1.1.6 LED Dot Matrix Module
In this project, you will learn about LED Matrix Module. LED Matrix Module uses the MAX7219 driver to drive the 8 x 8 LED Matrix.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPIMOSI |
Pin 19 |
12 |
MOSI |
SPICE0 |
pin 24 |
10 |
CE0 |
SPISCLK |
Pin 23 |
14 |
SCLK |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Turn on the SPI before starting the experiment, refer to SPI Configuration for details.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/c/1.1.6/
Step 4: Compile the code.
make
Step 5:: Run the executable file.
sudo ./1.1.6_LedMatrix
After running the code, the LED Dot Matrix displays from square, heart and number 0 to 9 in sequence.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0 // Define SPI channel (0 or 1)
#define SPI_SPEED 1000000 // SPI speed set to 1 MHz
// Function to write data to a MAX7219 register
void max7219_write(unsigned char address, unsigned char data) {
unsigned char buffer[2];
buffer[0] = address; // Register address to write to
buffer[1] = data; // Data to write into the register
wiringPiSPIDataRW(SPI_CHANNEL, buffer, 2); // Send data via SPI
// Function to initialize the MAX7219 display module
void max7219_init() {
max7219_write(0x09, 0x00); // Decode Mode: No decoding for digits (useful for 7-segment displays)
max7219_write(0x0A, 0x03); // Intensity: Set brightness level (0x00 to 0x0F)
max7219_write(0x0B, 0x07); // Scan Limit: Display digits 0-7 (all 8 digits)
max7219_write(0x0C, 0x01); // Shutdown Register: Normal operation (not in shutdown mode)
max7219_write(0x0F, 0x00); // Display Test: Normal operation (no test mode)
// Clear all digits on the display
for (int i = 1; i <= 8; i++) {
max7219_write(i, 0x00); // Write 0 to each digit register
// Function to display a pattern on the MAX7219
void max7219_display(unsigned char *data) {
max7219_write(i, data[i - 1]); // Write each row of the pattern to the display
// Function to display a pattern for a specified duration
void display_pattern(const unsigned char pattern[8], int delay_ms) {
max7219_display((unsigned char *)pattern); // Display the pattern
delay(delay_ms); // Wait for the specified time in milliseconds
// Array of patterns to display
const unsigned char patterns[][8] = {
// Square pattern
0b11111111, // Row 1
0b10000001, // Row 2
0b10000001, // Row 3
0b10000001, // Row 4
0b10000001, // Row 5
0b10000001, // Row 6
0b10000001, // Row 7
0b11111111 // Row 8
// Heart pattern
0b01100110, // Row 1
0b11111111, // Row 2
0b11111111, // Row 3
0b11111111, // Row 4
0b01111110, // Row 5
0b00111100, // Row 6
0b00011000, // Row 7
0b00000000 // Row 8
// Number 0
0b00111100, // Row 1
0b01100110, // Row 2
0b11000011, // Row 3
0b11000011, // Row 4
0b11000011, // Row 5
0b11000011, // Row 6
0b01100110, // Row 7
0b00111100 // Row 8
// Number 1
0b00011000, // Row 1
0b00111000, // Row 2
0b01111000, // Row 3
0b00011000, // Row 4
0b00011000, // Row 5
0b00011000, // Row 6
0b01111110, // Row 7
0b01111110 // Row 8
// Number 2
0b01111110, // Row 1
0b11000011, // Row 2
0b00000011, // Row 3
0b00001110, // Row 4
0b00110000, // Row 5
0b11000000, // Row 6
0b11111111, // Row 7
0b00000000 // Row 8
// Number 3
0b00111110, // Row 4
0b00000011, // Row 5
0b00000000 // Row 8
// Number 4
0b00001110, // Row 1
0b00011110, // Row 2
0b00110110, // Row 3
0b01100110, // Row 4
0b11111111, // Row 5
0b00000110, // Row 6
0b00000110, // Row 7
0b00000000 // Row 8
// Number 5
0b11000000, // Row 2
0b11111110, // Row 3
0b00000011, // Row 4
0b00000000 // Row 8
// Number 6
0b00111110, // Row 1
0b01100000, // Row 2
0b11000000, // Row 3
0b11111110, // Row 4
0b00000000 // Row 8
// Number 7
0b00000110, // Row 3
0b00001100, // Row 4
0b00110000, // Row 6
0b00110000, // Row 7
0b00000000 // Row 8
// Number 8
0b01111110, // Row 4
0b00000000 // Row 8
// Number 9
0b01111111, // Row 4
0b01111100, // Row 7
0b00000000 // Row 8
int main() {
if (wiringPiSetup() == -1) {
printf("Failed to initialize WiringPi\n");
printf("Failed to initialize SPI\n");
max7219_init(); // Initialize the MAX7219 module
// Display patterns in a loop
while (1) {
// Display the square pattern
display_pattern(patterns[0], 1000); // Display for 1000 milliseconds
// Display the heart pattern
display_pattern(patterns[1], 1000);
// Display numbers 0-9
for (int i = 2; i <= 11; i++) {
display_pattern(patterns[i], 1000);
Code Analysis
Header Files:
wiringPi.h: Provides functions for GPIO control.wiringPiSPI.h: Provides functions for SPI communication.stdio.h: Standard input/output library for functions like printf.
