.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 15. AI Storytelling Robot with Piper and OpenAI ======================================================== In the previous lesson, we tried two built-in TTS engines on Raspberry Pi (**Espeak** and **Pico2Wave**). Now let's explore two more powerful options: **Piper** (offline, neural network-based) and **OpenAI TTS** (online, cloud-based). * **Piper**: a local TTS engine that runs offline on Raspberry Pi. * **OpenAI TTS**: an online service that provides very natural, human-like voices. At the end, your PiCar-X will drive around and tell jokes like a little storyteller. ---- Before You Start ---------------- Make sure you‘ve completed: * :ref:`install_all_modules` — Install ``robot-hat``, ``vilib``, ``picar-x`` modules, then run the script ``i2samp.sh``. ---- .. _test_piper: 1. Testing Piper ------------------ **Steps to try it out**: #. Create a new file: .. code-block:: bash cd ~/picar-x/example sudo nano test_tts_piper.py #. Copy the example code below into the file. Press ``Ctrl+X``, then ``Y``, and finally ``Enter`` to save and exit. .. code-block:: python from picarx.tts import Piper tts = Piper() # List supported languages print(tts.available_countrys()) # List models for English (en_us) print(tts.available_models('en_us')) # Set a voice model (auto-download if not already present) tts.set_model("en_US-amy-low") # Say something tts.say("Hello! I'm Piper TTS.") * ``available_countrys()``: print supported languages. * ``available_models()``: list available models for that language. * ``set_model()``: set the voice model (downloads automatically if missing). * ``say()``: convert text to speech and play it. #. Run the program: .. code-block:: bash sudo python3 test_tts_piper.py #. The first time you run it, the selected voice model will be downloaded automatically. * You should then hear the PiCar-X say: ``Hello! I'm Piper TTS.`` * You can change to another language model by calling ``set_model()`` with a different name. 2. Testing OpenAI TTS ------------------------------- **Get and save your API Key** #. Go to |link_openai_platform| and log in. On the **API keys** page, click **Create new secret key**. .. image:: img/llm_openai_create.png #. Fill in the details (Owner, Name, Project, and permissions if needed), then click **Create secret key**. .. image:: img/llm_openai_create_confirm.png #. Once the key is created, copy it right away — you won't be able to see it again. If you lose it, you must generate a new one. .. image:: img/llm_openai_copy.png #. In your project folder (for example: ``/picar-x/example``), create a file called ``secret.py``: .. code-block:: bash cd ~/picar-x/example sudo nano secret.py #. Paste your key into the file like this: .. code-block:: python # secret.py # Store secrets here. Never commit this file to Git. OPENAI_API_KEY = "sk-xxx" **Write and Run a Test Program** #. Create a new file: .. code-block:: bash cd ~/picar-x/example sudo nano test_tts_openai.py #. Copy the example code below into the file. Press ``Ctrl+X``, then ``Y``, and finally ``Enter`` to save and exit. .. code-block:: python from picarx.tts import OpenAI_TTS from secret import OPENAI_API_KEY # or use the try/except version shown above # Initialize OpenAI TTS tts = OpenAI_TTS(api_key=OPENAI_API_KEY) tts.set_model('gpt-4o-mini-tts') # low-latency TTS model tts.set_voice('alloy') # pick a voice # Quick hello (sanity check) tts.say("Hello! I'm OpenAI TTS.") #. Run the program: .. code-block:: bash sudo python3 test_tts_openai.py #. You should hear the PiCar-X say: ``Hello! I'm OpenAI TTS.