts.
  • Move forward and tell a first joke.
  • Move forward again and tell a second joke.
  • Finally drive backward, return “home,” and say goodbye.
It’s like having a little robot storyteller on wheels!
Run the code
sudo python3 15.storytelling_robot.py
from picarx import Picarx
# === TTS Configuration ===
# Default: Piper
tts = Piper()
tts.set_model("en_US-amy-low")  # use the voice model you installed
# Optional: switch to OpenAI TTS
# from picarx.tts import OpenAI_TTS
# from secret import OPENAI_API_KEY
# tts = OpenAI_TTS(api_key=OPENAI_API_KEY)
# tts.set_model("gpt-4o-mini-tts")  # low-latency TTS model
# tts.set_voice("alloy")            # choose a voice
# === PiCar-X Setup ===
px = Picarx()
tts.say("Hello! I'm PiCar-X speaking with Piper.")
def main():
        # Leg 1
        px.forward(30)
        time.sleep(3)
        px.stop()
        tts.say("Why can't your nose be twelve inches long? Because then it would be a foot!")
        # Leg 2
        px.forward(30)
        time.sleep(3)
        px.stop()
        tts.say("Why did the cow go to outer space? To see the moooon!")
        # Wrap-up
        tts.say("That's all for today. Goodbye, let's go home and sleep.")
        px.backward(30)
        time.sleep(6)
        px.stop()
        px.stop()
    finally:
        px.stop()
        px.set_dir_servo_angle(0)
if __name__ == "__main__":
    main()
Troubleshooting
  • No module named ‘secret’
    This means secret.py is not in the same folder as your Python file. Move secret.py into the same directory where you run the script, e.g.:
    ls ~/picar-x/example
    # Make sure you see both: secret.py and your .py file
  • OpenAI: Invalid API key / 401
    • Check that you pasted the full key (starts with sk-) and there are no extra spaces/newlines.
    • Ensure your code imports it correctly:
    • Confirm network access on your Pi (try ping api.openai.com).
  • OpenAI: Quota exceeded / billing error
    • You may need to add billing or increase quota in the OpenAI dashboard.
    • Try again after resolving the account/billing issue.
  • Piper: tts.say() runs but no sound
    • Make sure a voice model is actually present:
      ls ~/.local/share/piper/voices
    • Confirm your model name matches exactly in code:
    • Check the audio output device/volume on your Pi (alsamixer), and that speakers are connected and powered.
  • ALSA / sound device errors (e.g., “Audio device busy” or “No such file or directory”)
    • Close other programs using audio.
    • Reboot the Pi if the device stays busy.
    • For HDMI vs. headphone jack output, select the correct device in Raspberry Pi OS audio settings.
  • Permission denied when running Python
    • Try with sudo if your environment requires it:
Comparison of TTS Engines
Feature comparison: Espeak vs Pico2Wave vs Piper vs OpenAI TTS
Item
Espeak
Pico2Wave
Piper
OpenAI TTS
Runs on
Built-in on Raspberry Pi (offline)
Raspberry Pi / PC (offline, needs model)
Cloud (online, needs API key)
Voice quality
Robotic
More natural than Espeak
Natural (neural TTS)
Very natural / human-like
Controls
Speed, pitch, volume
Limited controls
Choose different voices/models
Choose model and voices
Languages
Many (quality varies)
Limited set
Many voices/languages available
Best in English (others vary by availability)
Latency / speed
Very fast
Fast
Real-time on Pi 4/5 with “low” models
Network-dependent (usually low latency)
Setup
Minimal
Minimal
Download .onnx + .onnx.json models
Create API key, install client
Best for
Quick tests, basic prompts
Slightly better offline voice
Local projects with better quality
Highest quality, rich voice options
