2.2.6 MPU6050 Module
The MPU-6050 is the world’s first and only 6-axis motion tracking devices (3-axis Gyroscope and 3-axis Accelerometer) designed for smartphones, tablets and wearable sensors that have these features, including the low power, low cost, and high performance requirements.
In this experiment, use I2C to obtain the values of the three-axis acceleration sensor and three-axis gyroscope for MPU6050 and display them on the screen.
Components
../_images/list_2.2.6.png
Schematic Diagram
MPU6050 communicates with the microcontroller through the I2C bus interface. The SDA1 and SCL1 need to be connected to the corresponding pin.
../_images/image330.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image227.png
Step 2: Setup I2C (see Appendix I²C Configuration. If you have set I2C, skip this step.)
Step 3: Install dependencies.
sudo npm install mpu6050-gyro
Step 4: Run the code.
sudo node mpu6050_module.js
With the code run, the angle of deflection of the x-axis and y-axis and the acceleration, angular velocity on each axis read by MPU6050 will be printed on the screen after being calculating.
var gyro = require("mpu6050-gyro");
var address = 0x68; //MPU6050 address
var bus = 1; //i2c bus used
var gyro = new gyro( bus,address );
async function update_telemetry() {
    var gyro_xyz = gyro.get_gyro_xyz();
    var accel_xyz = gyro.get_accel_xyz();
    var gyro_data = {
        gyro_xyz: gyro_xyz,
        accel_xyz: accel_xyz,
        rollpitch: gyro.get_roll_pitch( gyro_xyz, accel_xyz )
    console.log(gyro_data);
    setTimeout(update_telemetry, 500);
if ( gyro ) {
    update_telemetry();
Code Explanation
Import the mpu6050-gyro module, determine the MPU6050 address and the bus creation object gyro, It is convenient to call the encapsulated functions in the module.
About this module, please refer to: https://www.npmjs.com/package/mpu6050-gyro
var gyro_data = {
    gyro_xyz: gyro_xyz,
The module encapsulates three available functions:
gyro.get_gyro_xyz(): Returns JSON object with raw x,y,z datas from gyroscope.
gyro.get_accel_xyz(): Returns JSON object with raw x,y,z datas from accelerometer.
gyro.get_roll_pitch( gyro_xyz, accel_xyz ): Returns JSON object with roll and pitch in degrees.
Phenomenon Picture
../_images/image228.jpeg
