1.1.5 4-Digit 7-Segment Display¶
Introduction¶
Next, follow me to try to control the 4-digit 7-segment display.
Components¶
In this projiect, for the 4-Digit 7-Segment Display we should use BS model,if you use AS model it may not light up.
Schematic Diagram¶
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
SPIMOSI |
Pin 19 |
12 |
10 |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
Experimental Procedures¶
Step 1: Build the circuit.
cd /home/pi/raphael-kit/c/1.1.5/
Step 3: Compile the code.
gcc 1.1.5_4-Digit.c -lwiringPi
After the code runs, the program takes a count, increasing by 1 per second, and the 4-digit 7-segment display displays the count.
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to Install and Check the WiringPi.
#include <wiringPi.h>
#include <stdio.h>
#include <wiringShift.h>
#include <signal.h>
#include <unistd.h>
#define SDI 5
#define RCLK 4
#define SRCLK 1
const int placePin[] = {12, 3, 2, 0};
unsigned char number[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
int counter = 0;
void pickDigit(int digit)
for (int i = 0; i < 4; i++)
digitalWrite(placePin[i], 0);
digitalWrite(placePin[digit], 1);
void hc595_shift(int8_t data)
int i;
for (i = 0; i < 8; i++)
digitalWrite(SDI, 0x80 & (data << i));
digitalWrite(SRCLK, 1);
delayMicroseconds(1);
digitalWrite(SRCLK, 0);
digitalWrite(RCLK, 1);
digitalWrite(RCLK, 0);
void clearDisplay()
int i;
digitalWrite(SDI, 1);
void loop()
clearDisplay();
pickDigit(0);
hc595_shift(number[counter % 10]);
clearDisplay();
pickDigit(1);
hc595_shift(number[counter % 100 / 10]);
clearDisplay();
pickDigit(2);
hc595_shift(number[counter % 1000 / 100]);
clearDisplay();
pickDigit(3);
hc595_shift(number[counter % 10000 / 1000]);
void timer(int timer1)
if (timer1 == SIGALRM)
counter++;
alarm(1);
printf("%d\n", counter);
void main(void)
if (wiringPiSetup() == -1)
return;
pinMode(SDI, OUTPUT);
pinMode(RCLK, OUTPUT);
pinMode(SRCLK, OUTPUT);
pinMode(placePin[i], OUTPUT);
digitalWrite(placePin[i], HIGH);
signal(SIGALRM, timer);
alarm(1);
loop();
Code Explanation
These four pins control the common anode pins of the four-digit 7-segment display.
A segment code array from 0 to 9 in Hexadecimal (Common anode).
Select the place of the value. there is only one place that should be enable each time. The enabled place will be written high.
void loop()
clearDisplay();
pickDigit(0);
clearDisplay();
pickDigit(1);
clearDisplay();
pickDigit(2);
clearDisplay();
pickDigit(3);
The functionis used to set the number displayed on the 4-digit 7-segment display.
clearDisplay()
:write in 11111111 to turn off these eight LEDs on 7-segment display so as to clear the displayed content.pickDigit(0)
:pick the fourth 7-segment display.hc595_shift(number[counter%10])
:the number in the single digit of counter will display on the forth segment.
This is a system-provided function, the prototype of code is:
sig_t signal(int signum,sig_t handler);
After executing the signal()
, once the process receives the corresponding signum (in this case SIGALRM), it immediately pauses the existing task and processes the set function (in this case timer(sig)
alarm(1);
This is also a system-provided function. The code prototype is:
unsigned int alarm (unsigned int seconds);
It generates a SIGALRM signal after a certain number of seconds.
counter++;
alarm(1);
We use the functions above to implement the timer function.
After the alarm()
generates the SIGALRM signal, the timer function is called. Add 1 to counter, and the function, alarm(1)
will be repeatedly called after 1 second.
Phenomenon Picture¶
