5. 休息状态
在本项目中,PiDog 会趴在地上打盹,当它听到周围的声音时,会迷迷糊糊地站起来,看看是谁打扰了它的美梦。
运行代码
cd ~/pidog/examples
sudo python3 5_rest.py
程序运行后,PiDog 会趴在地上,摇头摆尾,仿佛在打瞌睡。 此时,声音方向传感器模块开始工作。 如果 PiDog 听到响动,它会立刻站起来,环顾四周,露出一副迷惑的表情, 然后再次进入打盹状态。
代码
备注
您可以对以下代码进行 修改/重置/复制/运行/停止。但请确保已进入源码路径(如 pidog\examples)后操作。修改后可直接运行查看效果。
from pidog import Pidog
from time import sleep
from preset_actions import shake_head
my_dog = Pidog()
sleep(0.1)
def loop_around(amplitude=60, interval=0.5, speed=100):
my_dog.head_move([[amplitude,0,0]], immediately=True, speed=speed)
my_dog.wait_all_done()
sleep(interval)
my_dog.head_move([[-amplitude,0,0]], immediately=True, speed=speed)
sleep(interval)
my_dog.head_move([[0,0,0]], immediately=True, speed=speed)
def is_sound():
if my_dog.ears.isdetected():
direction = my_dog.ears.read()
if direction != 0:
return True
return False
return False
def rest():
my_dog.do_action('lie', speed=50)
# 进入睡眠状态
my_dog.rgb_strip.set_mode('breath', 'pink', bps=0.3)
my_dog.head_move([[0,0,-40]], immediately=True, speed=5)
my_dog.do_action('doze_off', speed=92)
# 清除之前的声音检测
sleep(1)
is_sound()
# 持续休息,直到检测到声音
while is_sound() is False:
sleep(0.2)
# 听到声音后唤醒
# Set light to yellow and stand up
my_dog.rgb_strip.set_mode('boom', 'yellow', bps=1)
my_dog.body_stop()
my_dog.do_action('stand', speed=90)
my_dog.head_move([[0, 0, 0]], immediately=True, speed=80)
# 环顾四周
loop_around(60, 1, 60)
sleep(0.5)
# 歪头迷惑
my_dog.speak('confused_3', volume=80)
my_dog.do_action('tilting_head_left', speed=80)
sleep(1.2)
my_dog.head_move([[0, 0, -10]], immediately=True, speed=80)
sleep(0.4)
# 摇头,表示不在意
shake_head(my_dog)
sleep(0.2)
# 再次趴下休息
my_dog.rgb_strip.set_mode('breath', 'pink', bps=1)
sleep(1)
if __name__ == "__main__":
rest()
except Exception as e:
finally:
my_dog.close()
