21. AI Voice Assistant Car
This lesson turns your PiCar-X into an AI-powered voice assistant on wheels. The robot can wake up to your voice, recognize what you say, talk back with emotion, and act out its “feelings” through movements, gestures, and lights.
You’ll build a fully interactive voice assistant car using:
  • LLM - Large Language Model (OpenAI GPT or Doubao).
  • STT - Speech-to-Text (voice to text).
  • TTS - Text-to-Speech (text to voice).
  • Sensors + Actions - Ultrasonic, camera, and built-in expressive actions.
Before You Start
Make sure you‘ve completed:
You should already have:
  • A working microphone and speaker on your PiCar-X.
  • A valid API key stored in secret.py.
  • A stable network connection (a wired connection is recommended for better stability).
Run the Example
Both language versions are placed in the same directory:
cd ~/picar-x/example
English version (OpenAI GPT, instructions in English):
sudo python3 21.voice_active_car_gpt.py
  • LLM: OpenAI GPT-4o-mini
  • TTS: en_US-ryan-low (Piper)
  • STT: Vosk (en-us)
Wake word:
"Hey buddy"
Chinese version (Doubao, instructions in Chinese):
sudo python3 21.voice_active_car_doubao_cn.py
  • LLM: Doubao-seed-1-6-250615
  • TTS: zh_CN-huayan-x_low (Piper)
  • STT: Vosk (cn)
Wake word:
"你好 滴滴"
You can modify the wake word and robot name in the code: NAME = "Buddy" or NAME = "滴滴" WAKE_WORD = ["hey buddy"] or WAKE_WORD = ["你好 滴滴"]
What Will Happen
When you run this example successfully:
  • The robot waits for the wake word (e.g., “Hey Buddy” / “你好 滴滴”).
  • When it hears the wake word:
    • LEDs will blink and stay on.
    • The robot greets you with a cheerful voice.
  • It then starts listening to your voice in real time.
  • After recognizing what you said, it:
    • Sends your speech to the LLM (OpenAI or Doubao).
    • Thinks and blinks LED while processing.
    • Replies with TTS voice.
    • Executes corresponding actions (e.g., nodding, turning, celebrating).
  • If you approach it too closely, the ultrasonic sensor:
    • Triggers an auto backward move for safety.
    • Interrupts the current round with a warning response.
Example interaction
You: Hey Buddy
Robot: Hi there!
You: Turn left and look around.
Robot: Roger that, turning my head left like a curious cat!
ACTIONS: turn_left, look_left
Switching to Other LLMs or TTS
You can easily switch to other LLMs, TTS, or STT languages with just a few edits:
  • Supported LLMs:
    • OpenAI
    • Doubao
    • Deepseek
    • Gemini
    • Qwen
    • Grok
  • 1. Testing Piper — Check the supported languages of Piper TTS.
  • 2. Test Vosk — Check the supported languages of Vosk STT.
To switch, simply modify the initialization part in the code:
from picarx.llm import Gemini as LLM
llm = LLM(api_key="YOUR_KEY", model="gemini-pro")
# Set models and languages
TTS_MODEL = "en_US-ryan-low"
STT_LANGUAGE = "en-us"
Action & Sound Reference
Below are the action keywords the LLM can return (after the ACTIONS: line) and what they do on the robot.
Action
What it does (per preset_actions.py)
Effect / Notes
shake head
Quickly swings camera pan angle right↔left in diminishing steps, then centers.
“No” gesture; wheels remain stopped.
nod
Bobs camera tilt up↔down twice, then centers.
“Yes” gesture; wheels remain stopped.
wave hands
Tilts camera, then steers left/right twice (±25°) and centers.
Playful wave (uses steering servo as “arms”).
resist
Small tilt; alternates (steer ±15°, pan ±15°) 3 times; stops and centers.
“Refuse”/defensive motion.
act cute
Head tilt down; quick forward/back micro-shuffles (short motor pulses), then reset.
Bouncy “cute” move; very short motions.
rub hands
Repeated small steering oscillation (±6°) five times; reset.
Mimics “rubbing hands together”.
think
Smooth pan right + tilt down + steer right sweep; brief hold; small poised pose; reset.
Used as a single “thinking” animation.
twist body
Three cycles of short forward/stop/pan-left/steer-left, then short backward/stop/pan-right/steer-right.
Gives a body “twist” vibe.
celebrate
Tilt up; two right pan/steer flourishes, then two left flourishes; returns to center.
Festive, symmetrical flourish.
depressed
Series of downward tilt pulses with varying angles and pauses; ends after a long beat and resets.
“Sad” posture sequence.
Movement & Utility
Action
What it does
Notes
forward
Drive forward at low speed for ~1 second, then stop.
Implemented by forward(car) (5% speed + 1s).
backward
Drive backward at low speed for ~1 second, then stop.
Implemented by backward(car) (5% speed + 1s).
Sound Effects
Sound
What it does
Notes
honking
Plays car-double-horn.wav asynchronously (volume ~100).
Triggered via Music.sound_play_threading.
start engine
Plays car-start-engine.wav asynchronously (volume ~50).
Boot/ready cue.
Sensor Triggers (Automatic)
  • Ultrasonic proximity
    • Trigger: distance < 10 cm
    • Side effect: auto backward + disable image for this round
    • Injected message: <<<Ultrasonic sense too close: {distance}cm>>>
Lifecycle Hooks (LED Indicators)
  • before_listen → blink twice (ready to listen)
  • before_think → blinking (thinking)
  • before_say → LED on (speaking)
  • after_say → wait for actions → LED off
  • on_stop → stop actions, close devices
Troubleshooting
  • The robot doesn’t respond to wake word
    • Check if the microphone works.
    • Ensure WAKE_ENABLE = True.
    • Adjust wake word to match your pronunciation.
  • No sound from the speaker
    • Verify TTS model setup.
    • Test Piper or Espeak manually.
    • Check speaker connection and volume.
  • API Key error or timeout
    • Check your key in secret.py.
    • Ensure network connection.
    • Confirm the LLM is supported.
  • Picar-X doesn’t move or act
    • Check that the action name matches actions_dict.
    • Verify motor and servo connections.
  • Ultrasonic sensor keeps triggering unexpectedly.
    • Check sensor installation height and angle.
    • Adjust the TOO_CLOSE distance threshold in code.
