.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ai_voice_assistant_car: 21. AI Voice Assistant Car =========================== This lesson turns your PiCar-X into an **AI-powered voice assistant on wheels**. The robot can wake up to your voice, recognize what you say, talk back with emotion, and act out its “feelings” through movements, gestures, and lights. You'll build a **fully interactive voice assistant car** using: * **LLM** - Large Language Model (OpenAI GPT or Doubao). * **STT** - Speech-to-Text (voice to text). * **TTS** - Text-to-Speech (text to voice). * **Sensors + Actions** - Ultrasonic, camera, and built-in expressive actions. ---- Before You Start ---------------- Make sure you‘ve completed: * :ref:`install_all_modules` — Install ``robot-hat``, ``vilib``, ``picar-x`` modules, then run the script ``i2samp.sh``. * :ref:`test_piper` — Check the supported languages of **Piper TTS**. * :ref:`test_vosk` — Check the supported languages of **Vosk STT**. * :ref:`py_online_llm` — This step is **very important**: obtain your **OpenAI** or **Doubao** API key, or the API key for any other supported LLM. You should already have: * A working **microphone** and **speaker** on your PiCar-X. * A **valid API key** stored in ``secret.py``. * A stable network connection (a **wired connection** is recommended for better stability). ---- Run the Example --------------- Both language versions are placed in the same directory: .. code-block:: bash cd ~/picar-x/example **English version** (OpenAI GPT, instructions in English): .. code-block:: bash sudo python3 21.voice_active_car_gpt.py * LLM: ``OpenAI GPT-4o-mini`` * TTS: ``en_US-ryan-low`` (Piper) * STT: Vosk (``en-us``) Wake word: .. code-block:: "Hey buddy" --- **Chinese version** (Doubao, instructions in Chinese): .. code-block:: bash sudo python3 21.voice_active_car_doubao_cn.py * LLM: ``Doubao-seed-1-6-250615`` * TTS: ``zh_CN-huayan-x_low`` (Piper) * STT: Vosk (``cn``) Wake word: .. code-block:: "你好 滴滴" .. note:: You can modify the **wake word** and **robot name** in the code: ``NAME = "Buddy"`` or ``NAME = "滴滴"`` ``WAKE_WORD = ["hey buddy"]`` or ``WAKE_WORD = ["你好 滴滴"]`` ---- What Will Happen ----------------- When you run this example successfully: * The robot **waits for the wake word** (e.g., “Hey Buddy” / “你好 滴滴”). * When it hears the wake word: * LEDs will **blink** and stay on. * The robot **greets you** with a cheerful voice. * It then starts **listening to your voice** in real time. * After recognizing what you said, it: * Sends your speech to the **LLM** (OpenAI or Doubao). * **Thinks** and blinks LED while processing. * Replies with **TTS voice**. * Executes **corresponding actions** (e.g., nodding, turning, celebrating). * If you approach it too closely, the ultrasonic sensor: * Triggers an auto **backward** move for safety. * Interrupts the current round with a warning response. **Example interaction** .. code-block:: text You: Hey Buddy Robot: Hi there! You: Turn left and look around. Robot: Roger that, turning my head left like a curious cat! ACTIONS: turn_left, look_left ---- Switching to Other LLMs or TTS ------------------------------ You can easily switch to other LLMs, TTS, or STT languages with just a few edits: * Supported LLMs: * OpenAI * Doubao * Deepseek * Gemini * Qwen * Grok * :ref:`test_piper` — Check the supported languages of **Piper TTS**. * :ref:`test_vosk` — Check the supported languages of **Vosk STT**. To switch, simply modify the initialization part in the code: .. code-block:: python from picarx.llm import Gemini as LLM llm = LLM(api_key="YOUR_KEY", model="gemini-pro") # Set models and languages TTS_MODEL = "en_US-ryan-low" STT_LANGUAGE = "en-us" ---- Action & Sound Reference ------------------------ Below are the **action keywords** the LLM can return (after the ``ACTIONS:`` line) and what they do on the robot. .. list-table:: :header-rows: 1 :widths: 20 55 25 * - **Action** - **What it does (per preset_actions.py)** - **Effect / Notes** * - ``shake head`` - Quickly swings camera pan angle right↔left in diminishing steps, then centers. - “No” gesture; wheels remain stopped. * - ``nod`` - Bobs camera tilt up↔down twice, then centers. - “Yes” gesture; wheels remain stopped. * - ``wave hands`` - Tilts camera, then steers left/right twice (±25°) and centers. - Playful wave (uses steering servo as “arms”). * - ``resist`` - Small tilt; alternates (steer ±15°, pan ±15°) 3 times; stops and centers. - “Refuse”/defensive motion. * - ``act cute`` - Head tilt down; quick forward/back micro-shuffles (short motor pulses), then reset. - Bouncy “cute” move; very short motions. * - ``rub hands`` - Repeated small steering oscillation (±6°) five times; reset. - Mimics “rubbing hands together”. * - ``think`` - Smooth pan right + tilt down + steer right sweep; brief hold; small poised pose; reset. - Used as a single “thinking” animation. * - ``twist body`` - Three cycles of short forward/stop/pan-left/steer-left, then short backward/stop/pan-right/steer-right. - Gives a body “twist” vibe. * - ``celebrate`` - Tilt up; two right pan/steer flourishes, then two left flourishes; returns to center. - Festive, symmetrical flourish. * - ``depressed`` - Series of downward tilt pulses with varying angles and pauses; ends after a long beat and resets. - “Sad” posture sequence. Movement & Utility ~~~~~~~~~~~~~~~~~~ .. list-table:: :header-rows: 1 :widths: 22 58 20 * - **Action** - **What it does** - **Notes** * - ``forward`` - Drive forward at low speed for ~1 second, then stop. - Implemented by ``forward(car)`` (5% speed + 1s). * - ``backward`` - Drive backward at low speed for ~1 second, then stop. - Implemented by ``backward(car)`` (5% speed + 1s). Sound Effects ~~~~~~~~~~~~~ .. list-table:: :header-rows: 1 :widths: 24 56 20 * - **Sound** - **What it does** - **Notes** * - ``honking`` - Plays ``car-double-horn.wav`` asynchronously (volume ~100). - Triggered via ``Music.sound_play_threading``. * - ``start engine`` - Plays ``car-start-engine.wav`` asynchronously (volume ~50). - Boot/ready cue. Sensor Triggers (Automatic) ~~~~~~~~~~~~~~~~~~~~~~~~~~~ * **Ultrasonic proximity** * Trigger: distance < 10 cm * Side effect: auto ``backward`` + disable image for this round * Injected message: ``<<>>`` Lifecycle Hooks (LED Indicators) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ * ``before_listen`` → blink twice (ready to listen) * ``before_think`` → blinking (thinking) * ``before_say`` → LED on (speaking) * ``after_say`` → wait for actions → LED off * ``on_stop`` → stop actions, close devices ---- Troubleshooting --------------- * **The robot doesn’t respond to wake word** * Check if the microphone works. * Ensure ``WAKE_ENABLE = True``. * Adjust wake word to match your pronunciation. * **No sound from the speaker** * Verify TTS model setup. * Test Piper or Espeak manually. * Check speaker connection and volume. * **API Key error or timeout** * Check your key in ``secret.py``. * Ensure network connection. * Confirm the LLM is supported. * **Picar-X doesn't move or act** * Check that the action name matches ``actions_dict``. * Verify motor and servo connections. * **Ultrasonic sensor keeps triggering unexpectedly.** * Check sensor installation height and angle. * Adjust the ``TOO_CLOSE`` distance threshold in code.
