1.1.3 LED Bar Graph
In this project, we sequentially illuminate the lights on the LED Bar Graph.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO18 |
Pin 12 |
18 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
GPIO25 |
Pin 22 |
25 |
SDA1 |
Pin 3 |
8 |
SCL1 |
Pin 5 |
9 |
SPICE0 |
Pin 24 |
10 |
8 |
Experimental Procedures
Step 1: Build the circuit.
Pay attention to the direction when connecting. If you connect it backwards, it will not light up.
cd ~/raphael-kit/c/1.1.3/
Step 3: Compile the code.
gcc 1.1.3_LedBarGraph.c -lwiringPi
After the code runs, you will see the LEDs on the LED bar turn on and off regularly.
#include <wiringPi.h>
#include <stdio.h>
int pins[10] = {0,1,2,3,4,5,6,8,9,10};
void oddLedBarGraph(void){
for(int i=0;i<5;i++){
int j=i*2;
digitalWrite(pins[j],HIGH);
delay(300);
digitalWrite(pins[j],LOW);
void evenLedBarGraph(void){
int j=i*2+1;
delay(300);
void allLedBarGraph(void){
for(int i=0;i<10;i++){
digitalWrite(pins[i],HIGH);
delay(300);
digitalWrite(pins[i],LOW);
int main(void)
for(int i=0;i<10;i++){ //make led pins' mode is output
pinMode(pins[i], OUTPUT);
oddLedBarGraph();
delay(300);
evenLedBarGraph();
delay(300);
allLedBarGraph();
delay(300);
Code Explanation
Create an array and assign it to the pin number corresponding to the LED Bar Graph (0,1,2,3,4,5,6,8,9,10) and the array will be used to control the LED.
int j=i*2;
delay(300);
Let the LED on the odd digit of the LED Bar Graph light on in turn.
int j=i*2+1;
delay(300);
Make the LED on the even digit of the LED Bar Graph light on in turn.
delay(300);
Let the LED on the LED Bar Graph light on one by one.
Phenomenon Picture
