16. Voice Controlled Car with Vosk (Offline)
Vosk is a lightweight speech-to-text (STT) engine that supports many languages and runs fully offline on Raspberry Pi. You only need internet access once to download a language model. After that, everything works without a network connection.
In this lesson, we will:
  • Check the microphone on Raspberry Pi.
  • Install and test Vosk with a chosen language model.
  • Build a voice controlled PiCar-X that listens for a wake word and then responds to commands like forward, backward, left, and right.
Before You Start
Make sure you‘ve completed:
1. Check Your Microphone
Before using speech recognition, make sure your USB microphone works correctly.
  1. List available recording devices:
    arecord -l
    Look for a line like card 1: ... device 0.
  2. Record a short sample (replace 1,0 with the numbers you found):
    arecord -D plughw:1,0 -f S16_LE -r 16000 -d 3 test.wav
    • Example: if your device is card 2, device 0, use:
    arecord -D plughw:2,0 -f S16_LE -r 16000 -d 3 test.wav
  3. Play it back to confirm the recording:
    aplay test.wav
  4. Adjust microphone volume if needed:
    alsamixer
    • Press F6 to select your USB microphone.
    • Find the Mic or Capture channel.
    • Make sure it is not muted ([MM] means mute, press M to unmute → should show [OO]).
    • Use ↑ / ↓ arrow keys to change the recording volume.
2. Test Vosk
Steps to try it out:
  1. Create a new file:
    cd ~/picar-x/example
    sudo nano test_stt_vosk.py
  2. Copy the example code into it. Press Ctrl+X, then Y, and Enter to save and exit.
    from picarx.stt import Vosk
    vosk = Vosk(language="en-us")
    print(vosk.available_languages)
        print("Say something")
        result = vosk.listen(stream=False)
        print(result)
  3. Run the program:
    sudo python3 test_stt_vosk.py
  4. The first time you run this code with a new language, Vosk will automatically download the language model (by default it will download the small version). At the same time, it will also print out the list of supported languages. Then you will see:
    vosk-model-small-en-us-0.15.zip: 100%|███████████████████| 39.3M/39.3M [00:05<00:00, 7.85MB/s]
    ['ar', 'ar-tn', 'ca', 'cn', 'cs', 'de', 'en-gb', 'en-in', 'en-us', 'eo', 'es', 'fa', 'fr', 'gu', 'hi', 'it', 'ja', 'ko', 'kz', 'nl', 'pl', 'pt', 'ru', 'sv', 'te', 'tg', 'tr', 'ua', 'uz', 'vn']
    Say something
    This means:
    • The model file (vosk-model-small-en-us-0.15) has been downloaded.
    • The list of supported languages has been printed.
    • The system is now listening — say something into the PiCar-X microphone, and the recognized text will appear in the terminal.
    Tips:
    • Keep the microphone about 15–30 cm away.
    • Pick a model that matches your language and accent.
Streaming Mode (optional)
You can also stream speech continuously to see partial results as you speak:
    for result in vosk.listen(stream=True):
        if result["done"]:
            print(f"final:   {result['final']}")
            print(f"partial: {result['partial']}", end="\r", flush=True)
3. Voice Controlled Car
Now let’s connect speech recognition to the PiCar-X!
We will use a wake word (“hey robot”) so the car only listens for commands after being activated. This saves CPU and prevents unwanted triggers.
Run the code
sudo python3 16.voice_controlled_car.py
In this program, the car:
  • Waits for the wake word “hey robot”.
  • After that, you can speak naturally — as long as your sentence includes one of the keywords (forward, backward, left, right), the car will respond.
    For example:
    • “Can you move forward a little?” → the car moves forward.
    • “Please turn left now.” → the car turns left.
  • The command “sleep” stops the control loop and puts the car back into waiting mode.
from picarx import Picarx
px = Picarx()
stt = Vosk(language="en-us")
WAKE_WORDS = ["hey robot"]
print('Say "hey robot" to wake me up! Then say: forward / backward / left / right. Say "sleep" to stop listening.')
        # --- wait for wake word once ---
        stt.wait_until_heard(WAKE_WORDS)
        print("Wake word detected. Listening for commands... (say 'sleep' to pause)")
        # --- command loop: multiple commands after one wake ---
            res = stt.listen(stream=False)
            text = res.get("text", "") if isinstance(res, dict) else str(res)
            text = text.lower().strip()
            if not text:
                continue
            print("Heard:", text)
            if "sleep" in text:
                # pause command mode; go back to wait for wake word
                px.stop(); px.set_dir_servo_angle(0)
                print("Sleeping. Say 'hey robot' to wake me again.")
                break
            elif "forward" in text:
                px.forward(30); time.sleep(1); px.stop()
            elif "backward" in text:
                px.backward(30); time.sleep(1); px.stop()
            elif "left" in text:
                px.set_dir_servo_angle(-25)
            elif "right" in text:
                px.set_dir_servo_angle(25)
            # (ignore other words)
finally:
    print("Stopped and centered. Bye.")
Troubleshooting
  • No such file or directory (when running `arecord`)
    You may have used the wrong card/device number. Run:
    arecord -l
    and replace 1,0 with the numbers shown for your USB microphone.
  • Recorded file has no sound
    Open the mixer and check the microphone volume:
    alsamixer
    • Press F6 to select your USB mic.
    • Make sure Mic/Capture is not muted ([OO] instead of [MM]).
    • Increase the level with ↑.
  • Vosk does not recognize speech
    • Make sure the language code matches your model (e.g. en-us for English, zh-cn for Chinese).
    • Keep the microphone 15–30 cm away and avoid background noise.
    • Speak clearly and slowly.
  • Wake word (“hey robot”) never triggers
    • Say it in a natural tone, not too fast.
    • Check that the program prints recognized text at all. If not, the microphone is not working.
  • High latency / slow recognition
    • The default auto-download is a small model (faster, but less accurate).
    • If it’s still slow, close other programs to free CPU.
