2.2.1 Photoresistor(MCP3008)
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
../_images/list2_2.2.1_photoresistor.png
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
GPIO22
pin15
../_images/schematic_2.2.1_photoresistor_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.1_Photoresistor_bb.png
Step 3: Run the code.
sudo node photoresistor-2.js
const mcpadc = require('mcp-spi-adc');
// Open MCP3008 channel 0 (analog input CH0)
const adc = mcpadc.openMcp3008(0, { speedHz: 1350000 }, (err) => {
if (err) {
    console.error("Failed to open MCP3008:", err);
    process.exit(1);
console.log("MCP3008 initialized on SPI0/CE0.");
// Initialize LED on GPIO22 (PWM capable)
const led = new Gpio(22, { mode: Gpio.OUTPUT });
// Set up interval to read ADC and update LED brightness every 100ms
const interval = setInterval(() => {
    adc.read((err, reading) => {
    if (err) {
        console.error("ADC read error:", err);
        return;
    const adcValue = reading.value;          // Float between 0.0 and 1.0
    const pwmValue = Math.round(adcValue * 255); // Scale to 0–255
    console.log(`ADC = ${adcValue.toFixed(4)}, PWM = ${pwmValue}`);
    led.pwmWrite(pwmValue); // Update LED brightness
}, 100);
// Handle Ctrl+C (SIGINT) to clean up
process.on('SIGINT', () => {
    console.log('\nGracefully shutting down...');
    clearInterval(interval);  // Stop the interval loop
    led.digitalWrite(0);      // Turn off LED
    process.exit(0);
Code Explanation
This line imports the pigpio module, which is used to control GPIO pins on the Raspberry Pi. It supports PWM output required for dimming an LED.
This line imports the mcp-spi-adc library, which enables communication with the MCP3008 analog-to-digital converter using the Raspberry Pi’s hardware SPI interface.
const adc = mcpadc.openMcp3008(0, { speedHz: 1350000 }, (err) => { ... });
Opens analog input channel 0 of the MCP3008 chip using hardware SPI. The SPI clock speed is set to 1.35 MHz. If an error occurs while opening the channel, the program logs it and exits.
Initializes GPIO pin 22 as an output. This pin is used to control the brightness of an LED using PWM via the pigpio library.
setInterval(() => {
}, 100);
Sets up a recurring loop that runs every 100 milliseconds. Within each cycle, it reads the analog value from MCP3008 channel 0. The result is a floating-point number between 0.0 and 1.0, representing the ratio of input voltage to reference voltage.
Converts the analog value to an 8-bit PWM value in the range 0–255, then writes it to GPIO22 to adjust LED brightness proportionally.
    process.exit(0);
Adds a signal handler to gracefully shut down the program when Ctrl+C is pressed. It stops the interval loop, turns off the LED, and exits the program cleanly.
