2.2.2 Thermistor(MCP3008)
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
Schematic Diagram
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
Experimental Procedures
Step 1: Build the circuit.
Step 3: Run the code.
sudo node thermistor-2.js
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
const mcpadc = require('mcp-spi-adc');
// Open MCP3008 channel 0 (CH0), analog input from thermistor voltage divider
const adc = mcpadc.openMcp3008(0, { speedHz: 1350000 }, (err) => {
if (err) {
console.error('Failed to open MCP3008 channel:', err);
process.exit(1);
console.log('MCP3008 thermistor channel opened.');
setInterval(() => {
adc.read((err, reading) => {
if (err) {
console.error('ADC read error:', err);
return;
const adcValue = reading.value; // Float: 0.0–1.0
const raw = Math.round(adcValue * 1023); // 10-bit integer value
const Vr = 3.3 * raw / 1023; // Convert to voltage (assuming 3.3V Vref)
const R0 = 10000; // Fixed resistor: 10k
const B = 3950; // B constant
const Rt = R0 * Vr / (3.3 - Vr); // Thermistor resistance
const tempK = 1 / ((Math.log(Rt / R0) / B) + (1 / (273.15 + 25))); // Kelvin
const tempC = tempK - 273.15; // Celsius
const tempF = tempC * 1.8 + 32; // Fahrenheit
console.log(`Celsius: ${tempC.toFixed(2)} °C | Fahrenheit: ${tempF.toFixed(2)} °F`);
}, 1000);
Code Explanation
setInterval(() => {
}, 1000);
Sets up a loop to read from MCP3008 channel 0 every 1000 milliseconds (1 second). The read function returns an analog value between 0.0 and 1.0.
const raw = Math.round(reading.value * 1023);
Converts the normalized float ADC value into a raw 10-bit integer (range 0–1023).
Calculates the voltage at the thermistor (Vr) using the ADC reading. Assumes MCP3008 reference voltage is 3.3V.
Uses the voltage divider formula to calculate the thermistor resistance Rt, where R0 is a fixed resistor (10kΩ) in series.
This applies the B-parameter equation (a simplified form of the Steinhart-Hart equation) to estimate the temperature in Kelvin.
These convert the Kelvin temperature to Celsius and then Fahrenheit.
Prints both the Celsius and Fahrenheit temperature values with two decimal points of precision to the console.
