14. Voice Prompt Car with Espeak and Pico2Wave
In this lesson, we’ll use two built-in text-to-speech (TTS) engines on Raspberry Pi — Espeak and Pico2Wave — to make the PiCar-X talk.
These two engines are both simple and run offline, but they sound quite different:
Espeak: very lightweight and fast, but the voice is robotic. You can adjust speed, pitch, and volume.
Pico2Wave: produces a smoother and more natural voice than Espeak, but has fewer options to configure.
You’ll hear the difference in voice quality and features, and then build a “voice prompt car” that announces its actions before moving.
Before You Start
Make sure you‘ve completed:
Install All the Modules (Important) — Install
robot-hat,vilib,picar-xmodules, then run the scripti2samp.sh.
1. Testing Espeak
Espeak is a lightweight TTS engine included in Raspberry Pi OS. Its voice sounds robotic, but it is highly configurable: you can adjust volume, pitch, speed, and more.
Steps to try it out:
Create a new file with the command:
cd ~/picar-x/example sudo nano test_tts_espeak.py
Then copy the example code into it. Press
Ctrl+X, thenY, and finallyEnterto save and exit.from picarx.tts import Espeak tts = Espeak() # Optional voice tuning # tts.set_amp(100) # 0 to 200 # tts.set_speed(150) # 80 to 260 # tts.set_gap(5) # 0 to 200 # tts.set_pitch(50) # 0 to 99 # Quick hello (sanity check) tts.say("Hello! I'm Espeak TTS.")
Run the program with:
sudo python3 test_tts_espeak.py
You should hear the PiCar-X say: “Hello! I’m Espeak TTS.”
Uncomment the voice tuning lines in the code to experiment with how
amp,speed,gap, andpitchaffect the sound.
2. Testing Pico2Wave
Pico2Wave produces a more natural, human-like voice than Espeak. It’s simpler to use but less flexible — you can only change the language, not the pitch or speed.
cd ~/picar-x/example sudo nano test_tts_pico2wave.py
Ctrl+X, thenY, and finallyEnterto save and exit.from picarx.tts import Pico2Wave tts = Pico2Wave() tts.set_lang('en-US') # en-US, en-GB, de-DE, es-ES, fr-FR, it-IT # Quick hello (sanity check) tts.say("Hello! I'm Pico2Wave TTS.")
sudo python3 test_tts_pico2wave.py
You should hear the PiCar-X say: “Hello! I’m Pico2Wave TTS.”
Try switching the language (for example,
es-ESfor Spanish) and listen to the difference.
3. Voice Prompt Car
Now let’s combine Pico2Wave or Espeak with PiCar-X driving code to create a “voice prompt car”: before every action, the car will announce what it’s about to do.
Run the Code
sudo python3 14.voice_promt_car.py
Run this code and you’ll see your PiCar-X drive forward, backward, and turn, each time announcing its move first. This makes your car safer, friendlier, and more interactive.
from picarx import Picarx
# If you want to try Pico2Wave instead of Espeak, uncomment below:
# from picarx.tts import Pico2Wave
# tts = Pico2Wave()
# tts.set_lang('en-US') # Options: en-US, en-GB, de-DE, es-ES, fr-FR, it-IT
px = Picarx()
tts = Espeak()
# Quick hello (test)
tts.say("Hello! I'm PiCar-X.")
def main():
# Forward
tts.say("Moving forward")
px.forward(30)
time.sleep(2)
px.stop()
# Backward
tts.say("Moving backward")
px.backward(30)
time.sleep(2)
px.stop()
# Turn left
tts.say("Turning left")
px.set_dir_servo_angle(-20)
px.forward(30)
time.sleep(2)
px.stop()
px.set_dir_servo_angle(0)
# Turn right
tts.say("Turning right")
px.set_dir_servo_angle(20)
px.forward(30)
time.sleep(2)
px.stop()
# Stop if interrupted
px.stop()
finally:
# Reset to safe state
px.stop()
if __name__ == "__main__":
main()
Troubleshooting
No sound when running Espeak or Pico2Wave
Check that your speakers/headphones are connected and volume is not muted.
Run a quick test in terminal:
espeak "Hello world" pico2wave -w test.wav "Hello world" && aplay test.wav
If you hear nothing, the issue is with audio output, not your Python code.
Espeak voice sounds too fast or too robotic
Try adjusting the parameters in your code:
tts.set_speed(120) # slower tts.set_pitch(60) # different pitch
Permission denied when running code
Try running with
sudo:sudo python3 test_tts_espeak.py
Comparison: Espeak vs Pico2Wave
Feature |
Espeak |
Pico2Wave |
Voice quality |
Robotic, synthetic |
More natural, human-like |
Languages |
Default English |
Fewer, but common ones |
Adjustable |
Yes (speed, pitch, etc.) |
No (only language) |
Performance |
Very fast, lightweight |
Slightly slower, heavier |