`` 3. Storytelling Robot ------------------------ Now that we have tested both **Piper** and **OpenAI TTS**, let’s use them in a real project: a **storytelling robot car** that drives around while telling jokes. In this program, the PiCar-X will: * Greet you with TTS when it starts. * Move forward and tell a first joke. * Move forward again and tell a second joke. * Finally drive backward, return “home,” and say goodbye. It’s like having a little robot storyteller on wheels! **Run the code** .. code-block:: bash cd ~/picar-x/example sudo python3 15.storytelling_robot.py **Code** .. code-block:: python from picarx import Picarx import time # === TTS Configuration === # Default: Piper from picarx.tts import Piper tts = Piper() tts.set_model("en_US-amy-low") # use the voice model you installed # Optional: switch to OpenAI TTS # from picarx.tts import OpenAI_TTS # from secret import OPENAI_API_KEY # tts = OpenAI_TTS(api_key=OPENAI_API_KEY) # tts.set_model("gpt-4o-mini-tts") # low-latency TTS model # tts.set_voice("alloy") # choose a voice # === PiCar-X Setup === px = Picarx() # Quick hello (sanity check) tts.say("Hello! I'm PiCar-X speaking with Piper.") def main(): try: # Leg 1 px.forward(30) time.sleep(3) px.stop() tts.say("Why can't your nose be twelve inches long? Because then it would be a foot!") # Leg 2 px.forward(30) time.sleep(3) px.stop() tts.say("Why did the cow go to outer space? To see the moooon!") # Wrap-up tts.say("That's all for today. Goodbye, let's go home and sleep.") px.backward(30) time.sleep(6) px.stop() except KeyboardInterrupt: px.stop() finally: px.stop() px.set_dir_servo_angle(0) if __name__ == "__main__": main() ---- Troubleshooting ------------------- * **No module named 'secret'** This means ``secret.py`` is not in the same folder as your Python file. Move ``secret.py`` into the same directory where you run the script, e.g.: .. code-block:: bash ls ~/picar-x/example # Make sure you see both: secret.py and your .py file * **OpenAI: Invalid API key / 401** * Check that you pasted the full key (starts with ``sk-``) and there are no extra spaces/newlines. * Ensure your code imports it correctly: .. code-block:: python from secret import OPENAI_API_KEY * Confirm network access on your Pi (try ``ping api.openai.com``). * **OpenAI: Quota exceeded / billing error** * You may need to add billing or increase quota in the OpenAI dashboard. * Try again after resolving the account/billing issue. * **Piper: tts.say() runs but no sound** * Make sure a voice model is actually present: .. code-block:: bash ls ~/.local/share/piper/voices * Confirm your model name matches exactly in code: .. code-block:: python tts.set_model("en_US-amy-low") * Check the audio output device/volume on your Pi (``alsamixer``), and that speakers are connected and powered. * **ALSA / sound device errors (e.g., “Audio device busy” or “No such file or directory”)** * Close other programs using audio. * Reboot the Pi if the device stays busy. * For HDMI vs. headphone jack output, select the correct device in Raspberry Pi OS audio settings. * **Permission denied when running Python** * Try with ``sudo`` if your environment requires it: .. code-block:: bash sudo python3 test_tts_piper.py Comparison of TTS Engines ------------------------- .. list-table:: Feature comparison: Espeak vs Pico2Wave vs Piper vs OpenAI TTS :header-rows: 1 :widths: 18 18 20 22 22 * - Item - Espeak - Pico2Wave - Piper - OpenAI TTS * - Runs on - Built-in on Raspberry Pi (offline) - Built-in on Raspberry Pi (offline) - Raspberry Pi / PC (offline, needs model) - Cloud (online, needs API key) * - Voice quality - Robotic - More natural than Espeak - Natural (neural TTS) - Very natural / human-like * - Controls - Speed, pitch, volume - Limited controls - Choose different voices/models - Choose model and voices * - Languages - Many (quality varies) - Limited set - Many voices/languages available - Best in English (others vary by availability) * - Latency / speed - Very fast - Fast - Real-time on Pi 4/5 with “low” models - Network-dependent (usually low latency) * - Setup - Minimal - Minimal - Download ``.onnx`` + ``.onnx.json`` models - Create API key, install client * - Best for - Quick tests, basic prompts - Slightly better offline voice - Local projects with better quality - Highest quality, rich voice options
