πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.5 Keypad
Introduction
A keypad is a rectangular array of buttons. In this project, We will use it input characters.
Components
../_images/list_2.1.5_keypad.png
Schematic Diagram
../_images/image315.png ../_images/image316.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image186.png
Step 2: Open the code file.
Step 3: Run.
sudo node keypad.js
After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen.
var rowsPins = [18,23,24,25];
var colsPins = [10,6,27,17];
var keys = ["1","2","3","A",
        "4","5","6","B",
        "7","8","9","C",
        "*","0","#","D"];
for(let i=0;i<rowsPins.length;i++){
    rowsPins[i] = new Gpio(rowsPins[i],{mode: Gpio.OUTPUT})
for(let i=0;i<colsPins.length;i++){
    colsPins[i] = new Gpio(colsPins[i],{
        mode: Gpio.INPUT,
        pullUpDown: Gpio.PUD_DOWN,
        edge: Gpio.RISING_EDGE
var last_key_pressed = 0;
var col=-1;
    colsPins[i].on('interrupt',()=>{
        col=i;
        pressed_keys=keys[row*colsPins.length+col];
        if(last_key_pressed!=pressed_keys){
            console.log(`${pressed_keys}`);
        last_key_pressed = pressed_keys;
var row=-1;
setInterval(() => {
    row=(row+1)%rowsPins.length;
        rowsPins[i].digitalWrite(0);
    rowsPins[row].digitalWrite(1);
}, 10);
Code Explanation
        "4","5","6","B",
        "7","8","9","C",
        "*","0","#","D"];
        mode: Gpio.INPUT,
In the style of the keypad, declare two sets of pins and a matrix.
Four of the pins are the row of the keypad, set these pins to OUTPUT mode; The other four pins are the columns of the keypad, set these pins to INPUT mode, and set the rising edge interrupt for them.
The principle that the main controller can obtain the key value is as follows: The four row pins provide high level in turn, if a button is pressed, The corresponding column pin will get the high level released by the row pin, which will trigger the rising edge interrupt.
For example, if I press the button 3 , when the 2nd, 3rd, and 4th row pins release the high level, there is no effect; When the row pin in the first position releases the high level, the third column pin will be able to obtain the high level and trigger the rising edge interrupt. At this time, the 1st, 2nd, and 4th column pins do not trigger any events.
Then, according to the 1st row pin that releases the high level and the 3rd column pin that gets the high level, the main controller will be able to know that the position of the pressed button is (1,3), which is the button 3.
../_images/image187.png
var row=-1;
setInterval(() => {
}, 10);
The four row pins are periodically supplied high, and the variable row is used to locate the currently working row pin.
var col=-1;
        col=i;
        // pressed_keys=keys[row*colsPins.length+col];
        // if(last_key_pressed!=pressed_keys){
        //     console.log(`${pressed_keys}`);
        // last_key_pressed = pressed_keys;
Set up interrupt functions for the four column pins, and the variable col is used to locate the column pins that trigger the rising edge interrupt event.
There is also a piece of code in the break function to get the specific key value from the keys matrix according to row and col. And every time you get a new key value, print the value.
Phenomenon Picture
../_images/image188.jpeg
