20. Treasure Hunt
In this lesson, you will turn your PiCar-X into a treasure hunter robot. Arrange a maze in your room and place six different color cards in different corners. Your PiCar-X will search, recognize, and celebrate when it finds the target color.
This project combines three skills you’ve learned so far:
  • Computer Vision – detecting colored cards with the Pi camera.
  • Keyboard Control – driving the robot manually through the maze.
  • Speech Feedback – Pico2Wave announces the target color and success.
It’s a fun game that shows how robots can see, think, and act just like treasure hunters!
You can download and print the PDF Color Cards for reliable color detection.
Before You Start
Make sure you‘ve completed:
Run the Code
cd ~/picar-x/example
sudo python3 20.treasure_hunt.py
After running, you’ll see a message like this:
Then, open http://<your IP>:9000/mjpg in your browser to view the live video feed. Example: http://192.168.18.113:9000/mjpg
../_images/display.png
Game Rules
  1. The robot randomly selects a target color and says: “Look for red!”
  2. You drive PiCar-X with the keyboard:
    • w = forward
    • a = turn left
    • s = backward
    • d = turn right
    • space = repeat target
    • Ctrl+C = quit
  3. When the camera sees the target color card, PiCar-X says “Well done!”
  4. A new target color is chosen, and the hunt continues!
from picarx import Picarx
from vilib import Vilib
from picarx.tts import Pico2Wave
from time import sleep
import threading
import readchar
import random
# Settings
COLORS = ["red", "orange", "yellow", "green", "blue", "purple"]
DETECTION_WIDTH_THRESHOLD = 100  # how wide the color blob must be
DRIVE_SPEED = 80
TURN_ANGLE = 30
MANUAL = """
Press keys to control PiCar-X:
  w: forward    a: turn left    s: backward    d: turn right
  space: repeat target          Ctrl+C: quit
# Init
px = Picarx()
tts = Pico2Wave()
tts.set_lang("en-US")
current_color = "red"
key = None
lock = threading.Lock()
def say(line: str):
    print(f"[SAY] {line}")
    tts.say(line)
def renew_color_detect():
    """Choose a new target color and start detection."""
    global current_color
    current_color = random.choice(COLORS)
    Vilib.color_detect(current_color)
    say(f"Look for {current_color}!")
def key_scan_thread():
    """Background thread reading keys."""
    global key
        k = readchar.readkey()
        # Map special keys before lowercasing
        if k == readchar.key.SPACE:
            mapped = "space"
        elif k == readchar.key.CTRL_C:
            mapped = "quit"
            mapped = k.lower()
        with lock:
            key = mapped
        if mapped == "quit":
            return
        sleep(0.01)
def car_move(k: str):
    if k == "w":
        px.set_dir_servo_angle(0)
        px.forward(DRIVE_SPEED)
    elif k == "s":
        px.backward(DRIVE_SPEED)
    elif k == "a":
        px.set_dir_servo_angle(-TURN_ANGLE)
    elif k == "d":
        px.set_dir_servo_angle(TURN_ANGLE)
def main():
    global key
    # Start camera and web preview
    Vilib.camera_start(vflip=False, hflip=False)
    Vilib.display(local=False, web=True)
    sleep(0.8)
    print(MANUAL.strip())
    say("Game start!")
    sleep(0.1)
    # Start keyboard thread (modern style)
    key_thread = threading.Thread(target=key_scan_thread, daemon=True)
    key_thread.start()
            # Check detection: if target color present and wide enough
            if (Vilib.detect_obj_parameter.get("color_n", 0) != 0 and
                Vilib.detect_obj_parameter.get("color_w", 0) > DETECTION_WIDTH_THRESHOLD):
                say("Well done!")
                sleep(0.1)
            # Take a snapshot of the last key (and clear it)
            with lock:
                k = key
                key = None
            # Handle movement / actions
            if k in ("w", "a", "s", "d"):
                car_move(k)
                sleep(0.5)
                px.stop()
            elif k == "space":
            elif k == "quit":
                print("\n[INFO] Quit requested.")
                break
            sleep(0.05)
        print("\n[INFO] Stopped by user.")
    finally:
            Vilib.camera_close()
        except Exception:
        px.stop()
        say("Goodbye!")
        sleep(0.2)
if __name__ == "__main__":
    main()
How It Works
  1. Initialization
    • Import modules and configure PiCar-X, camera, and TTS.
    • Set color list, speed, and steering angle.
  2. Target Selection
    • renew_color_detect() randomly picks a target color.
    • The robot announces the target with Pico2Wave.
  3. Keyboard Control
    • key_scan_thread() runs in the background to capture keys.
    • Keys w, a, s, d control motion; space repeats target.
  4. Color Detection
    • Camera constantly checks if the target color is visible.
    • If the detected blob is large enough, PiCar-X celebrates.
  5. Main Loop
    • Continuously handles movement, detection, and feedback.
    • Cleanly stops the robot and camera when quitting.
Troubleshooting
  • Camera feed not working?
    Run libcamera-hello to check if the Pi camera is connected properly.
  • Robot doesn’t detect colors?
    Ensure the cards are printed clearly and placed in good lighting. Try adjusting DETECTION_WIDTH_THRESHOLD.
  • No voice feedback?
    Check that pico2wave is installed and your audio output is configured.
  • Car doesn’t move?
    Verify PiCar-X power is on and the motor calibration is correct.
By completing this lesson, you’ve built a mini treasure hunt game with PiCar-X, combining vision, control, and interaction into one project!
