.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _py_tts: 13. Play Music and Sound Effects ===================================== In this project, you will learn how to make the PiCar-X play background music or sound effects. You can also play music files that you have stored. **Before You Start** Make sure you‘ve completed: * :ref:`install_all_modules` — Install ``robot-hat``, ``vilib``, ``picar-x`` modules, then run the script ``i2samp.sh``. **Run the Code** .. raw:: html .. code-block:: cd ~/picar-x/example sudo python3 13.sound_background_music.py After the code runs, please operate according to the prompt that printed on the terminal. Input key to call the function! * space: Play sound effect (Car horn) * c: Play sound effect with threads * q: Play/Stop Music **Code** .. code-block:: python from time import sleep from picarx.music import Music import readchar music = Music() manual = ''' Input key to call the function! space: Play sound effect (Car horn) c: Play sound effect with threads q: Play/Stop Music ''' def main(): print(manual) flag_bgm = False music.music_set_volume(20) while True: key = readchar.readkey() key = key.lower() if key == "q": flag_bgm = not flag_bgm if flag_bgm is True: music.music_play('../musics/slow-trail-Ahjay_Stelino.mp3') else: music.music_stop() elif key == readchar.key.SPACE: music.sound_play('../sounds/car-double-horn.wav') sleep(0.05) elif key == "c": music.sound_play_threading('../sounds/car-double-horn.wav') sleep(0.05) if __name__ == "__main__": main() **How it works?** Functions related to background music include these: * ``music = Music()`` : Declare the object. * ``music.music_set_volume(20)`` : Set the volume, the range is 0~100. * ``music.music_play('../musics/slow-trail-Ahjay_Stelino.mp3')`` : Play music files, here is the **slow-trail-Ahjay_Stelino.mp3** file under the ``../musics`` path. * ``music.music_stop()`` : Stop playing background music. .. note:: You can add different sound effects or music to ``musics`` or ``sounds`` folder via :ref:`filezilla`.