Definitions:
SPI_CHANNEL: Specifies the SPI channel (0 or 1) used for communication.SPI_SPEED: Sets the SPI communication speed to 1 MHz.
#define SPI_CHANNEL 0 // Define SPI channel (0 or 1) #define SPI_SPEED 1000000 // SPI speed set to 1 MHz
Function
max7219_write: Sends data to a specific register of the MAX7219 display driver.address: The address of the register to write to.data: The data to write into the register.Creates a buffer containing the address and data.
Uses
wiringPiSPIDataRWto send the buffer over SPI.
void max7219_write(unsigned char address, unsigned char data) { unsigned char buffer[2]; buffer[0] = address; // Register address to write to buffer[1] = data; // Data to write into the register wiringPiSPIDataRW(SPI_CHANNEL, buffer, 2); // Send data via SPI }
Function
max7219_init: Initializes the MAX7219 display module with required settings.Sets decode mode to “no decode” since we are directly controlling the LEDs.
Sets intensity (brightness) to a moderate level (0x03).
Sets scan limit to 7 to enable all 8 digits (rows) of the display.
Exits shutdown mode to turn on the display.
Disables display test mode.
Clears the display by writing 0x00 to all digit registers.
void max7219_init() { max7219_write(0x09, 0x00); // Decode Mode: No decoding for digits (useful for 7-segment displays) max7219_write(0x0A, 0x03); // Intensity: Set brightness level (0x00 to 0x0F) max7219_write(0x0B, 0x07); // Scan Limit: Display digits 0-7 (all 8 digits) max7219_write(0x0C, 0x01); // Shutdown Register: Normal operation (not in shutdown mode) max7219_write(0x0F, 0x00); // Display Test: Normal operation (no test mode) // Clear all digits on the display for (int i = 1; i <= 8; i++) { max7219_write(i, 0x00); // Write 0 to each digit register } }
Function
max7219_display: Updates the display with a given 8-byte pattern.data: An array containing the pattern to display.Iterates through each of the 8 rows (digits) and writes the corresponding data.
void max7219_display(unsigned char *data) { for (int i = 1; i <= 8; i++) { max7219_write(i, data[i - 1]); // Write each row of the pattern to the display } }
Function
display_pattern: Displays a pattern for a specified amount of time.pattern: The pattern to display (array of 8 bytes).delay_ms: Duration to display the pattern in milliseconds.Calls
max7219_displayto show the pattern.Uses
delayto wait for the specified duration.
void display_pattern(const unsigned char pattern[8], int delay_ms) { max7219_display((unsigned char *)pattern); // Display the pattern delay(delay_ms); // Wait for the specified time in milliseconds }
Array patterns:
Contains predefined patterns for the square, heart, and numbers 0-9.
Each pattern is an array of 8 bytes, representing 8 rows of the 8x8 LED matrix.
Each byte uses binary notation where each bit represents an LED (1 for on, 0 for off).
const unsigned char patterns[][8] = { // Square pattern { 0b11111111, // Row 1 0b10000001, // Row 2 0b10000001, // Row 3 0b10000001, // Row 4 0b10000001, // Row 5 0b10000001, // Row 6 0b10000001, // Row 7 0b11111111 // Row 8 }, ... // Number 9 { ... }, };
Function main:
Initializes
WiringPiandSPIinterface.if (wiringPiSetup() == -1) { printf("Failed to initialize WiringPi\n"); return 1; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("Failed to initialize SPI\n"); return 1; }
Calls
max7219_initto configure the MAX7219 module.max7219_init(); // Initialize the MAX7219 module
Enters an infinite loop to display the patterns continuously. Displays each pattern for 1 second before moving to the next.
while (1) { // Display the square pattern display_pattern(patterns[0], 1000); // Display for 1000 milliseconds // Display the heart pattern display_pattern(patterns[1], 1000); // Display numbers 0-9 for (int i = 2; i <= 11; i++) { display_pattern(patterns[i], 1000); } }
Understanding the Patterns
Binary Representation:
Each pattern is defined using binary literals (0b prefix).
Each byte corresponds to a row on the 8x8 LED matrix.
Each bit within the byte represents a column (LED) in that row.
The most significant bit (leftmost) corresponds to the first LED on the left.
Creating Custom Patterns:
You can create new patterns by defining new arrays of 8 bytes.
Each pattern can be added to the patterns array.
Update the display loop in main to include your new patterns.
Adjustments and Customization
Changing Brightness: Modify the intensity level in
max7219_init:max7219_write(0x0A, brightness_level); // brightness_level between 0x00 and 0x0F
Modifying Display Time: Change the
delay_msparameter indisplay_patterncalls to adjust how long each pattern is displayed.
