1.1.6 LED Dot Matrix
As the name suggests, an LED dot matrix is a matrix composed of LEDs. The lighting up and dimming of the LEDs formulate different characters and patterns.
../_images/1.1.6_led_dot_matrix_list.png
Principle
LED Dot Matrix
Generally, LED dot matrix can be categorized into two types: common cathode (CC) and common anode (CA). They look much alike, but internally the difference lies. You can tell by test. A CA one is used in this kit. You can see 788BS labeled at the side.
See the figure below. The pins are arranged at the two ends at the back. Take the label side for reference: pins on this end are pin 1-8, and oh the other are pin 9-16.
The external view:
../_images/1.1.6_led_dot_matrix_1.png
Below the figures show their internal structure. You can see in a CA LED dot matrix, ROW represents the anode of the LED, and COL is cathode; it’s contrary for a CC one. One thing in common: for both types, pin 13, 3, 4, 10, 6, 11, 15, and 16 are all COL, when pin 9, 14, 8, 12, 1, 7, 2, and 5 are all ROW. If you want to turn on the first LED at the top left corner, for a CA LED dot matrix, just set pin 9 as High and pin 13 as Low, and for a CC one, set pin 13 as High and pin 9 as Low. If you want to light up the whole first column, for CA, set pin 13 as Low and ROW 9, 14, 8, 12, 1, 7, 2, and 5 as High, when for CC, set pin 13 as High and ROW 9, 14, 8, 12, 1, 7, 2, and 5 as Low. Consider the following figures for better understanding.
The internal view:
../_images/1.1.6_led_dot_matrix_2.png
Pin numbering corresponding to the above rows and columns:
COL
8
Pin No.
13
15
16
ROW
8
Pin No.
9
14
8
12
In addition, two 74HC595 chips are used here. One is to control the rows of the LED dot matrix while the other, the columns.
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
../_images/1.1.6_led_dot_matrix_schematic.png
Experimental Procedures
Step 1: Build the circuit. Since the wiring is complicated, let’s make it step by step. First, insert the T-Cobbler, the LED dot matrix and two 74HC595 chips into breadboard. Connect the 3.3V and GND of the T-Cobbler to holes on the two sides of the board, then hook up pin16 and 10 of the two 74HC595 chips to VCC, pin 13 and pin 8 to GND.
In the Fritzing image above, the side with label is at the bottom.
../_images/1.1.6_LedMatrix_circuit_1.png
Step 2: Connect pin 11 of the two 74HC595 together, and then to GPIO27; then pin 12 of the two chips, and to GPIO18; next, pin 14 of the 74HC595 on the left side to GPIO17 and pin 9 to pin 14 of the second 74HC595.
../_images/1.1.6_LedMatrix_circuit_2.png
Step 3: The 74HC595 on the right side is to control columns of the LED dot matrix. See the table below for the mapping. Therefore, Q0-Q7 pins of the 74HC595 are mapped with pin 13, 3, 4, 10, 6, 11, 15, and 16 respectively.
74HC595
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
LED Dot Matrix
13
15
16
../_images/1.1.6_LedMatrix_circuit_3.png
Step 4: Now connect the ROWs of the LED dot matrix. The 74HC595 on the left controls ROW of the LED dot matrix. See the table below for the mapping. We can see, Q0-Q7 of the 74HC595 on the left are mapped with pin 9, 14, 8, 12, 1, 7, 2, and 5 respectively.
74HC595
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
LED Dot Matrix
9
14
8
12
../_images/1.1.6_LedMatrix_circuit_4.png
Step 5: Open the code file.
Step 6: Run.
sudo python3 1.1.6_led_dot_matrix.py
After the code runs, the LED dot matrix lights up and out row by row and column by column.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from time import sleep
# Define GPIO pins connected to the 74HC595 shift register
SDI = OutputDevice(17)   # Serial Data Input
RCLK = OutputDevice(18)  # Register Clock
SRCLK = OutputDevice(27) # Shift Register Clock
# Define patterns for matrix display; ROWs are anodes (+), COLs are cathodes (-)
# Pattern for ROWs (anode signals)
code_H = [0x01, 0xff, 0x80, 0xff, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff]
# Pattern for COLs (cathode signals)
code_L = [0x00, 0x7f, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f]
# Shift data to 74HC595
def hc595_shift(dat):
   """ Shift data to the 74HC595 shift register for displaying on the matrix. """
   for i in range(8):
      # Set SDI value and trigger shift register clock
      SDI.value = 0x80 & (dat << i)
      SRCLK.on()
      SRCLK.off()
   # Trigger register clock to update display
   RCLK.on()
   sleep(0.001)
   RCLK.off()
def main():
   """ Main loop for cycling through display patterns. """
      # Cycle through patterns in ascending order
      for i in range(len(code_H)):
            hc595_shift(code_L[i])
            hc595_shift(code_H[i])
            sleep(0.1)
      # Cycle through patterns in descending order
      for i in range(len(code_H)-1, -1, -1):
            sleep(0.1)
# Run main loop, handle keyboard interrupt gracefully
   main()
Code Explanation
  1. This snippet imports the necessary classes for the project. OutputDevice from gpiozero is used to control hardware components connected to GPIO pins, and sleep from time is for adding delays.
  2. This section initializes GPIO pins connected to the 74HC595 shift register. SDI is the Serial Data Input, RCLK is the Register Clock, and SRCLK is the Shift Register Clock. These pins are used to shift data into the register and control the display of the LED matrix.
  3. code_H and code_L define binary patterns for controlling the rows (anodes) and columns (cathodes) of the LED matrix, respectively. Each element in these arrays represents a binary pattern that controls which LEDs are turned on or off in the matrix.
  4. This function shifts a byte of data (dat) into the 74HC595 shift register. It iterates over each bit in the byte, setting the SDI pin high or low based on the bit value, and toggles the SRCLK pin to shift the bit into the register. After all bits are shifted, it toggles the RCLK pin to update the LED matrix display.
       for i in range(8):
          SRCLK.on()
          SRCLK.off()
       RCLK.on()
       sleep(0.001)
       RCLK.off()
  5. The main function contains an infinite loop that cycles through predefined patterns for the LED matrix. It uses the hc595_shift function to send row and column patterns (code_H and code_L) to the shift register, first in ascending order and then in descending order, creating a dynamic display.
    def main():
                sleep(0.1)
                sleep(0.1)
  6. This segment ensures the program can be interrupted using a keyboard interrupt (Ctrl+C). It gracefully exits the main loop without any abrupt stoppage or resource leakage.
       main()
