πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.2.1 Photoresistor
Introduction
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Components
../_images/list_2.2.1_photoresistor.png
Schematic Diagram
../_images/image321.png ../_images/image322.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image198.png
Step 3: Run the code.
sudo node photoresistor.js
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
const ADC0834 = require('./adc0834.js').ADC0834;
exports.ADC0834 = ADC0834;
const adc = new ADC0834(17, 18, 27);
const led = new Gpio(22, {mode: Gpio.OUTPUT});
setInterval(() => {
  adc.read(0).then((value) => {
    console.log(value);
    led.pwmWrite(value);
  }, (error)=>{
    console.log("Error: " + error);
}, 100);
Code Explanation
The codes here are the same as that in 2.1.4 Potentiometer. Please check the code explanation of 2.1.4 Potentionmeter for details.
Phenomenon Picture
../_images/image199.jpeg
