.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 14. Voice Prompt Car with Espeak and Pico2Wave ================================================= In this lesson, we'll use two built-in text-to-speech (TTS) engines on Raspberry Pi — **Espeak** and **Pico2Wave** — to make the PiCar-X talk. These two engines are both simple and run offline, but they sound quite different: * **Espeak**: very lightweight and fast, but the voice is robotic. You can adjust speed, pitch, and volume. * **Pico2Wave**: produces a smoother and more natural voice than Espeak, but has fewer options to configure. You'll hear the difference in **voice quality** and **features**, and then build a "voice prompt car" that announces its actions before moving. ---- Before You Start ---------------- Make sure you‘ve completed: * :ref:`install_all_modules` — Install ``robot-hat``, ``vilib``, ``picar-x`` modules, then run the script ``i2samp.sh``. 1. Testing Espeak -------------------- Espeak is a lightweight TTS engine included in Raspberry Pi OS. Its voice sounds robotic, but it is highly configurable: you can adjust volume, pitch, speed, and more. **Steps to try it out**: * Create a new file with the command: .. code-block:: bash cd ~/picar-x/example sudo nano test_tts_espeak.py * Then copy the example code into it. Press ``Ctrl+X``, then ``Y``, and finally ``Enter`` to save and exit. .. code-block:: python from picarx.tts import Espeak tts = Espeak() # Optional voice tuning # tts.set_amp(100) # 0 to 200 # tts.set_speed(150) # 80 to 260 # tts.set_gap(5) # 0 to 200 # tts.set_pitch(50) # 0 to 99 # Quick hello (sanity check) tts.say("Hello! I'm Espeak TTS.") * Run the program with: .. code-block:: bash sudo python3 test_tts_espeak.py * You should hear the PiCar-X say: “Hello! I'm Espeak TTS.” * Uncomment the voice tuning lines in the code to experiment with how ``amp``, ``speed``, ``gap``, and ``pitch`` affect the sound. ---- 2. Testing Pico2Wave --------------------- Pico2Wave produces a more natural, human-like voice than Espeak. It's simpler to use but less flexible — you can only change the language, not the pitch or speed. **Steps to try it out**: * Create a new file with the command: .. code-block:: bash cd ~/picar-x/example sudo nano test_tts_pico2wave.py * Then copy the example code into it. Press ``Ctrl+X``, then ``Y``, and finally ``Enter`` to save and exit. .. code-block:: python from picarx.tts import Pico2Wave tts = Pico2Wave() tts.set_lang('en-US') # en-US, en-GB, de-DE, es-ES, fr-FR, it-IT # Quick hello (sanity check) tts.say("Hello! I'm Pico2Wave TTS.") * Run the program with: .. code-block:: sudo python3 test_tts_pico2wave.py * You should hear the PiCar-X say: “Hello! I'm Pico2Wave TTS.” * Try switching the language (for example, ``es-ES`` for Spanish) and listen to the difference. ---- 3. Voice Prompt Car -------------------- Now let's combine **Pico2Wave** or **Espeak** with PiCar-X driving code to create a “voice prompt car”: before every action, the car will announce what it's about to do. **Run the Code** .. code-block:: bash cd ~/picar-x/example sudo python3 14.voice_promt_car.py Run this code and you'll see your PiCar-X drive forward, backward, and turn, each time announcing its move first. This makes your car safer, friendlier, and more interactive. **Code** .. code-block:: python from picarx import Picarx from picarx.tts import Espeak import time # If you want to try Pico2Wave instead of Espeak, uncomment below: # from picarx.tts import Pico2Wave # tts = Pico2Wave() # tts.set_lang('en-US') # Options: en-US, en-GB, de-DE, es-ES, fr-FR, it-IT px = Picarx() tts = Espeak() # Quick hello (test) tts.say("Hello! I'm PiCar-X.") def main(): try: # Forward tts.say("Moving forward") px.forward(30) time.sleep(2) px.stop() # Backward tts.say("Moving backward") px.backward(30) time.sleep(2) px.stop() # Turn left tts.say("Turning left") px.set_dir_servo_angle(-20) px.forward(30) time.sleep(2) px.stop() px.set_dir_servo_angle(0) # Turn right tts.say("Turning right") px.set_dir_servo_angle(20) px.forward(30) time.sleep(2) px.stop() px.set_dir_servo_angle(0) except KeyboardInterrupt: # Stop if interrupted px.stop() finally: # Reset to safe state px.stop() px.set_dir_servo_angle(0) if __name__ == "__main__": main() ---- Troubleshooting ------------------- * **No sound when running Espeak or Pico2Wave** * Check that your speakers/headphones are connected and volume is not muted. * Run a quick test in terminal: .. code-block:: bash espeak "Hello world" pico2wave -w test.wav "Hello world" && aplay test.wav If you hear nothing, the issue is with audio output, not your Python code. * **Espeak voice sounds too fast or too robotic** * Try adjusting the parameters in your code: .. code-block:: python tts.set_speed(120) # slower tts.set_pitch(60) # different pitch * **Permission denied when running code** * Try running with ``sudo``: .. code-block:: bash sudo python3 test_tts_espeak.py Comparison: Espeak vs Pico2Wave ------------------------------------- .. list-table:: :widths: 20 40 40 :header-rows: 1 * - Feature - Espeak - Pico2Wave * - Voice quality - Robotic, synthetic - More natural, human-like * - Languages - Default English - Fewer, but common ones * - Adjustable - Yes (speed, pitch, etc.) - No (only language) * - Performance - Very fast, lightweight - Slightly slower, heavier
